    MMM-Strava ID Unauthorized
    Scheduled Pinned Locked Moved Health
    17 Posts 4 Posters 7.1k Views 4 Watching
    • BerkSmash1984B Offline
      BerkSmash1984 @BerkSmash1984
      @mumblebaj Any ideas here? Would really like to get this functional. Appreciate any help!
      • mumblebajM Offline
        mumblebaj Module Developer @BerkSmash1984
        @BerkSmash1984 Let’s trace all the required steps.
        • Have run npm install in the MMM-Strava folder?
        • Did you do the browser auth on the PI?
        • Does the tokens.json file exist in the MMM-Strava folder and does it have the required information in it? This should be created once the authorization step has been completed from the Browser on the RPi and should be populated with some token and user information.
        Other than checking that I am not sure what else you can check. Other than starting the process from scratch to re-install and re-auth I don’t know what else you can do.
        BerkSmash1984B 1 Reply Last reply Reply Quote 0
          BerkSmash1984 @mumblebaj
          @mumblebaj Thanks for the response.
          • yes npm install was run the MMM-Strave folder
          • yes I did the browser auth on the RPI as well
          • no, I do not see a tokens file in the MMM-Strava folder after attempting the authorization:
            @mumblebaj I did attempt a reinstall of the MMM-Strava module but can certainly do it again. Is best method to rm-rf the MMM-Strava modiue folder and then redo the steps listed in the Github for MMM-Strava?
              @BerkSmash1984 u can edit your posts… don’t have to leave pad text, wrong info, bad tag…
                BerkSmash1984 @sdetweil
                @sdetweil my bad, thanks! I corrected my post
                  sdetweil @BerkSmash1984
                  @BerkSmash1984 not bad, maybe you didn’t know. lol
                    BerkSmash1984
                    @mumblebaj just removed the MMM-Strava module and installed from scratch. Still seeing the same issue. Would you by chance be able to do any direct troubleshooting with me? I am on discord in the MM channel and can dm you in there, if you have any free time at any point.
                    Note: when I click the authorize button a the Stava auth site after being redirected there from my MM on the RPI, in Electron, I see this generated:
                    [03.05.2022 10:13.13.537] [ERROR] Whoops! There was an uncaught exception…
                    [03.05.2022 10:13.13.538] [ERROR] Error [ERR_HTTP_HEADERS_SENT]: Cannot set headers after they are sent to the client
                    at new NodeError (node:internal/errors:371:5)
                    at ServerResponse.setHeader (node:_http_outgoing:576:11)
                    at ServerResponse.header (/home/jberk1984/MagicMirror/node_modules/express/lib/response.js:776:10)
                    at ServerResponse.location (/home/jberk1984/MagicMirror/node_modules/express/lib/response.js:893:15)
                    at ServerResponse.redirect (/home/jberk1984/MagicMirror/node_modules/express/lib/response.js:931:18)
                    at /home/jberk1984/MagicMirror/modules/MMM-Strava/node_helper.js:185:10
                    at /home/jberk1984/MagicMirror/modules/MMM-Strava/node_helper.js:451:5
                    at node:fs:2122:7
                    at FSReqCallback.oncomplete (node:fs:188:23) {
                    code: ‘ERR_HTTP_HEADERS_SENT’
                    So the issue seems to be whatever is causing that. I never do see the token.js being generated after clicking the authorize button. My client and secret ID are correct in my config.js file (can’t tell you how many times I have checked to make sure)
                      @BerkSmash1984 said in MMM-Strava ID Unauthorized:
                      so, this error is typically caused by some code doing two sends for an incoming request
                      the module sets up a little server to receive and does a redirect response…
                      but this could be an async problem
                      start sending one response, continue while it runs and then fall into another send… oops…
                      I only made a cursory look at the code. i have done similar things in some of my coding here and on other platforms.
                      I don’t ‘see’ it, but there is a library in there too
                      this says it is handling a callback on request complete,
                      line 185 is in the handling of the token auth . but the stravea lib is calling back into the function (function (err, payload, limits) at line 176
                      so the node_helper called strava, who called us back at the function on line 185 ( (err, data) => { (err, data) => { ) which does a redirect… WHILE the strava request to get the auth token handler is still active…
                      			strava.oauth.getToken(authCode, function (err, payload, limits) {
                      				if (err) {
                      					console.error(err);
                      					res.redirect(`/${self.name}/auth/?error=${err}`);
                      					return;
                      				// Store tokens
                      				self.saveToken(clientId, payload.body, (err, data) => {    // line 185
                      					// redirect route
                      					res.redirect(`/${self.name}/auth/?status=success`);
                      line 451, is in the end of the saveFile() function, supposedly to save the tokens.json
                      	saveToken: function (clientId, token, cb) {
                      		var self = this;
                      		this.readTokens();
                      		// No token for clientId - delete existing
                      		if (clientId in this.tokens && !token) {
                      			delete this.tokens[clientId];
                      		// No clientId in tokens - create stub
                      		if (!(clientId in this.tokens) && token) {
                      			this.tokens[clientId] = {};
                      		// Add token for client
                      		if (token) {
                      			this.tokens[clientId].token = token;
                      		// Save tokens to file
                      		var json = JSON.stringify(this.tokens, null, 2);
                      		fs.writeFile(this.tokensFile, json, "utf8", function (error) {
                      			if (error && cb) {
                      				cb(error);
                      			if (cb) {
                      				cb(null, self.tokens);  // line 451  --- this calls back into the  ( (err, data) =>)  function
                        rmonteroc
                        @BerkSmash1984 did you ever fixed this issue?
                        I just had the same issue, and it turns out it was a permissions issue in the MagicMirror folder, I changed the permissions of the folder and re-authorized, it’s now working.
                        Best regards
