    Adjust individual table column widths?
    7 Posts 3 Posters 1.8k Views 3 Watching
      MMRIZE @jimmy_382837
      @jimmy_382837
      What is your config now for your result? I cannot guess your configs.
        jimmy_382837 @MMRIZE
        @MMRIZE my current config looks like this
        	module: "MMM-OpenWeatherForecast",
        		apikey: "xx",
        		latitude: 30.266666,
        		longitude: -97.733330,
        		requestDelay: 1500,
        		units: "imperial",
        		forecastHeaderText: "",
        		forecastLayout: "table",
        		hourlyForecastTableHeaderText: "",
        		hourlyForecastInterval: 3,
        		  extraCurrentConditions: {
        				highLowTemp: true,
        				precipitation: true,
        				sunrise: true,
        				sunset: true,
        				wind: false,
        				barometricPressure: false,
        				humidity: false,
        				dewPoint: false,
        				uvIndex: false,
        				visibility: false
        			hourlyExtras: {
        				wind: true,
        				humidity: true,
        				dewPoint: false,
        				uvIndex: false,
        				visibility: false
        		showDailyForecast: false,
        i am trying to edit the column widths on the hourly forecast table. i have tried all of the below in the custom.css, but none seem to work.
        .MMM-OpenWeatherForecast .forecast-container.hourly {
          table-layout: fixed;
        .MMM-OpenWeatherForecast .wrapper.table .forecast-container .forecast-item {
        .MMM-OpenWeatherForecast .wrapper.table .forecast-container .forecast-item .forecast-icon-container {
            width: 30px;
        ideally, i’d like to set a specific width for each column. e.g., the time is 30 px, conditions are 35 px, temperature is 45 px, and so on.
          sdetweil @jimmy_382837
          @jimmy_382837 did u see this from the link I posted…
          note that the TH for the columns MUST has a class
          OR
          you have to the the :nth-child() type selector
          tr:nth-child(1)
          would be the same element as the
          <th class="from"...>
          https://www.w3schools.com/cssref/css_selectors.php
            MMRIZE @sdetweil
            I haven’t examined the rendered HTML yet, but hardcoded style attributes in HTML code are prior than CSS.
            In case; You should modify source code of the module to change the result. (Or consider to use monkey-patch)
              MMRIZE @MMRIZE
              @jimmy_382837
              @MMRIZE said in Adjust individual table column widths?:
              The rendered result is not hard-coded, so you can adjust it with only CSS.
              This is an example. (Anyway, your config was not exactly matched with your previous screenshot…)
              .MMM-OpenWeatherMapForecast .module-content {
                width: inherit;
                /* I don't know why, but it was defined as 300px, might be an issue when you adjust the dimension. so have to reset */
              .MMM-OpenWeatherMapForecast,
              .MMM-OpenWeatherMapForecast .wrapper {
                width: 500px;
                /* give a custom width to a module */
              .MMM-OpenWeatherMapForecast .forecast-item .time {
                /* Some customizing for `time` cell for example.*/
                width: 200px;
                background-color: rgb(127 127 127/ 50%);
                color: white;
                font-weight: bold;
