    MMM-DHT-Sensor stopped working
    20 Posts 4 Posters 7.2k Views 4 Watching
    • ankonaskiff17A
      ankonaskiff17 @sdetweil
      @sdetweil Now if I had a magic wand I could wave and this ALT issue would go up in a puff of smoke that would be nice too.
        sdetweil @ankonaskiff17
        @ankonaskiff17 never ever tried it. the official keystroke is alt and spacebar
        ankonaskiff17A 1 Reply Last reply Reply Quote 0
        • ankonaskiff17A
          @sdetweil This is where ALT comes from. First one I built I did on my own with no guidance and I expect it is why you have seen other people saying ALT doesn’t work anymore. I can only work off the documentation. Documents said hit ALT key, I hit ALT key and it works.
            @ankonaskiff17 cool. never read that part of the doc.
            also says you can’t install over ssh, but it’s the ONLY way I install mm., ever
            • ankonaskiff17A
              ankonaskiff17
              I can build my digital picture frame without going though a bunch of gyrations and that was my goal so I’m content. 3 - 4 days ago that looked grim.
              Now to look into your comment about a server for all my pictures and see what that requires.
              Stuff I’m likely ignorant of at this moment I’m sure.
                @ankonaskiff17 i had a spare machine, installed linux 10 years ago… have a 5tb external drive with the pics and and a lot of other stuff…
                share via samba (windows file sharing)
                and mount that on the pi (line in /etc/fstab)
                ends up in /media/{username}/…configed_name
                then u can link (ln) to map in to a folder some other place with a new name…
                  Dracarys @ankonaskiff17
                  @ankonaskiff17 Yes sudo apt-get update and sudo apt-get upgrade. Other modules work again just the DHT wont work :(
                    Dracarys
                    Fixed it. Updating the magic mirror itself did the trick.
                    ankonaskiff17A J 3 Replies Last reply Reply Quote 0
                    • ankonaskiff17A
                      ankonaskiff17 @Dracarys
                      @Dracarys As in updating to 2.24.0?
                      Those are the best kind.
                      • ankonaskiff17A
                        @Dracarys I want to dig in to sensor projects myself. I looked at that DHT sensor and I think it is using SPI so maybe other sensors using same interface might be amenable to using module as a building block.
                          Jonae @Dracarys
                          @Dracarys mine is still broken, updated MM to version 2.24.0 and still not working. Any solution?
                          • ankonaskiff17A
                            ankonaskiff17 @Jonae
                            @Jonae How many wires on sensor? 3 or 4? There are some DHT sensors with 4, some with 3.
                            If it is 4, and/or you know it is I2C ,try running ```sudo i2cdetect -y 1’‘’ .
                            Should spit you out an address 38.
                            If not I have a 3 wire sensor I can hook up and run through setup. My 3 wire sensor and DHT supposed to be about twins.
                              Jonae @ankonaskiff17
                              @ankonaskiff17
                              I have a 4 wire sensor, eunning sudo i2cdetect -y 1 i am getting an error thet could not open file. Anny sugestions?
