    `GLIBCXX_3.4.26' not found (required by node)
    24 Posts 4 Posters 28.5k Views 4 Watching
      matt216 @sdetweil
      @sdetweil Ah but any pm2 command gives me the error `GLIBCXX_3.4.26’ not found I originally mentioned.
        sdetweil @matt216
        @matt216 reboot… pm2 will fail to launch then upgrade again …
        then pm2 should work
          matt216 @sdetweil
          @sdetweil Unfortunately not. After reboot 2 electron processes preventing the upgrade-script from completing and pm2 commands fail without GLIBCXX version.
          Appreciate the support here.
            sdetweil @matt216
            @matt216 ok, run this command string all one copy/paste and enter
            sudo apt-get purge nodejs -y &&\
            sudo rm -r /etc/apt/sources.list.d/nodesource.list &&\
            sudo rm -r /etc/apt/keyrings/nodesource.gpg
              matt216 @sdetweil
              @sdetweil Progress, thank you. After purging and removing those files, I ran the install script. It completes, but during the npm install step I notice:
              E: Unable to correct problems, you have held broken packages.
              node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
              The script completes (but doesn’t give a npm version number, interestingly). I rebooted the pi and the mirror doesn’t start and pm2 command is not found.
                sdetweil @matt216
                @matt216 can u show me the output of
                lsb_release -a
                uname -a
                and you ran MY install script, correct?
                send me ~/install.log
                my same userid at gmail
                  matt216 @sdetweil
                  @sdetweil Your upgrade-script.sh yes, with force.
                  pi@magicmirror:~ $ lsb_release -a
                  No LSB modules are available.
                  Distributor ID: Raspbian
                  Description: Raspbian GNU/Linux 10 (buster)
                  Release: 10
                  Codename: buster
                  pi@magicmirror:~ $ uname -a
                  Linux magicmirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
                  No install.log in my home directory, sorry…
                    sdetweil @matt216
                    @matt216 ok, can you copy/paste, and execute this
                    bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)”
                      matt216 @sdetweil
                      @sdetweil Initially no such file or directory response so I removed the two sudo rm -r lines and ran again. Looked to complete successfully.
                      Rebooted.
                      Same state - mirror doesn’t start, pm2 commands not found.
                        matt216 @sdetweil
                        @sdetweil I need to pick the boy up from nursery now. Will return tomorrow. Thanks loads for the support.
                        Matt
                          matt216
                          Going for a full fresh install. Did some googling on GLIBCXX and it looks terrifying. Seems particular to raspberry pis. It seems quite fundamental to the OS and people don’t recommend tinkering with it at all. Only advice out there seems to be “rebuild”.
                            sdetweil @matt216
                            @matt216 yes, it’s a tough problem .
                            backup your mm config
                            https://github.com/sdetweil/MagicMirror-backup-restore
                              matt216 @sdetweil
                              @sdetweil config.js is backed-up regularly to an NFS mount from another machine. Will be a good recovery test :) Would be handy to figure out a way to restore all the modules.
                              Thanks for your assistance
                                sdetweil @matt216
                                @matt216 try my backup it saves the config the custom CSS and the URLs on GitHub of all of the modules you have installed
                                then on restore it uses the URLs to download the modules
                                check it out You can run them from GitHub without downloading onto your machine
                                puts everything into a little folder MM _ backup just three files
                                uses git tags to version the backup, and can push the GitHub if you want when you back up
                                and will save the extra files found in any module folder like Google or Spotify token files etc
                                  matt216 @sdetweil
                                  @sdetweil beautiful!
                                  • N Offline
                                    nnvv3344
                                    I was having this problem and could not figure it out. Here is the fix that worked right away for me…
                                    I uninstalled the version of Node that I had (which was 20) and I went back to install node js 18. It works after doing this
                                    W 1 Reply Last reply Reply Quote 1
                                    • W Offline
                                      wyovino @nnvv3344
                                      @nnvv3344 Unfortunately, the module MMM-Jast requires Node above 18, so I can do that.
