    Autostarts but doesn't run, will run on restart
    47 Posts 3 Posters 23.3k Views 3 Watching
      sdetweil @ember1205
      @ember1205 yes… i am looking for a test that works if the system is slow…
      i added the rm of ./config folder and my pi 0 now comes up instead of the chrome desktop
      which was random before…
              if [ $(which $b). != '.' ]; then
                   rm -rf ~/.config/$b 2>/dev/null   # add this line
      • E Offline
        ember1205 @sdetweil
        @sdetweil said in Autostarts but doesn't run, will run on restart:
        … my pi 0 now comes up instead of the chrome desktop
        Not sure I’m following what this should mean?
          sdetweil @ember1205
          @ember1205 you had another problem where chrome comes up to the white screen w the icons. that is the chrome desktop.
          i added the delete of the config folder to the run start script to get it back to just MagicMirror
          • E Offline
            ember1205 @sdetweil
            Oh… now I follow.
              sdetweil @ember1205
              @ember1205 can u try this on the reboot problem
              add this
              xprop -root      # add this line
              xorg=$(pgrep Xorg)
              then do the reboot test with the debugging still turned on
              • E Offline
                ember1205 @sdetweil
                I removed the check I was running that was ensuring it would start correctly and put in the line you asked. I believe the log info you want is this:
                0|mm       | + '[' -f ./untrack-css.sh ']'
                0|mm       | + grep docker /proc/1/cgroup -qa
                0|mm       | + '[' -z :0 ']'
                0|mm       | ++ uname -m
                0|mm       | + arch=armv7l
                0|mm       | + false=false
                0|mm       | ++ grep -i serveronly:
                0|mm       | ++ awk -F: '{print tolower($2)}'
                0|mm       | ++ tr -d ',"'\''\r'
                0|mm       | ++ grep -v '^[[:blank:]]*//' config/config.js
                0|mm       | ++ sed -e 's/^[[:space:]]*//'
                0|mm       | + serveronly=local
                0|mm       | + xprop -root
                0|mm       | xprop:  unable to open display ':0'
                0|mm       | ++ pgrep Xorg
                0|mm       | + xorg=
                0|mm       | + '[' . == . ']'
                0|mm       | ++ pgrep X
                0|mm       | + xorg=
                0|mm       | ++ uname
                0|mm       | + mac=Linux
                0|mm       | + '[' local. '!=' false. -o armv7l == armv6l ']'
                0|mm       | + '[' local. == true. ']'
                0|mm       | + '[' . == . -a Linux '!=' Darwin ']'
                0|mm       | + node serveronly
                Here’s the rest that goes with it “just in case”:
                PM2        | 2022-05-11T08:48:46: PM2 log: PM2 successfully stopped
                PM2        | 2022-05-11T08:49:03: PM2 log: ===============================================================================
                PM2        | 2022-05-11T08:49:03: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                PM2        | 2022-05-11T08:49:03: PM2 log: Time                 : Wed May 11 2022 08:49:03 GMT-0400 (Eastern Daylight Time)
                PM2        | 2022-05-11T08:49:03: PM2 log: PM2 version          : 4.4.1
                PM2        | 2022-05-11T08:49:03: PM2 log: Node.js version      : 16.15.0
                PM2        | 2022-05-11T08:49:03: PM2 log: Current arch         : arm
                PM2        | 2022-05-11T08:49:03: PM2 log: PM2 home             : /home/pi/.pm2
                PM2        | 2022-05-11T08:49:03: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                PM2        | 2022-05-11T08:49:03: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                PM2        | 2022-05-11T08:49:03: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                PM2        | 2022-05-11T08:49:03: PM2 log: Application log path : /home/pi/.pm2/logs
                PM2        | 2022-05-11T08:49:03: PM2 log: Worker Interval      : 30000
                PM2        | 2022-05-11T08:49:03: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                PM2        | 2022-05-11T08:49:03: PM2 log: Concurrent actions   : 2
                PM2        | 2022-05-11T08:49:03: PM2 log: SIGTERM timeout      : 1600
                PM2        | 2022-05-11T08:49:04: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2022-05-11T08:49:04: PM2 log: App [mm:0] online
                0|mm       |
                0|mm       | > magicmirror@2.13.0 start
                0|mm       | > ./run-start.sh
                0|mm       |
                0|mm       | [2022-05-11 08:49:14.433] [LOG]    Starting MagicMirror: v2.13.0
                0|mm       | [2022-05-11 08:49:14.450] [LOG]    Loading config ...
                0|mm       | [2022-05-11 08:49:14.465] [LOG]    Loading module helpers ...
                0|mm       | [2022-05-11 08:49:15.909] [LOG]    Initializing new module helper ...
                0|mm       | [2022-05-11 08:49:15.914] [LOG]    Module helper loaded: MMM-ImagesPhotos
                0|mm       | [2022-05-11 08:49:15.923] [LOG]    No helper found for module: alert.
                0|mm       | [2022-05-11 08:49:16.037] [LOG]    Initializing new module helper ...
                0|mm       | [2022-05-11 08:49:16.040] [LOG]    Module helper loaded: updatenotification
                0|mm       | [2022-05-11 08:49:16.044] [LOG]    No helper found for module: clock.
                0|mm       | [2022-05-11 08:49:16.351] [LOG]    Initializing new module helper ...
                0|mm       | [2022-05-11 08:49:16.353] [LOG]    Module helper loaded: calendar
                0|mm       | [2022-05-11 08:49:16.401] [LOG]    No helper found for module: currentweather.
                0|mm       | [2022-05-11 08:49:16.576] [LOG]    No helper found for module: weatherforecast.
                0|mm       | [2022-05-11 08:49:16.578] [LOG]    All module helpers loaded.
                0|mm       | [2022-05-11 08:49:18.093] [LOG]    Starting server on port 8080 ...
                0|mm       | [2022-05-11 08:49:18.123] [LOG]    Server started ...
                0|mm       | [2022-05-11 08:49:18.126] [LOG]    Connecting socket for: MMM-ImagesPhotos
                0|mm       | [2022-05-11 08:49:18.127] [LOG]    Starting node helper for: MMM-ImagesPhotos
                0|mm       | [2022-05-11 08:49:18.130] [LOG]    Connecting socket for: updatenotification
                0|mm       | [2022-05-11 08:49:18.132] [LOG]    Connecting socket for: calendar
                0|mm       | [2022-05-11 08:49:18.134] [LOG]    Starting node helper for: calendar
                0|mm       | [2022-05-11 08:49:18.135] [LOG]    Sockets connected & modules started ...
                0|mm       | [2022-05-11 08:49:18.137] [LOG]
                0|mm       | Ready to go! Please point your browser to: http://0.0.0.0:8080
                  sdetweil @ember1205
                  @ember1205 said in Autostarts but doesn't run, will run on restart:
                  0|mm | xprop: unable to open display ‘:0’
                  thanks… x not up yet…
                  weird, never seen this on any other system pi otherwise…
                  I have 3 pi3, 2 pi4, pi 0w and pi02w and jetson nano, odroid, chromebox, plus desktops…
                  i’ll add another environment variable check
                  u add it to the mm.sh used to launch…
                  let me test it…
                  thanks for your help
                  • E Offline
                    ember1205 @sdetweil
                    Happy to have broken it. Again. lol
                      sdetweil @ember1205
                      @ember1205 ok, do this
                      curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/test/run-start.sh >run-start.sh
                      edit the MagicMirror/installers/mm.sh
                      add a line before the npm start
                      export wait_for_x=1
                      (or true, or ANYTHING)
                      the value can be anything
                      edit the run-start.sh and add the -x on the 1st line again
                      do the pm2 flush
                      pm2 restart
                      just to test
                      • E Offline
                        ember1205 @sdetweil
                        export wait_for_x=1
                        That isn’t the mm.sh that my system launches from, though… Mine is ~/mm.sh
                        Does the one you’re referencing get called from one of the other scripts?
                          sdetweil @ember1205
                          @ember1205 whatever script…
                          if you used my setup script it uses the one already in installers
                          • E Offline
                            ember1205 @sdetweil
                            Ok… Modified the ~/mm.sh script
                            pm2 restart mm failed to start Chromium correctly - landed on the Chrome Desktop.
                            Purged the config directory and started mm without issue.
                            Restarted the mirror and everything came up clean multiple times, but there is clearly still something weird happening with Chromium in that I have to continue wiping the config directory before it will start up correctly.
                              sdetweil @ember1205
                              @ember1205 the new script wipes the config folder already
                              E 2 Replies Last reply Reply Quote 0
                              • E Offline
                                ember1205 @sdetweil
                                Whatever it’s doing, it isn’t doing it correctly. “pm2 restart mm” lands me on the Chrome Desktop every time. I have to wipe the config folder by hand.
                                • E Offline
                                  ember1205 @sdetweil
                                  Its trying to wipe a non-existent directory
                                  0|mm  | + rm -rf /home/pi/.config/chromium-browser
                                    sdetweil @ember1205
                                    @ember1205 ah. I ‘assumed’ folder name matched executable…doah…
                                    • E Offline
                                      ember1205 @sdetweil
                                      cd ~
                                      rm -rf .config/chromium
                                      rm -rf .config/electron
                                      This was what you had mentioned earlier in the thread and worked, and it’s what I built my config wipe based on.
                                        sdetweil @ember1205
                                        @ember1205 do the curl again
                                        • E Offline
                                          ember1205 @sdetweil
                                          Seems to be working reliably. Even why I simply do a “shutdown now” without any of my shutdown process items, it starts up correctly.
                                            sdetweil @ember1205
                                            @ember1205 cool… thanks for the feedback…
                                            i merged the changes into the master branch for all updates from now on
                                            • 2 / 3
