    Autostarts but doesn't run, will run on restart
    47 Posts 3 Posters 23.8k Views 3 Watching
      sdetweil @ember1205
      @ember1205 people are constantly fiddling with stuff, you never know what you’re gonna get anymore.
      E 1 Reply Last reply
      • E
        ember1205 @sdetweil
        Would there be more value in coding in a check for to see if it’s Raspbian or possibly even bullseye and adding a two second sleep if there is?
        raspberry_pi=$(grep ID /etc/os-release | cut -f2 -d=)
        if [ "$raspberry_pi." == "raspbian" ] ; then
           sleep 2
        fi
        xorg=$(pgrep Xorg)
        Maybe there’s a better string to search for, but it might be a stop-gap that would help?
          sdetweil @ember1205
          @ember1205 i don’t think thats right… as we could have the same problem on any other system…
          • E
            ember1205 @sdetweil
            Correct syntax would need to be:
              raspberry_pi=$(grep ^ID= /etc/os-release | cut -f2 -d=)
               sleep 2
              fi
            The RPi 3B+ is a little slower to initialize on Bullseye versus Buster. Any time a device is running a slightly heavier OS and needs a little more time to finish booting up, I could see this occurring. The question is, do you solve it with a fix that impacts everyone (“sleep 2” or similar), test for particular OS/HW combo’s, or is there another process to look for that would better indicate when the system should be finished initializing?
            Right now, it looks for X and just “moves on” when it isn’t found and assumes some sort of mistake or something in the config. Great as a fail-safe, but creates a new occasional issue to be dealt with.
              sdetweil @ember1205
              @ember1205 that test is for when MM is running under docker (with no X running) but using the docker host’s xorg for viewing…
              • E
                ember1205 @sdetweil
                The test I’m referring to checks to see if X is running. If not, it moves on to test for Lubuntu. If that also fails, it assumes server only and moves on.
                I do recall seeing a specific Docker test at the very beginning of the script, but that’s a fair bit earlier than where I’ve added this check (which is right before the “pgrep Xorg” line).
                  sdetweil @ember1205
                  @ember1205 yes… i am looking for a test that works if the system is slow…
                  i added the rm of ./config folder and my pi 0 now comes up instead of the chrome desktop
                  which was random before…
                          if [ $(which $b). != '.' ]; then
                               rm -rf ~/.config/$b 2>/dev/null   # add this line
                  • E
                    ember1205 @sdetweil
                    @sdetweil said in Autostarts but doesn't run, will run on restart:
                    … my pi 0 now comes up instead of the chrome desktop
                    Not sure I’m following what this should mean?
                      sdetweil @ember1205
                      @ember1205 you had another problem where chrome comes up to the white screen w the icons. that is the chrome desktop.
                      i added the delete of the config folder to the run start script to get it back to just MagicMirror
                      • E
                        ember1205 @sdetweil
                        Oh… now I follow.
                          sdetweil @ember1205
                          @ember1205 can u try this on the reboot problem
                          add this
                          xprop -root      # add this line
                          xorg=$(pgrep Xorg)
                          then do the reboot test with the debugging still turned on
                          • E
                            ember1205 @sdetweil
                            I removed the check I was running that was ensuring it would start correctly and put in the line you asked. I believe the log info you want is this:
                            0|mm       | + '[' -f ./untrack-css.sh ']'
                            0|mm       | + grep docker /proc/1/cgroup -qa
                            0|mm       | + '[' -z :0 ']'
                            0|mm       | ++ uname -m
                            0|mm       | + arch=armv7l
                            0|mm       | + false=false
                            0|mm       | ++ grep -i serveronly:
                            0|mm       | ++ awk -F: '{print tolower($2)}'
                            0|mm       | ++ tr -d ',"'\''\r'
                            0|mm       | ++ grep -v '^[[:blank:]]*//' config/config.js
                            0|mm       | ++ sed -e 's/^[[:space:]]*//'
                            0|mm       | + serveronly=local
                            0|mm       | + xprop -root
                            0|mm       | xprop:  unable to open display ':0'
                            0|mm       | ++ pgrep Xorg
                            0|mm       | + xorg=
                            0|mm       | + '[' . == . ']'
                            0|mm       | ++ pgrep X
                            0|mm       | + xorg=
                            0|mm       | ++ uname
                            0|mm       | + mac=Linux
                            0|mm       | + '[' local. '!=' false. -o armv7l == armv6l ']'
                            0|mm       | + '[' local. == true. ']'
                            0|mm       | + '[' . == . -a Linux '!=' Darwin ']'
                            0|mm       | + node serveronly
                            Here’s the rest that goes with it “just in case”:
                            PM2        | 2022-05-11T08:48:46: PM2 log: PM2 successfully stopped
                            PM2        | 2022-05-11T08:49:03: PM2 log: ===============================================================================
                            PM2        | 2022-05-11T08:49:03: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                            PM2        | 2022-05-11T08:49:03: PM2 log: Time                 : Wed May 11 2022 08:49:03 GMT-0400 (Eastern Daylight Time)
                            PM2        | 2022-05-11T08:49:03: PM2 log: PM2 version          : 4.4.1
                            PM2        | 2022-05-11T08:49:03: PM2 log: Node.js version      : 16.15.0
                            PM2        | 2022-05-11T08:49:03: PM2 log: Current arch         : arm
                            PM2        | 2022-05-11T08:49:03: PM2 log: PM2 home             : /home/pi/.pm2
                            PM2        | 2022-05-11T08:49:03: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                            PM2        | 2022-05-11T08:49:03: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                            PM2        | 2022-05-11T08:49:03: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                            PM2        | 2022-05-11T08:49:03: PM2 log: Application log path : /home/pi/.pm2/logs
                            PM2        | 2022-05-11T08:49:03: PM2 log: Worker Interval      : 30000
                            PM2        | 2022-05-11T08:49:03: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                            PM2        | 2022-05-11T08:49:03: PM2 log: Concurrent actions   : 2
                            PM2        | 2022-05-11T08:49:03: PM2 log: SIGTERM timeout      : 1600
                            PM2        | 2022-05-11T08:49:04: PM2 log: App [mm:0] starting in -fork mode-
                            PM2        | 2022-05-11T08:49:04: PM2 log: App [mm:0] online
                            0|mm       |
                            0|mm       | > magicmirror@2.13.0 start
                            0|mm       | > ./run-start.sh
                            0|mm       |
                            0|mm       | [2022-05-11 08:49:14.433] [LOG]    Starting MagicMirror: v2.13.0
                            0|mm       | [2022-05-11 08:49:14.450] [LOG]    Loading config ...
                            0|mm       | [2022-05-11 08:49:14.465] [LOG]    Loading module helpers ...
                            0|mm       | [2022-05-11 08:49:15.909] [LOG]    Initializing new module helper ...
                            0|mm       | [2022-05-11 08:49:15.914] [LOG]    Module helper loaded: MMM-ImagesPhotos
                            0|mm       | [2022-05-11 08:49:15.923] [LOG]    No helper found for module: alert.
                            0|mm       | [2022-05-11 08:49:16.037] [LOG]    Initializing new module helper ...
                            0|mm       | [2022-05-11 08:49:16.040] [LOG]    Module helper loaded: updatenotification
                            0|mm       | [2022-05-11 08:49:16.044] [LOG]    No helper found for module: clock.
                            0|mm       | [2022-05-11 08:49:16.351] [LOG]    Initializing new module helper ...
                            0|mm       | [2022-05-11 08:49:16.353] [LOG]    Module helper loaded: calendar
                            0|mm       | [2022-05-11 08:49:16.401] [LOG]    No helper found for module: currentweather.
                            0|mm       | [2022-05-11 08:49:16.576] [LOG]    No helper found for module: weatherforecast.
                            0|mm       | [2022-05-11 08:49:16.578] [LOG]    All module helpers loaded.
                            0|mm       | [2022-05-11 08:49:18.093] [LOG]    Starting server on port 8080 ...
                            0|mm       | [2022-05-11 08:49:18.123] [LOG]    Server started ...
                            0|mm       | [2022-05-11 08:49:18.126] [LOG]    Connecting socket for: MMM-ImagesPhotos
                            0|mm       | [2022-05-11 08:49:18.127] [LOG]    Starting node helper for: MMM-ImagesPhotos
                            0|mm       | [2022-05-11 08:49:18.130] [LOG]    Connecting socket for: updatenotification
                            0|mm       | [2022-05-11 08:49:18.132] [LOG]    Connecting socket for: calendar
                            0|mm       | [2022-05-11 08:49:18.134] [LOG]    Starting node helper for: calendar
                            0|mm       | [2022-05-11 08:49:18.135] [LOG]    Sockets connected & modules started ...
                            0|mm       | [2022-05-11 08:49:18.137] [LOG]
                            0|mm       | Ready to go! Please point your browser to: http://0.0.0.0:8080
                              sdetweil @ember1205
                              @ember1205 said in Autostarts but doesn't run, will run on restart:
                              0|mm | xprop: unable to open display ‘:0’
                              thanks… x not up yet…
                              weird, never seen this on any other system pi otherwise…
                              I have 3 pi3, 2 pi4, pi 0w and pi02w and jetson nano, odroid, chromebox, plus desktops…
                              i’ll add another environment variable check
                              u add it to the mm.sh used to launch…
                              let me test it…
                              thanks for your help
                              • E
                                ember1205 @sdetweil
                                Happy to have broken it. Again. lol
                                  sdetweil @ember1205
                                  @ember1205 ok, do this
                                  curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/test/run-start.sh >run-start.sh
                                  edit the MagicMirror/installers/mm.sh
                                  add a line before the npm start
                                  export wait_for_x=1
                                  (or true, or ANYTHING)
                                  the value can be anything
                                  edit the run-start.sh and add the -x on the 1st line again
                                  do the pm2 flush
                                  pm2 restart
                                  just to test
                                  • E
                                    ember1205 @sdetweil
                                    export wait_for_x=1
                                    That isn’t the mm.sh that my system launches from, though… Mine is ~/mm.sh
                                    Does the one you’re referencing get called from one of the other scripts?
                                      sdetweil @ember1205
                                      @ember1205 whatever script…
                                      if you used my setup script it uses the one already in installers
                                      • E
                                        ember1205 @sdetweil
                                        Ok… Modified the ~/mm.sh script
                                        pm2 restart mm failed to start Chromium correctly - landed on the Chrome Desktop.
                                        Purged the config directory and started mm without issue.
                                        Restarted the mirror and everything came up clean multiple times, but there is clearly still something weird happening with Chromium in that I have to continue wiping the config directory before it will start up correctly.
                                          sdetweil @ember1205
                                          @ember1205 the new script wipes the config folder already
                                          E 2 Replies Last reply
                                          • E
                                            ember1205 @sdetweil
                                            Whatever it’s doing, it isn’t doing it correctly. “pm2 restart mm” lands me on the Chrome Desktop every time. I have to wipe the config folder by hand.
                                            • 2 / 3
