    Autostarts but doesn't run, will run on restart
    47 Posts 3 Posters 18.8k Views 3 Watching
    • E Offline
      ember1205 @sdetweil
      What’s the goal?
      I have .config/chromium and .config/Electron with the latter being two years old and the former having a current date (I switched to Chromium because Electron was a ton of trouble).
      This is all on Bullseye which I upgraded to (yeah, yeah, I know… don’t upgrade, fresh install, not supported, etc.). Up to that point, it was on Buster and ran fine.
      Incidentally… I have an automated routine to bring the RPi down gracefully based on a virtual switch setting on a home automation controller. Here’s the gist:
      • Set the virtual switch to “on”
      • Every five minutes, the RPi queries the status of the switch
      • If the switch is set to “1” (on), it launches a script with sudo
      The script does the following:
      • Using cec-client, it puts the Soundbar into Standby (off)
      • Using cec-client, it puts the TV into standby (off)
      • Sets the status of the virtual switch to “1” (on) to ensure that any other items that trigger of the state change of that switch will run as well
      • Sets the status of the virtual switch to “0” (off)
      • Sends an IFTTT message using WebHooks / curl
      • Does a “shutdown now”
      If I comment out the cec commands, it starts up incorrectly. If I manually just do a “shutdown now” and boot it back up, it starts up incorrectly.
        sdetweil @ember1205
        @ember1205 what pi?
        if armv6l, use the legacy buster image… do NOT upgrade to bullseye
        uname -a will show u
        the deletes were to wipe out any saved config data for the browser so it would come up clean…
        (not desktop.) supposedly
        • E Offline
          ember1205 @sdetweil
          armv71
          I’ve modified my shutdown control to stop MM, wipe the .config/chromium directory, and then power off. This allows chromium to load the correct information when it does finally launch.
          There still remains an issue, however, with the run-start.sh script actually launching the chromium browser on boot. The log file basically ends with “0|mm | Ready to go! Please point your browser to: http://0.0.0.0:8080” on boot up. “pm2 restart mm” correctly brings everything up every time.
          Here’s what the log looks like when it boots:
          0|mm       | > magicmirror@2.13.0 start
          0|mm       | > ./run-start.sh
          0|mm       |
          0|mm       | [2022-05-10 14:30:59.191] [LOG]    Starting MagicMirror: v2.13.0
          0|mm       | [2022-05-10 14:30:59.207] [LOG]    Loading config ...
          0|mm       | [2022-05-10 14:30:59.222] [LOG]    Loading module helpers ...
          0|mm       | [2022-05-10 14:31:00.614] [LOG]    Initializing new module helper ...
          0|mm       | [2022-05-10 14:31:00.617] [LOG]    Module helper loaded: MMM-ImagesPhotos
          0|mm       | [2022-05-10 14:31:00.625] [LOG]    No helper found for module: alert.
          0|mm       | [2022-05-10 14:31:00.733] [LOG]    Initializing new module helper ...
          0|mm       | [2022-05-10 14:31:00.735] [LOG]    Module helper loaded: updatenotification
          0|mm       | [2022-05-10 14:31:00.741] [LOG]    No helper found for module: clock.
          0|mm       | [2022-05-10 14:31:01.058] [LOG]    Initializing new module helper ...
          0|mm       | [2022-05-10 14:31:01.060] [LOG]    Module helper loaded: calendar
          0|mm       | [2022-05-10 14:31:01.068] [LOG]    No helper found for module: currentweather.
          0|mm       | [2022-05-10 14:31:01.072] [LOG]    No helper found for module: weatherforecast.
          0|mm       | [2022-05-10 14:31:01.074] [LOG]    All module helpers loaded.
          0|mm       | [2022-05-10 14:31:02.616] [LOG]    Starting server on port 8080 ...
          0|mm       | [2022-05-10 14:31:02.665] [LOG]    Server started ...
          0|mm       | [2022-05-10 14:31:02.680] [LOG]    Connecting socket for: MMM-ImagesPhotos
          0|mm       | [2022-05-10 14:31:02.683] [LOG]    Starting node helper for: MMM-ImagesPhotos
          0|mm       | [2022-05-10 14:31:02.685] [LOG]    Connecting socket for: updatenotification
          0|mm       | [2022-05-10 14:31:02.693] [LOG]    Connecting socket for: calendar
          0|mm       | [2022-05-10 14:31:02.700] [LOG]    Starting node helper for: calendar
          0|mm       | [2022-05-10 14:31:02.702] [LOG]    Sockets connected & modules started ...
          0|mm       | [2022-05-10 14:31:02.704] [LOG]
            sdetweil @ember1205
            @ember1205 ok,
            lets edit run-start.sh t- enable some more debugging
            in the 1st line add -x to the change the 1st line to
            #!/bin/bash -x
            then pm2 flush
            then do the reboot which causes mm not to come up.
            then pm2 logs --lines=100
            the debug output will come out in the error listing of the two listings displayed
            E 3 Replies Last reply Reply Quote 0
            • E Offline
              ember1205 @sdetweil
              Full logs…
              PM2        | 2022-05-10T15:00:25: PM2 log: PM2 successfully stopped
              PM2        | 2022-05-10T15:00:44: PM2 log: ===============================================================================
              PM2        | 2022-05-10T15:00:44: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
              PM2        | 2022-05-10T15:00:44: PM2 log: Time                 : Tue May 10 2022 15:00:44 GMT-0400 (Eastern Daylight Time)
              PM2        | 2022-05-10T15:00:44: PM2 log: PM2 version          : 4.4.1
              PM2        | 2022-05-10T15:00:44: PM2 log: Node.js version      : 16.15.0
              PM2        | 2022-05-10T15:00:44: PM2 log: Current arch         : arm
              PM2        | 2022-05-10T15:00:44: PM2 log: PM2 home             : /home/pi/.pm2
              PM2        | 2022-05-10T15:00:44: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
              PM2        | 2022-05-10T15:00:44: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
              PM2        | 2022-05-10T15:00:44: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
              PM2        | 2022-05-10T15:00:44: PM2 log: Application log path : /home/pi/.pm2/logs
              PM2        | 2022-05-10T15:00:44: PM2 log: Worker Interval      : 30000
              PM2        | 2022-05-10T15:00:44: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
              PM2        | 2022-05-10T15:00:44: PM2 log: Concurrent actions   : 2
              PM2        | 2022-05-10T15:00:44: PM2 log: SIGTERM timeout      : 1600
              PM2        | 2022-05-10T15:00:45: PM2 log: App [mm:0] starting in -fork mode-
              PM2        | 2022-05-10T15:00:45: PM2 log: App [mm:0] online
              0|mm       | + '[' -f ./untrack-css.sh ']'
              0|mm       | + grep docker /proc/1/cgroup -qa
              0|mm       | + '[' -z :0 ']'
              0|mm       | ++ uname -m
              0|mm       | + arch=armv7l
              0|mm       | + false=false
              0|mm       | ++ grep -v '^[[:blank:]]*//' config/config.js
              0|mm       | ++ grep -i serveronly:
              0|mm       | ++ awk -F: '{print tolower($2)}'
              0|mm       | ++ sed -e 's/^[[:space:]]*//'
              0|mm       | ++ tr -d ',"'\''\r'
              0|mm       | + serveronly=local
              0|mm       | ++ pgrep Xorg
              0|mm       | + xorg=
              0|mm       | + '[' . == . ']'
              0|mm       | ++ pgrep X
              0|mm       | + xorg=
              0|mm       | ++ uname
              0|mm       | + mac=Linux
              0|mm       | + '[' local. '!=' false. -o armv7l == armv6l ']'
              0|mm       | + '[' local. == true. ']'
              0|mm       | + '[' . == . -a Linux '!=' Darwin ']'
              0|mm       | + node serveronly
              0|mm       |
              0|mm       |
              0|mm       | [2022-05-10 15:00:55.768] [LOG]    Starting MagicMirror: v2.13.0
              0|mm       | [2022-05-10 15:00:55.790] [LOG]    Loading config ...
              0|mm       | [2022-05-10 15:00:55.804] [LOG]    Loading module helpers ...
              0|mm       | [2022-05-10 15:00:57.248] [LOG]    Initializing new module helper ...
              0|mm       | [2022-05-10 15:00:57.252] [LOG]    Module helper loaded: MMM-ImagesPhotos
              0|mm       | [2022-05-10 15:00:57.264] [LOG]    No helper found for module: alert.
              0|mm       | [2022-05-10 15:00:57.385] [LOG]    Initializing new module helper ...
              0|mm       | [2022-05-10 15:00:57.387] [LOG]    Module helper loaded: updatenotification
              0|mm       | [2022-05-10 15:00:57.391] [LOG]    No helper found for module: clock.
              0|mm       | [2022-05-10 15:00:57.686] [LOG]    Initializing new module helper ...
              0|mm       | [2022-05-10 15:00:57.689] [LOG]    Module helper loaded: calendar
              0|mm       | [2022-05-10 15:00:57.692] [LOG]    No helper found for module: currentweather.
              0|mm       | [2022-05-10 15:00:57.696] [LOG]    No helper found for module: weatherforecast.
              0|mm       | [2022-05-10 15:00:57.698] [LOG]    All module helpers loaded.
              0|mm       | [2022-05-10 15:01:00.465] [LOG]    Starting server on port 8080 ...
              0|mm       | [2022-05-10 15:01:00.504] [LOG]    Server started ...
              0|mm       | [2022-05-10 15:01:00.507] [LOG]    Connecting socket for: MMM-ImagesPhotos
              0|mm       | [2022-05-10 15:01:00.509] [LOG]    Starting node helper for: MMM-ImagesPhotos
              0|mm       | [2022-05-10 15:01:00.511] [LOG]    Connecting socket for: updatenotification
              0|mm       | [2022-05-10 15:01:00.514] [LOG]    Connecting socket for: calendar
              0|mm       | [2022-05-10 15:01:00.516] [LOG]    Starting node helper for: calendar
              0|mm       | [2022-05-10 15:01:00.517] [LOG]    Sockets connected & modules started ...
              0|mm       | [2022-05-10 15:01:00.519] [LOG]
              • E Offline
                ember1205 @sdetweil
                Here’s a portion of the log when doing a stop and a start (without reboot):
                0|mm       | + xorg=755
                0|mm       | + '[' 755. == . ']'
                0|mm       | ++ uname
                0|mm       | + mac=Linux
                0|mm       | + '[' 755. == . -a Linux '!=' Darwin ']'
                0|mm       | + exec
                0|mm       | + read line
                0|mm       | ++ node serveronly
                0|mm       | + case "$line" in
                0|mm       | + echo '[2022-05-10' '15:14:59.203]' '[LOG]' Starting MagicMirror: v2.13.0
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:14:59.220]' '[LOG]' Loading config ...
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:14:59.231]' '[LOG]' Loading module helpers ...
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:14:59.936]' '[LOG]' Initializing new module helper ...
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:14:59.938]' '[LOG]' Module helper loaded: MMM-ImagesPhotos
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:14:59.943]' '[LOG]' No helper found for module: alert.
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.042]' '[LOG]' Initializing new module helper ...
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.050]' '[LOG]' Module helper loaded: updatenotification
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.059]' '[LOG]' No helper found for module: clock.
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.274]' '[LOG]' Initializing new module helper ...
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.278]' '[LOG]' Module helper loaded: calendar
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.280]' '[LOG]' No helper found for module: currentweather.
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.282]' '[LOG]' No helper found for module: weatherforecast.
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.284]' '[LOG]' All module helpers loaded.
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.471]' '[LOG]' Starting server on port 8080 ...
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.496]' '[LOG]' Server started ...
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.498]' '[LOG]' Connecting socket for: MMM-ImagesPhotos
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.500]' '[LOG]' Starting node helper for: MMM-ImagesPhotos
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.502]' '[LOG]' Connecting socket for: updatenotification
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.504]' '[LOG]' Connecting socket for: calendar
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.505]' '[LOG]' Starting node helper for: calendar
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.506]' '[LOG]' Sockets connected '&' modules started ...
                0|mm       | + read line
                0|mm       | + echo '[2022-05-10' '15:15:00.507]' '[LOG]'
                0|mm       | + read line
                0|mm       | + echo Ready to 'go!' Please point your browser to: http://0.0.0.0:8080
                0|mm       | + break
                0|mm       | ++ echo Ready to 'go!' Please point your browser to: http://0.0.0.0:8080
                0|mm       | ++ awk -F: '{print $4}'
                0|mm       | + port=8080
                0|mm       | + echo 'Starting chromium browser now, have patience, it takes a minute'
                0|mm       | + '[' Linux '!=' Darwin ']'
                0|mm       | + tee
                0|mm       | ++ which chromium-browser
                0|mm       | + '[' /usr/bin/chromium-browser '!=' '' ']'
                0|mm       | + chromium-browser -noerrdialogs -kiosk -start_maximized --disable-infobars --app=http://localhost:8080 --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors
                • E Offline
                  ember1205 @sdetweil
                  I’m seeing a discrepancy where on boot it’s collecting xorg= blank versus xorg=755 on a stop/start after boot.
                    sdetweil @ember1205
                    @ember1205 yes… I see that too…
                    • E Offline
                      ember1205 @sdetweil
                      It almost seems like the X desktop isn’t fully initialized when the pgrep command executes and it isn’t collecting info on the process as a result. The restart NEVER happens until X is fully initialized which means that it -can- collect info on the process from a restart or stop/start.
                        sdetweil @ember1205
                        @ember1205 yes. I am looking for a resolution…
                        • 1 / 5
