    npm start Problem
    16 Posts 2 Posters 6.9k Views 2 Watching
      sdetweil @Lockslay
      @Lockslay can you do
      node - v
      L 1 Reply Last reply
      • L
        Lockslay @sdetweil
        node - v
        -bash: /usr/local/bin/node: cannot execute binary file: Exec format error
          sdetweil @Lockslay
          @Lockslay
          when was the last update to the system or MagicMirror?
          do
          nvm
          and
          n
          see if either respond… because node is in the local folder
          • L
            Lockslay @sdetweil
            I did an apt update && apt upgrade today.
            Everything else did not work after a reboot.
            n
            and nvm
            command not found
              sdetweil @Lockslay
              @Lockslay
              little more debug
              uname -a
              lsb_release -a
              file /bin/bash
              file /usr/local/bin/node
              • L
                Lockslay @sdetweil
                uname -a
                Linux smartmirror 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                lsb_release -a
                No LSB modules are available.
                Distributor ID: Raspbian
                Description: Raspbian GNU/Linux 11 (bullseye)
                Release: 11
                Codename: bullseye
                file /bin/bash
                /bin/bash: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, BuildID[sha1]=f12e6d40fb262ad0037b6ec43162208b76d4da71, for GNU/Linux 3.2.0, stripped
                  sdetweil @Lockslay
                  @Lockslay note I added an additional line
                  • L
                    Lockslay @sdetweil
                    /usr/local/bin/node: ELF 64-bit LSB executable, x86-64, version 1 (GNU/Linux), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=d6aa6eb3474758fb4e621dac8db78891d4f4c0ef, for GNU/Linux 3.2.0, with debug_info, not stripped, too many notes (256)
                    Sorry,
                    I hadn’t seen the message
                      sdetweil @Lockslay
                      @Lockslay yeh, something installed the 64 bit v of node on your 32 bit system.
                      let’s try this
                      sudo apt-get remove nodejs
                      then
                       node - v
                      • L
                        Lockslay @sdetweil
                        @sdetweil said in npm start Problem:
                        node - v
                        __
                        dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/man/man7’ not empty so not removed
                        dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/man/man5’ not empty so not removed
                        dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/man/man1’ not empty so not removed
                        dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/lib/utils’ not empty so not removed
                        dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/docs/output/using-npm’ not empty so not removed
                        dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/docs/output/configuring-npm’ not empty so not removed
                        dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/docs/output/commands’ not empty so not removed
                        dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/bin’ not empty so not removed
                        Processing triggers for man-db (2.9.4-2) …
                        stefan@smartmirror:~ $ node - v
                          sdetweil @Lockslay
                          @Lockslay ok, next
                          sudo rm -rf /usr/lib/node_modules/npm
                          sudo rm  /usr/local/bin/node
                          which node
                          hash -r
                          which node
                          node -v
                          • L
                            Lockslay @sdetweil
                            @sdetweil Thanks for your help, isn’t it better to reinstall?
                            I just realised that the config is no longer there either
                              sdetweil @Lockslay
                              @Lockslay yes, probably.
                              flash SD card
                              boot
                              skip updates
                              use my script
                              if u back up w my other script
                              I will restore the config, css, and modules on top.of the new mm after install
