    MMM-Page-Selector: A page switcher that can set positions of modules
    94 Posts 14 Posters 104.2k Views 15 Watching
      m1scha
      Hi first of all thanks for this great module, Works great. I wanto to remotely change the pages which works with this commands:
      http://ip:8080/remote?action=NOTIFICATION&notification=PAGE_DOWN
      http://ip:8080/remote?action=NOTIFICATION&notification=PAGE_UP
      But if I want to go to a specific page it does noct work with this command:
      http://ip:8080/remote?action=NOTIFICATION&notification="SELECT_PAGE"&payload="0"
      Can somebody tell me whats wrong?
      • V Offline
        Veldrovive Module Developer @m1scha
        @m1scha
        Hello, glad you’re enjoying the module.
        I am assuming that your page has some name that is not "0".
        I haven’t extensively tested with magic mirror remote, but I imagine the issue is with setting payload to be a string. When it gets a string, MMM-Page-Selector assumes it is the name of the page, not a page index. If an integer is sent, it assumes it is a page index.
        I don’t know how remote works, but you might be able to use
        http://ip:8080/remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=0
        Or you could specify your page name as
        http://ip:8080/remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=“YOUR_PAGE_NAME”
          m1scha @Veldrovive
          @veldrovive said in MMM-Page-Selector: A page switcher that can set positions of modules:
          Hi, thanks for you reply.
          I tested this in several variations, but I get a sucess Message, but change of page.
          • V Offline
            @m1scha
            I checked out MMM-Remote-Control and it is just a problem with string representations.
            remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=0 sends the literal notification “SELECT_PAGE” including the quotes. A more correct request would be remote?action=NOTIFICATION&notification=SELECT_PAGE&payload=Main which would switch the the page called main.
            However, in order to support other modules, pages are 1 indexed by notification so to switch to the first page, you would send remote?action=NOTIFICATION&notification=SELECT_PAGE&payload=1
            Strings that are numbers are handled correctly by MMM-Page-Selector.
            • I Offline
              innovation @Veldrovive
              @veldrovive Hello! I want to use this module for
              1. An intro screen - only for 10 secs
              2. Move into screen 2 - stay there
              Can I only have one screen to have a time interval and the other doesn’t? If so how?
                Riaanh
                Good day @Veldrovive thanks for the brilliant work you have done on this, and your comments on this is really helpful.
                I have an issue to get this going, and been researching and trying for the past two days with no success. I even tried using some of the users on this thread’s config as posted here, and loaded the modules they refer to, but I always end up with a blank page once I load the portion for MMM-Page-Selector.
                As soon as I add this portion below, it only display a blank page, or if I comment it out, then the page will display again.
                			disabled: false,
                		        module: "MMM-Page-Selector",
                		        position: "top_bar",
                			        defaultPage: "Page1",
                		                displayTitle: true,
                			        selectPageNotif: ["SELECT_PAGE"],
                		                incrementPageNotif: ["PAGE_UP"],
                		                decrementPageNotif: ["PAGE_DOWN"],
                Any advice or even just guidance on where to look further would be greatly appreciated.
                  sdetweil @Riaanh
                  @Riaanh said in MMM-Page-Selector: A page switcher that can set positions of modules:
                  MMM-Page-Selector
                  can u show the messages from where u start MagicMirror
                  either npm start
                  or pm2
                  if using pm2,. then
                  pm2 logs --lines=100
                  will show the messages
                  blank screen is usually a missing library , see
                    Riaanh @sdetweil
                    @sdetweil said in MMM-Page-Selector: A page switcher that can set positions of modules:
                    0 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                    1 info using npm@7.5.2
                    2 info using node@v12.22.5
                    3 timing config:load:defaults Completed in 4ms
                    4 timing config:load:file:/usr/share/nodejs/npm/npmrc Completed in 7ms
                    5 timing config:load:builtin Completed in 8ms
                    6 timing config:load:cli Completed in 4ms
                    7 timing config:load:env Completed in 1ms
                    8 timing config:load:file:/home/pi/magicmirror/mounts/modules/.npmrc Completed in 1ms
                    9 timing config:load:project Completed in 3ms
                    10 timing config:load:file:/home/pi/.npmrc Completed in 0ms
                    11 timing config:load:user Completed in 0ms
                    12 timing config:load:file:/etc/npmrc Completed in 0ms
                    13 timing config:load:global Completed in 0ms
                    14 timing config:load:cafile Completed in 1ms
                    15 timing config:load:validate Completed in 1ms
                    16 timing config:load:setUserAgent Completed in 2ms
                    17 timing config:load:setEnvs Completed in 2ms
                    18 timing config:load Completed in 29ms
                    19 verbose npm-session 72db9025016605ec
                    20 timing npm:load Completed in 58ms
                    21 timing command:run-script Completed in 45ms
                    22 timing command:start Completed in 59ms
                    23 verbose stack Error: missing script: start
                    23 verbose stack     at runScript (/usr/share/nodejs/npm/lib/run-script.js:54:11)
                    24 verbose cwd /home/pi/magicmirror/mounts/modules
                    25 verbose Linux 5.10.92-v7l+
                    26 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                    27 verbose node v12.22.5
                    28 verbose npm  v7.5.2
                    29 error missing script: start
                    30 verbose exit 1
                    Thanks for responding, is this what you are referring to?
                      sdetweil @Riaanh
                      @Riaanh how do you start MagicMirror normally?
                        sdetweil @Riaanh
                        @Riaanh this looks like being started under docker
                        • 5 / 5
