    `GLIBCXX_3.4.26' not found (required by node)
    24 Posts 4 Posters 27.3k Views 4 Watching
      sdetweil @matt216
      @matt216 please use my upgrade script, with force instead of apply
      I added support for the latest version and the new node
        matt216 @sdetweil
        @sdetweil said in `GLIBCXX_3.4.26' not found (required by node):
        Thanks. What do you mean with force, instead of apply?
          matt216 @sdetweil
          @sdetweil Thanks. What do you mean with force instead of apply?
            sdetweil @matt216
            @matt216
            the upgrade command is
            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
            change the word apply to force
              matt216 @sdetweil
              @sdetweil Thank you. It currently can’t upgrade as I have 2 electron node processes running. killall node and the processes start again with a different PID. Can’t seem to stop electron!
                sdetweil @matt216
                @matt216 pm2 stop all
                pm2’s JOB is to KEEP the monitored apps running… you kill it, and then pm2 restarts…
                pm2 status
                will show you all the things being managed
                  matt216 @sdetweil
                  @sdetweil Ah but any pm2 command gives me the error `GLIBCXX_3.4.26’ not found I originally mentioned.
                    sdetweil @matt216
                    @matt216 reboot… pm2 will fail to launch then upgrade again …
                    then pm2 should work
                      matt216 @sdetweil
                      @sdetweil Unfortunately not. After reboot 2 electron processes preventing the upgrade-script from completing and pm2 commands fail without GLIBCXX version.
                      Appreciate the support here.
                        sdetweil @matt216
                        @matt216 ok, run this command string all one copy/paste and enter
                        sudo apt-get purge nodejs -y &&\
                        sudo rm -r /etc/apt/sources.list.d/nodesource.list &&\
                        sudo rm -r /etc/apt/keyrings/nodesource.gpg
