    MM shuts down after an hour
    18 Posts 3 Posters 9.3k Views 3 Watching
      sdetweil @Lazershrimp
      @Lazershrimp how do you start mm?
      npm start
      pm2
      did u upgrade the base os?
      • L Offline
        Lazershrimp @sdetweil
        @sdetweil Yes, I use PM2 to start MM. If you by base OS mean RPi OS, then yes.
          @Lazershrimp can u minimize mm ctrl-m and use the preferences (top left menu)
          to see if blank screen was turned back on?
          or from a terminal or ssh window, run my screensaveroff script from
          next to the last thing listed on the page, copy/paste the one line
            jasondreher
            I had a similar issue, the screen would go black after an hour or so (never the login screen just always went black). On of my modules was not compatible with the upgrade. Once I removed that module all was well.
              sdetweil @jasondreher
              @jasondreher can u tell me about that module? I like to keep track of troubles users experience
                jasondreher @sdetweil
                https://github.com/scottcl88/MMM-DynamicWeather
                Once I removed this module I had no issues.
                  @jasondreher that module suffers from this
                  https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later?page=1
                  • L Offline
                    @sdetweil said in MM shuts down after an hour:
                    Thanks, I am now trying the screensaveroff script. Will have to wait for an hour to see if it works.
                    I have checked my modules for the package.json files, all good
                      @Lazershrimp you are not checking for package.json, except to apply the fix
                      the fix is to
                      npm install xxxx
                      where xxx is the missing library as found in the log error messages
                      • L Offline
                        the fix is to
                        npm install xxxx
                        This I don’t understand. You write in “fix for black screen in 2.16 and later” that some MM modules used libraries, which are now removed.
                        By navigating to the module folder and running “ls package.json”, I am checking whether the module contains this file or not, yes? If it does not, the fix is to install it by typing “npm init -y”
                        But since my modules all seem to contain the package.json, I’m guessing that this is not what causes my problem.
                        Or am I wrong?
