    Autostarts but doesn't run, will run on restart
    47 Posts 3 Posters 23.3k Views 3 Watching
    • E Offline
      ember1205 @sdetweil
      I removed the check I was running that was ensuring it would start correctly and put in the line you asked. I believe the log info you want is this:
      0|mm       | + '[' -f ./untrack-css.sh ']'
      0|mm       | + grep docker /proc/1/cgroup -qa
      0|mm       | + '[' -z :0 ']'
      0|mm       | ++ uname -m
      0|mm       | + arch=armv7l
      0|mm       | + false=false
      0|mm       | ++ grep -i serveronly:
      0|mm       | ++ awk -F: '{print tolower($2)}'
      0|mm       | ++ tr -d ',"'\''\r'
      0|mm       | ++ grep -v '^[[:blank:]]*//' config/config.js
      0|mm       | ++ sed -e 's/^[[:space:]]*//'
      0|mm       | + serveronly=local
      0|mm       | + xprop -root
      0|mm       | xprop:  unable to open display ':0'
      0|mm       | ++ pgrep Xorg
      0|mm       | + xorg=
      0|mm       | + '[' . == . ']'
      0|mm       | ++ pgrep X
      0|mm       | + xorg=
      0|mm       | ++ uname
      0|mm       | + mac=Linux
      0|mm       | + '[' local. '!=' false. -o armv7l == armv6l ']'
      0|mm       | + '[' local. == true. ']'
      0|mm       | + '[' . == . -a Linux '!=' Darwin ']'
      0|mm       | + node serveronly
      Here’s the rest that goes with it “just in case”:
      PM2        | 2022-05-11T08:48:46: PM2 log: PM2 successfully stopped
      PM2        | 2022-05-11T08:49:03: PM2 log: ===============================================================================
      PM2        | 2022-05-11T08:49:03: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
      PM2        | 2022-05-11T08:49:03: PM2 log: Time                 : Wed May 11 2022 08:49:03 GMT-0400 (Eastern Daylight Time)
      PM2        | 2022-05-11T08:49:03: PM2 log: PM2 version          : 4.4.1
      PM2        | 2022-05-11T08:49:03: PM2 log: Node.js version      : 16.15.0
      PM2        | 2022-05-11T08:49:03: PM2 log: Current arch         : arm
      PM2        | 2022-05-11T08:49:03: PM2 log: PM2 home             : /home/pi/.pm2
      PM2        | 2022-05-11T08:49:03: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
      PM2        | 2022-05-11T08:49:03: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
      PM2        | 2022-05-11T08:49:03: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
      PM2        | 2022-05-11T08:49:03: PM2 log: Application log path : /home/pi/.pm2/logs
      PM2        | 2022-05-11T08:49:03: PM2 log: Worker Interval      : 30000
      PM2        | 2022-05-11T08:49:03: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
      PM2        | 2022-05-11T08:49:03: PM2 log: Concurrent actions   : 2
      PM2        | 2022-05-11T08:49:03: PM2 log: SIGTERM timeout      : 1600
      PM2        | 2022-05-11T08:49:04: PM2 log: App [mm:0] starting in -fork mode-
      PM2        | 2022-05-11T08:49:04: PM2 log: App [mm:0] online
      0|mm       |
      0|mm       | > magicmirror@2.13.0 start
      0|mm       | > ./run-start.sh
      0|mm       |
      0|mm       | [2022-05-11 08:49:14.433] [LOG]    Starting MagicMirror: v2.13.0
      0|mm       | [2022-05-11 08:49:14.450] [LOG]    Loading config ...
      0|mm       | [2022-05-11 08:49:14.465] [LOG]    Loading module helpers ...
      0|mm       | [2022-05-11 08:49:15.909] [LOG]    Initializing new module helper ...
      0|mm       | [2022-05-11 08:49:15.914] [LOG]    Module helper loaded: MMM-ImagesPhotos
      0|mm       | [2022-05-11 08:49:15.923] [LOG]    No helper found for module: alert.
      0|mm       | [2022-05-11 08:49:16.037] [LOG]    Initializing new module helper ...
      0|mm       | [2022-05-11 08:49:16.040] [LOG]    Module helper loaded: updatenotification
      0|mm       | [2022-05-11 08:49:16.044] [LOG]    No helper found for module: clock.
      0|mm       | [2022-05-11 08:49:16.351] [LOG]    Initializing new module helper ...
      0|mm       | [2022-05-11 08:49:16.353] [LOG]    Module helper loaded: calendar
      0|mm       | [2022-05-11 08:49:16.401] [LOG]    No helper found for module: currentweather.
      0|mm       | [2022-05-11 08:49:16.576] [LOG]    No helper found for module: weatherforecast.
      0|mm       | [2022-05-11 08:49:16.578] [LOG]    All module helpers loaded.
      0|mm       | [2022-05-11 08:49:18.093] [LOG]    Starting server on port 8080 ...
      0|mm       | [2022-05-11 08:49:18.123] [LOG]    Server started ...
      0|mm       | [2022-05-11 08:49:18.126] [LOG]    Connecting socket for: MMM-ImagesPhotos
      0|mm       | [2022-05-11 08:49:18.127] [LOG]    Starting node helper for: MMM-ImagesPhotos
      0|mm       | [2022-05-11 08:49:18.130] [LOG]    Connecting socket for: updatenotification
      0|mm       | [2022-05-11 08:49:18.132] [LOG]    Connecting socket for: calendar
      0|mm       | [2022-05-11 08:49:18.134] [LOG]    Starting node helper for: calendar
      0|mm       | [2022-05-11 08:49:18.135] [LOG]    Sockets connected & modules started ...
      0|mm       | [2022-05-11 08:49:18.137] [LOG]
      0|mm       | Ready to go! Please point your browser to: http://0.0.0.0:8080
        sdetweil @ember1205
        @ember1205 said in Autostarts but doesn't run, will run on restart:
        0|mm | xprop: unable to open display ‘:0’
        thanks… x not up yet…
        weird, never seen this on any other system pi otherwise…
        I have 3 pi3, 2 pi4, pi 0w and pi02w and jetson nano, odroid, chromebox, plus desktops…
        i’ll add another environment variable check
        u add it to the mm.sh used to launch…
        let me test it…
        thanks for your help
        • E Offline
          ember1205 @sdetweil
          Happy to have broken it. Again. lol
            sdetweil @ember1205
            @ember1205 ok, do this
            curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/test/run-start.sh >run-start.sh
            edit the MagicMirror/installers/mm.sh
            add a line before the npm start
            export wait_for_x=1
            (or true, or ANYTHING)
            the value can be anything
            edit the run-start.sh and add the -x on the 1st line again
            do the pm2 flush
            pm2 restart
            just to test
            then do the reboot test
            • E Offline
              ember1205 @sdetweil
              @sdetweil said in Autostarts but doesn't run, will run on restart:
              export wait_for_x=1
              That isn’t the mm.sh that my system launches from, though… Mine is ~/mm.sh
              Does the one you’re referencing get called from one of the other scripts?
                sdetweil @ember1205
                @ember1205 whatever script…
                if you used my setup script it uses the one already in installers
                • E Offline
                  ember1205 @sdetweil
                  Ok… Modified the ~/mm.sh script
                  pm2 restart mm failed to start Chromium correctly - landed on the Chrome Desktop.
                  Purged the config directory and started mm without issue.
                  Restarted the mirror and everything came up clean multiple times, but there is clearly still something weird happening with Chromium in that I have to continue wiping the config directory before it will start up correctly.
                    sdetweil @ember1205
                    @ember1205 the new script wipes the config folder already
                    E 2 Replies Last reply Reply Quote 0
                    • E Offline
                      ember1205 @sdetweil
                      Whatever it’s doing, it isn’t doing it correctly. “pm2 restart mm” lands me on the Chrome Desktop every time. I have to wipe the config folder by hand.
                      • E Offline
                        ember1205 @sdetweil
                        Its trying to wipe a non-existent directory
                        0|mm  | + rm -rf /home/pi/.config/chromium-browser
                          sdetweil @ember1205
                          @ember1205 ah. I ‘assumed’ folder name matched executable…doah…
                          • E Offline
                            ember1205 @sdetweil
                            cd ~
                            rm -rf .config/chromium
                            rm -rf .config/electron
                            This was what you had mentioned earlier in the thread and worked, and it’s what I built my config wipe based on.
                              sdetweil @ember1205
                              @ember1205 do the curl again
                              • E Offline
                                ember1205 @sdetweil
                                Seems to be working reliably. Even why I simply do a “shutdown now” without any of my shutdown process items, it starts up correctly.
                                  sdetweil @ember1205
                                  @ember1205 cool… thanks for the feedback…
                                  i merged the changes into the master branch for all updates from now on
                                  • E Offline
                                    ember1205 @sdetweil
                                    Now I have to find something else to break… sigh… :)
                                      sdetweil @ember1205
                                      @ember1205 thanks!.. this exposed another problem , using the script on an ubuntu system it opened the MM page in the running chrome instance and THEN DIDN’T WAIT… so the script ‘failed’ and pm2 restarted it , over and over and over…
                                      So, i just fixed THAT too… (didn’t break the prior! lol)
                                      • E Offline
                                        ember1205 @sdetweil
                                        As long as you got it all fixed, then it was a good day!
                                        • 2 / 3
