    Adjust individual table column widths?
    7 Posts 3 Posters 2.1k Views 3 Watching
      jimmy_382837
      is there a way to adjust the individual column widths on a table in custom.css?
      i am using the MMM-openweathermapforecast, which is fantastic module.
      the hourly forecast is in a little table as pasted below, and i’m trying to adjust the individual column widths so that there’s no linebreak when the text exceeds the width.
      i tried table-layout: auto and table-layout: fixed with a width %, but both seem to either do nothing, or adjust all column widths to the same thing. is there a way to say col 1 should be X%, col 2 should be y%, and so on?
        sdetweil @jimmy_382837
        @jimmy_382837 I think it takes additional html, not just styles
        https://stackoverflow.com/questions/928849/setting-table-column-width
          MMRIZE @jimmy_382837
          @jimmy_382837
          What is your config now for your result? I cannot guess your configs.
            jimmy_382837 @MMRIZE
            @MMRIZE my current config looks like this
            	module: "MMM-OpenWeatherForecast",
            		apikey: "xx",
            		latitude: 30.266666,
            		longitude: -97.733330,
            		requestDelay: 1500,
            		units: "imperial",
            		forecastHeaderText: "",
            		forecastLayout: "table",
            		hourlyForecastTableHeaderText: "",
            		hourlyForecastInterval: 3,
            		  extraCurrentConditions: {
            				highLowTemp: true,
            				precipitation: true,
            				sunrise: true,
            				sunset: true,
            				wind: false,
            				barometricPressure: false,
            				humidity: false,
            				dewPoint: false,
            				uvIndex: false,
            				visibility: false
            			hourlyExtras: {
            				wind: true,
            				humidity: true,
            				dewPoint: false,
            				uvIndex: false,
            				visibility: false
            		showDailyForecast: false,
            i am trying to edit the column widths on the hourly forecast table. i have tried all of the below in the custom.css, but none seem to work.
            .MMM-OpenWeatherForecast .forecast-container.hourly {
              table-layout: fixed;
            .MMM-OpenWeatherForecast .wrapper.table .forecast-container .forecast-item {
            .MMM-OpenWeatherForecast .wrapper.table .forecast-container .forecast-item .forecast-icon-container {
                width: 30px;
            ideally, i’d like to set a specific width for each column. e.g., the time is 30 px, conditions are 35 px, temperature is 45 px, and so on.
              @jimmy_382837 did u see this from the link I posted…
              note that the TH for the columns MUST has a class
              OR
              you have to the the :nth-child() type selector
              tr:nth-child(1)
              would be the same element as the
              <th class="from"...>
              https://www.w3schools.com/cssref/css_selectors.php
                MMRIZE @sdetweil
                I haven’t examined the rendered HTML yet, but hardcoded style attributes in HTML code are prior than CSS.
                In case; You should modify source code of the module to change the result. (Or consider to use monkey-patch)
                  MMRIZE @MMRIZE
                  @jimmy_382837
                  @MMRIZE said in Adjust individual table column widths?:
                  The rendered result is not hard-coded, so you can adjust it with only CSS.
                  This is an example. (Anyway, your config was not exactly matched with your previous screenshot…)
                  .MMM-OpenWeatherMapForecast .module-content {
                    width: inherit;
                    /* I don't know why, but it was defined as 300px, might be an issue when you adjust the dimension. so have to reset */
                  .MMM-OpenWeatherMapForecast,
                  .MMM-OpenWeatherMapForecast .wrapper {
                    width: 500px;
                    /* give a custom width to a module */
                  .MMM-OpenWeatherMapForecast .forecast-item .time {
                    /* Some customizing for `time` cell for example.*/
                    width: 200px;
                    background-color: rgb(127 127 127/ 50%);
                    color: white;
                    font-weight: bold;
