    Newbie question OpenHab and MagicMirror
    6 Posts 4 Posters 1.7k Views 4 Watching
    • V Offline
      Vauxdvihl
      Hi friends,
      i have installed Openhab on the same system from the magic mirror (raspi).
      Now, trying to start the mm with “pm2 start 0” from the home directory or “npm start” from the MagicMirrror folder, the pi opens the Openhab Web
      Can please anybody help me?
      Sry for the newbie question?
      Thanks a lot
        sdetweil @Vauxdvihl
        @Vauxdvihl change the mm port number in config J’s
        both products are trying to use port 8080.
        change mm to 8090
        • BKeyportB Offline
          BKeyport Module Developer
          Really, out of habit, I move all my ‘web based’ software off the 80/8080 ports completely. Start at 60000 and work my way up from there.
            razserv2010
            I also have the same problem that it opens openhab web even though I changed the port of MM2
            Does anyone have a solution for this?
              sdetweil @razserv2010
              @razserv2010 show the top of config.js
              address:
              ipWhitelist:
                razserv2010 @sdetweil
                let config = {
                        address: "0.0.0.0",     // Address to listen on, can be:
                        port: 8888,
                        basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                        ipWhitelist: [],        // Set [] to allow all IP addresses
