    Edit CSS of only one instance of module
    7 Posts 3 Posters 1.6k Views 3 Watching
    • O Offline
      OWL
      I have two instances of the weather module running and tried to differentiate with regions with .middle_center.weather but that doesn’t work at all and it still overlaps. If i just use .weather it works but on both instances. Can i add something in the config.js for the second instance to give it an id?
      S 3 Replies Last reply Reply Quote 0
        sdetweil @OWL
        @OWL yes, instead of using the classname, use the instanceID
        in custom.css
        #module_{#}_{modulename}
        you can ‘count’ the modules top down in config.js, starting at 0.
        Or you can use the developers console to discover the string
        #module_?_weather
          sdetweil @OWL
          @OWL in css the thing the left of the {, is called the selector clause
          it can contain all kinds of things and get very complex sometimes
          I use this one to help me remember or figure out a selector clause
          https://www.w3schools.com/cssref/css_selectors.php
          • O Offline
            OWL @sdetweil
            @sdetweil Very nice thank you!
              sdetweil @OWL
              @OWL one thing to note on using the ID if you change the module order in config.js , the id changes…
              bugsounetB 1 Reply Last reply Reply Quote 0
              • bugsounetB Offline
                bugsounet Banned @sdetweil
                @sdetweil maybe classes in module config can help ;)
                  sdetweil @bugsounet
                  @bugsounet yes maybe too
