    calendar with recurring event
    11 Posts 2 Posters 4.9k Views 3 Watching
      sdetweil @jasondreher
      @jasondreher
      could u post on of the events from the ics file that demonstrates this?
      use the url in the cal in the browser,not will download the ics file. open it as a text file not just double click.
      BEGIN:VEVENT
      END: VEVENT
      change any personal info, don’t change anything else
        jasondreher @sdetweil
        I only changed the UID, looks like it started 9/12/22, repeats weekly till 10/12/22. (although some of that is a day off, but that is what some of the other forum items said)
        BEGIN:VEVENT
        DTSTART;TZID=America/Chicago:20220912T190000
        DTEND;TZID=America/Chicago:20220912T200000
        RRULE:FREQ=WEEKLY;WKST=SU;UNTIL=20221012T045959Z;BYDAY=MO
        DTSTAMP:20220927T001542Z
        UID:XXXXXXXXXXXXXXXXXXXX
        CREATED:20220901T144823Z
        DESCRIPTION:
        LAST-MODIFIED:20220913T001004Z
        SEQUENCE:1
        STATUS:CONFIRMED
        SUMMARY:TS Boot Camp
        TRANSP:OPAQUE
        END:VEVENT
          @jasondreher ok thx will review shortly.
          the day off bug has a fix in the next release ( Saturday), cal entries w BYDAY return junk
            @jasondreher ok, i don’t see a problem with 2.20 or upcoming 2.21 (with the byday fix) …
            do you have broadcastPastEvents:true? in the cal config?
            there is a bug there, that I introduced… it chops off maxEvents incorrectly (also fixed in 2.21, Sauturday)
            workaround is to increase maxEntries from 10 to 100 (or more) depending on how big the past years events are…
              I do not have broadcastPastEvents: true, in my config.
              I will update this weekend, add broadcastPastEvents: true, and see if that fixes anything, thanks.
                @jasondreher don’t NEED broadcastPastEvents, it was just a bug I introduced… which fixed a regression of another problem…
                want to run debug test…
                edit config.js and add ,“DEBUG”
                to the logLevel:
                attribute at the top of config.js
                then if using pm2, pm2 stop all
                then
                npm start >somefie.txt 2>&1
                run til cal appears
                ctrl-q to end
                send the somefile.txt to my email (I don’t share info )
                my same userid at gmail
                turn off debug
                  Wow, I cant find your email, I am sure its fairly obvious. Anyway I narrowed down the event that is not showing…
                  It looks all right, showing “Corrected startDate: Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)”
                  [27.09.2022 09:25.50.700] [DEBUG] start: Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.700] [DEBUG] end:: Mon Sep 12 2022 20:00:00 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.701] [DEBUG] duration: 3600000
                  [27.09.2022 09:25.50.701] [DEBUG] title: TS Boot Camp
                  [27.09.2022 09:25.50.701] [DEBUG] Search for recurring events between: Tue Sep 27 2022 09:25:50 GMT-0500 (Central Daylight Time) and Tue Sep 26 2023 23:59:59 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.705] [DEBUG] Title: TS Boot Camp, with dates: [“2022-10-03T00:00:00.000Z”,“2022-10-10T00:00:00.000Z”]
                  [27.09.2022 09:25.50.705] [DEBUG] event.recurrences: undefined
                  [27.09.2022 09:25.50.706] [DEBUG] recurring date is Sun Oct 02 2022 19:00:00 GMT-0500 (Central Daylight Time) offset is 300
                  [27.09.2022 09:25.50.706] [DEBUG] recurring date is Sun Oct 02 2022 19:00:00 GMT-0500 (Central Daylight Time) offset is 5 Hour is 19
                  [27.09.2022 09:25.50.706] [DEBUG] new recurring date2 is Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.706] [DEBUG] Corrected startDate: Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.707] [DEBUG] initial tz=America/Chicago
                  [27.09.2022 09:25.50.707] [DEBUG] corrected tz=America/Chicago
                  [27.09.2022 09:25.50.707] [DEBUG] start date/time=Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.707] [DEBUG] start offset=-300
                  [27.09.2022 09:25.50.707] [DEBUG] start date/time w tz =Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.708] [DEBUG] event date=Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.708] [DEBUG] event offset=-300 hour=19 event date=Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.708] [DEBUG] adjustHours=0
                  [27.09.2022 09:25.50.708] [DEBUG] duration: 3600000
                  [27.09.2022 09:25.50.708] [DEBUG] saving event: false
                  [27.09.2022 09:25.50.709] [DEBUG] recurring date is Sun Oct 09 2022 19:00:00 GMT-0500 (Central Daylight Time) offset is 300
                  [27.09.2022 09:25.50.709] [DEBUG] recurring date is Sun Oct 09 2022 19:00:00 GMT-0500 (Central Daylight Time) offset is 5 Hour is 19
                  [27.09.2022 09:25.50.709] [DEBUG] new recurring date2 is Mon Oct 10 2022 19:00:00 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.709] [DEBUG] Corrected startDate: Mon Oct 10 2022 19:00:00 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.709] [DEBUG] initial tz=America/Chicago
                  [27.09.2022 09:25.50.710] [DEBUG] corrected tz=America/Chicago
                  [27.09.2022 09:25.50.710] [DEBUG] start date/time=Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.710] [DEBUG] start offset=-300
                  [27.09.2022 09:25.50.710] [DEBUG] start date/time w tz =Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.711] [DEBUG] event date=Mon Oct 10 2022 19:00:00 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.711] [DEBUG] event offset=-300 hour=19 event date=Mon Oct 10 2022 19:00:00 GMT-0500 (Central Daylight Time)
                  [27.09.2022 09:25.50.711] [DEBUG] adjustHours=0
                  [27.09.2022 09:25.50.711] [DEBUG] duration: 3600000
                  [27.09.2022 09:25.50.711] [DEBUG] saving event: false
                  [27.09.2022 09:25.50.712] [DEBUG] Processing entry…
                  [27.09.2022 09:25.50.712] [DEBUG] Event:
                    @jasondreher
                    my id here
                    at gmail
                      @jasondreher and what shows on the calendar?
                      the 3rd should show, maybe 10th it is 2 weeks away.
                        I plan on updating this weekend and seeing what shows when this event comes up next, your help is greatly appreciated!!!
