    npm start Problem
    16 Posts 2 Posters 5.6k Views 2 Watching
      sdetweil @Lockslay
      @Lockslay
      when was the last update to the system or MagicMirror?
      do
      nvm
      and
      n
      see if either respond… because node is in the local folder
      • L Offline
        Lockslay @sdetweil
        I did an apt update && apt upgrade today.
        Everything else did not work after a reboot.
        n
        and nvm
        command not found
          sdetweil @Lockslay
          @Lockslay
          little more debug
          uname -a
          lsb_release -a
          file /bin/bash
          file /usr/local/bin/node
          • L Offline
            Lockslay @sdetweil
            uname -a
            Linux smartmirror 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
            lsb_release -a
            No LSB modules are available.
            Distributor ID: Raspbian
            Description: Raspbian GNU/Linux 11 (bullseye)
            Release: 11
            Codename: bullseye
            file /bin/bash
            /bin/bash: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, BuildID[sha1]=f12e6d40fb262ad0037b6ec43162208b76d4da71, for GNU/Linux 3.2.0, stripped
              sdetweil @Lockslay
              @Lockslay note I added an additional line
              • L Offline
                Lockslay @sdetweil
                /usr/local/bin/node: ELF 64-bit LSB executable, x86-64, version 1 (GNU/Linux), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=d6aa6eb3474758fb4e621dac8db78891d4f4c0ef, for GNU/Linux 3.2.0, with debug_info, not stripped, too many notes (256)
                Sorry,
                I hadn’t seen the message
                  sdetweil @Lockslay
                  @Lockslay yeh, something installed the 64 bit v of node on your 32 bit system.
                  let’s try this
                  sudo apt-get remove nodejs
                  then
                   node - v
                  • L Offline
                    Lockslay @sdetweil
                    @sdetweil said in npm start Problem:
                    node - v
                    __
                    dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/man/man7’ not empty so not removed
                    dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/man/man5’ not empty so not removed
                    dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/man/man1’ not empty so not removed
                    dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/lib/utils’ not empty so not removed
                    dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/docs/output/using-npm’ not empty so not removed
                    dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/docs/output/configuring-npm’ not empty so not removed
                    dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/docs/output/commands’ not empty so not removed
                    dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/bin’ not empty so not removed
                    Processing triggers for man-db (2.9.4-2) …
                    stefan@smartmirror:~ $ node - v
                    -bash: /usr/local/bin/node: cannot execute binary file: Exec format error
                      sdetweil @Lockslay
                      @Lockslay ok, next
                      sudo rm -rf /usr/lib/node_modules/npm
                      sudo rm  /usr/local/bin/node
                      which node
                      hash -r
                      which node
                      node -v
                      • L Offline
                        Lockslay @sdetweil
                        @sdetweil Thanks for your help, isn’t it better to reinstall?
                        I just realised that the config is no longer there either
                          sdetweil @Lockslay
                          @Lockslay yes, probably.
                          flash SD card
                          boot
                          skip updates
                          use my script
                          if u back up w my other script
                          I will restore the config, css, and modules on top.of the new mm after install
