    Default weather module not showing after MM update
    25 Posts 7 Posters 9.3k Views 7 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @01ZerosOnes01
      @01ZerosOnes01 I am just upgrading. Just one last check, see in the Developers window if there are any errors there. shit + ctrl + i
      0 1 Reply Last reply Reply Quote 0
        @01ZerosOnes01 I think there may be an issue with the api key for OpenWeatherMap.
        • 0 Offline
          01ZerosOnes01 @mumblebaj
          @mumblebaj I xxx out the last few digits
          • 0 Offline
            @mumblebaj If I enter shit + ctrl + i in the terminal nothing shows up but a dialog box with Cancel and OK
              @01ZerosOnes01 Hi. Not in the terminal from the browser window that displays the mirror. I have created an Openweathermap api key and I get an unauthorized error in the Developers window. I guess I have to wait for it to activate first. Once it is active I will see if I can spot anything.
              • 0 Offline
                @mumblebaj Okay this is what I get when I run shift + ctrl + i
                Load script: modules/default/weather/weather.js
                :8080/modules/default/weather/weather.js:159 Uncaught SyntaxError: Unexpected token .
                Jarhead96097J S B T 4 Replies Last reply Reply Quote 0
                • Jarhead96097J Offline
                  Jarhead96097 @01ZerosOnes01
                  @01ZerosOnes01 said in Default weather module not showing after MM update:
                  I’m receiving the same error after updating to 2.20.0. Here’s the text from the weather.js error line 159: " currentWeather: this.weatherProvider?.currentWeatherObject?.simpleClone() ?? null,(RED X)"
                  Jarhead96097
                  • 0 Offline
                    01ZerosOnes01 @Jarhead96097
                    @Jarhead96097 Thanks for your info. Hopefully someone can come up with the fix.
                      sdetweil @01ZerosOnes01
                      @01ZerosOnes01 @Jarhead96097
                      how did u upgrade,and from what version?
                      I don’t see any significant code change here this release…
                      Jarhead96097J 1 Reply Last reply Reply Quote 0
                      • 0 Offline
                        01ZerosOnes01
                        I keep the mirror updated so I am assuming it was updated from the last version.
                        I updated by first issuing git stash then git pull && npm install --only=prod --omit=dev
                        followed by git stash apply
                        All other default and third party modules work.
                        Thank for your help it is appreciated.
