Unsolved pm2 no longer launching MM
I had 2 versions of the PIR sensor module as one didn’t work, I don’t know if I ended up using the lite version or the other one.
some of the modules are saying they have old lockfiles (this is for the ISS module) or in the case of dad jokes it has an ERR! code eresolve.
Any ideas why the calendar extension hasn’t popped back up? It was calendar ext2 I was using I think.
@JMac said in pm2 no longer launching MM:
no idea… but one might look at the logs
@JMac ignore the lockfiles message…
modules shouldn’t ship lock files… (in my opinion)
Sam, scratch my last message, I was just about to turn everything off as it’s getting pretty late here.
used ctrl c to stop the MM so I could shutdown the pi and attack it another day.
pm2 restarted the MM and hey presto the mirror seems by and large back to normal.I’m away with work for the next 3 days but will have a proper butchers (look) when I’m back home.
Thank you so much for both your patience and help.
I had genuine fears I’d have to start the entire build (modules bit) again and I was lucky I got it up and running like I did in the first place.thank you!
Thought I’d drop in here rather than start a new thread, with this current setup pm2 stop mm in terminal no longer stops the mirror from relaunching after using shift+Q.
Any ideas how I stop the MM to allow me to shut the pi down safely for a brief time?
@JMac pm2’s JOB is to keep the apps it manages running. so if YOU stop it, or it crashes doesn’t matter , same job, restart the app.
to stop a managed app. you need to use the pm2 command
so, minimize the app, ctrl-m for mm
open a terminal window on the desktop, ctrl-alt-t, and typepm2 status
and get the name or number of the app you are interested in and then do
pm2 stop x
where x is the name or number
most Linux commands have help built in by convention
pm2 --help
i followed this to get my starting again
https://forum.magicmirror.builders/topic/10840/problems-with-starting-pm2-start-mm-sh/7
