    Default Calander - can't get it to work
    7 Posts 3 Posters 1.4k Views 3 Watching
      sdetweil @svencarree
      @svencarree if u copy/paste the url, you should get a file download not a calendar display.
      u want the ical format url, not the embed url
      • mattkabM Offline
        mattkab @svencarree
        @svencarree
        I got multiple google calendars to display, including subscribed calendars. Try using the two links here (I had more luck with the secret address, and just use that as the default) in settings:
          sdetweil @mattkab
          @mattkab correct those are the ical format urls.
          public and secret.
          the embed url is located above them
          mattkabM 1 Reply Last reply Reply Quote 1
          • mattkabM Offline
            mattkab @sdetweil
            @sdetweil I was just trying to be extra obvious and explicit for @svencarree :)
              sdetweil @mattkab
              @mattkab I thought your info was fabulous!
              I was just using your image to reconfirm the words I used in the prior post.
                svencarree @sdetweil
                Woowww I knew it had to be some kind of PEBCAK! Thanks, it was so simple.
                Thanks for answering all the newbie questions.
