    MMM-Flights Not Working
    14 Posts 4 Posters 3.9k Views 4 Watching
      sdetweil @KI6UVE
      @KI6UVE can u open the developer window and look for any errors in the console tab, with flight in the filter field
      • K Offline
        KI6UVE @sdetweil
        Seems odd, but absolutely nothing comes up with “flight” in the filter field.
        There is this error without filtering:
        karsten13K S 2 Replies Last reply Reply Quote 0
        • karsten13K Offline
          karsten13 @KI6UVE
          @KI6UVE
          did you install the module?
          your config.js is missing a }
          laMin and laMax should be switched
            sdetweil @KI6UVE
            @KI6UVE well, there SHOULD be ‘something’ loading etc…
            this is what I see
            i did git clone
            then cd MMM-Flights
            then npm install
            I just copied the module sample config
            • K Offline
              KI6UVE @sdetweil
              I used the exact same install technique. Could you post your code section with the module above and below the flights module so I can see how it is supposed to be nested in the config file? The module author said I’m missing a { somewhere.
              Thanks!
                bicolorbore586 @KI6UVE
                @KI6UVE
                Your config.js should be as follows
                module: “MMM-Flights”,
                position: “middle_center”,
                laMin: 33.183537,
                laMax: 32.849596,
                loMin: -117.204895,
                loMax: -116.790161,
                Note the } without the comma closes off the config part. (With the comma, closes the module)
                  sdetweil @KI6UVE
                  @KI6UVE it was only in the paste above
                  Here is the section in my config.js file:
                  laMin: 33.183537,
                  laMax: 32.849596,
                  loMin: -117.204895,
                  loMax: -116.790161,
                  you would have had a fatal startup error otherwise…
                  did u npm install in the module folder?
                  your config looks ok
                  • K Offline
                    KI6UVE @sdetweil
                    @sdetweil said in MMM-Flights Not Working:
                    Got it working. Thanks to all!!
                      sdetweil @KI6UVE
                      @KI6UVE what was it?
                      • K Offline
                        KI6UVE @sdetweil
                        I was missing the } to close out the flights module.
                        My coordinates do not include the ocean, but my map extends the width of the entire screen to include areas outside my area of interest. Do you know if there is a way to constrain it to just the area of interest?
