    disable X11 lightdm
    8 Posts 2 Posters 869 Views 2 Watching
    • E Offline
      emadragon
      Raspian gnu/linux 11 bullseye
        sdetweil @emadragon
        @emadragon the desktop has a config panel under menu top left, preferences, display where you can do the rotate
        • E Offline
          emadragon @sdetweil
          @sdetweil yes, I have done, but now, when i start the mirror, I have lxde on the background…
          Is correct ?
            sdetweil @emadragon
            @emadragon said in disable X11 lightdm:
            i don’t know what you mean
            what is ‘start the mirror’? boot, or type a command, if command, what command
            how did you install mm? manual , or my script?
            what did you do to ‘start’ the mirror on boot if a manual install?
            • E Offline
              emadragon @sdetweil
              @sdetweil I used MM as in the Magic Mirror documentation, now, when Rasperry Boot, start Lxde, than start Magic Mirror
              How can i start only Magic Mirror ?
              It’s possible?
                sdetweil @emadragon
                @emadragon I don’t know…
                my scripts use the node process manager (pm2) so that its the same on every platform
                see
                the fixuppm2 script at the bottom of the page…
                then u would undo what the lxde setup was
                then its auto started on boot…
                but you can control it with the pm2 command
                pm2 status
                pm2 stop xx (or all)
                pm2 start xx (or all)
                pm2 restart xx
                output is captured to two logs
                pm2 logs --lines=nn
                (nn is some number, 15 by default)
                you can redirect that output to a file to view it if there issues
                during development and test, I don’t use pm2, I just
                npm start >somefile.txt 2>&1
                then it captures all the output to ~/MagicMirror/somefile.txt
                ctrl-q on the MM screen stops it
                ctrl-m minimizes
                once u have everything working , then reboot or pm2 start all
