    disable X11 lightdm
    8 Posts 2 Posters 1.0k Views 2 Watching
    • E Offline
      emadragon
      I have a problem, I had a magic mirror on RPI 3B+ I had to rotate the screen by X11 screen configuration cause dysplay rotate doesn’t work…
      Now, when I start the mirror, start X11 Desktop manager than Magic Mirror, can I disable the Desktop manager in the background and start only the mirror
        sdetweil @emadragon
        @emadragon no… MM uses a browser which requires the graphical desktop to display content
        which OS are you on?
        lsb_release -a
        will show you
        • E Offline
          emadragon
          Raspian gnu/linux 11 bullseye
            sdetweil @emadragon
            @emadragon the desktop has a config panel under menu top left, preferences, display where you can do the rotate
            • E Offline
              emadragon @sdetweil
              @sdetweil yes, I have done, but now, when i start the mirror, I have lxde on the background…
              Is correct ?
                sdetweil @emadragon
                @emadragon said in disable X11 lightdm:
                i don’t know what you mean
                what is ‘start the mirror’? boot, or type a command, if command, what command
                how did you install mm? manual , or my script?
                what did you do to ‘start’ the mirror on boot if a manual install?
                • E Offline
                  emadragon @sdetweil
                  @sdetweil I used MM as in the Magic Mirror documentation, now, when Rasperry Boot, start Lxde, than start Magic Mirror
                  How can i start only Magic Mirror ?
                  It’s possible?
                    sdetweil @emadragon
                    @emadragon I don’t know…
                    my scripts use the node process manager (pm2) so that its the same on every platform
                    see
                    the fixuppm2 script at the bottom of the page…
                    then u would undo what the lxde setup was
                    then its auto started on boot…
                    but you can control it with the pm2 command
                    pm2 status
                    pm2 stop xx (or all)
                    pm2 start xx (or all)
                    pm2 restart xx
                    output is captured to two logs
                    pm2 logs --lines=nn
                    (nn is some number, 15 by default)
                    you can redirect that output to a file to view it if there issues
                    during development and test, I don’t use pm2, I just
                    npm start >somefile.txt 2>&1
                    then it captures all the output to ~/MagicMirror/somefile.txt
                    ctrl-q on the MM screen stops it
                    ctrl-m minimizes
                    once u have everything working , then reboot or pm2 start all
