    Calendar Stuck at Loading...
    11 Posts 2 Posters 3.4k Views 2 Watching
      bzowk @sdetweil
      Thanks - I restarted it, give it a couple to ensure it was loaded, and took this screenshot. Verified in MM logs that it had already retrieved and was broadcasting events at this point…
      Appreciate your help!
        bzowk @sdetweil
        Browser/MM was really sluggish when doing that (RasPi3) so wondered if it perhaps was still parsing events when the update hit which may restart the process. Added a line to config to set maximumNumberOfDays to 1 and extended the refresh x4 then restarted MM. This time, it’s only broadcasting 12 events, but still stuck on loading after ~5 minutes.
        Changed config back to Google ICS (which is a shared calendar that imports the M365 ICS) and got similar results as was broadcasting 10 but still showed “Loading…”. :(
          sdetweil @bzowk
          @bzowk and, what messages in the browser console?
            bzowk @sdetweil
            Hmm - guess that reply didn’t post. Here’s a screenshot…
              sdetweil @bzowk
              @bzowk sorry, didn’t see the pending post (I review all)
                sdetweil @bzowk
                @bzowk hm… can you disable the other modules and see what happens
                add
                disabled:true,
                after the module: line
                  bzowk @sdetweil
                  Well, I actually put it down for a while and when I came back to it it seems to be working. Think it was the number of events and it trying to receive / refresh them before it was done parsing. It’s showing things now - just not everything - so going to play a bit more with and hopefully I’m on the right track. Keep you updated
                  Thanks a ton for your help!
