    Setting 2 default calendar modules; but weird represent
    11 Posts 2 Posters 3.2k Views 2 Watching
      sdetweil @1a2a3a
      @1a2a3a I don’t understand your words
      do u have 1 calendar module w 3 url entries
      or more than one calendar module w different settings?
      only the calendar module w a position: attribute will show the content
      1 1 Reply Last reply Reply Quote 0
      • 1 Offline
        1a2a3a @sdetweil
        @sdetweil we are talking about default cal ya? lets ignore cx here.
        i have 1 hidden with 2 url. <- this is fine to be hidden because i need the url to be passed on to the cx.
        have another 1 not hidden with 1 url. <- i cant change the date format for this with the code given unless i merge both cal (hidden and not hidden) url into 1 module. i only want this calendar to only show holiday and not the rest of the url.
        im going to paste my code here
          module: "MMM-CalendarExt3Agenda",
          title: "Today",
        	  locale: 'en-GB',
        	  instanceId: "basicCalendar",
        	  startDayIndex: 0,
        	  endDayIndex: 7,
        	  showMiniMonthCalendar: false,
        			broadcastPastEvents: true,
        			timeFormat: "absolute",
        			dateFormat: "Do MMM",
        					 url: "personal.ics",
        					url: "personal2.ics",
        					url: "soccer.ics",
        			 module: "MMM-CalendarExt3",
        			 position: "bottom_bar",
        			 title: "",
        			  mode: "weekly",
        			  locale: 'en-GB',
        			  weekIndex: 0,
        			  weeksInView: 4,
        			  maxEventLines: 6,
        			  fontSize: '18px',
        			  eventHeight: '13px',
        			  firstDayOfWeek: 0,
                      		  useMarquee: true,
        			  calendarSet: [],
        			header: "Singapore Holiday",
        			fulldayEventDateFormat: "Do. MMM",
        			maximumEntries: 10,
        					url: "https://www.officeholidays.com/ics-clean/singapore",
        					name: "Singapore Holiday",
        and this is my result. as you can see, managed to flip all the dates to d MM except the one on the right showing the holiday despite the code added in…
          sdetweil @1a2a3a
          @1a2a3a I think you have the wrong format requested
          Do MMM
          from the moment format specs page
          https://momentjscom.readthedocs.io/en/latest/moment/04-displaying/01-format/
          Day of Month	D	1 2 ... 30 31
          Do	1st 2nd ... 30th 31st
          DD	01 02 ... 30 31
          Do has th, nd,st…
          D has just the number
          DD has 2 digit number 0 prefixed
            sdetweil @1a2a3a
            @1a2a3a one other minor forum thing…
            alwasy warp config stuff in code block
            paste text in editor
            spare line above/below
            select all the text you pasted
            hit the </> button to wrap in code block… I added that for you this time
            • 1 Offline
              1a2a3a @sdetweil
              @sdetweil nothing works actually. so you see my code.
              the last paragraph on the default cal module where holiday ics is … no matter what format i choose for the date format, it will be stuck at Dec 25th. all i wanted is 25th Dec or 25 Dec.
                sdetweil @1a2a3a
                @1a2a3a ok, got it…
                the code is using this attribute
                 'fullDayEventDateFormat'
                you are suppling the second one
                case matters, every character
                so your config entry is ignored as it didn’t match, so it used the default
                • 1 Offline
                  1a2a3a @sdetweil
                  @sdetweil yes yes yes! thank you so much! spent my entire day on this :(
                    sdetweil @1a2a3a
                    @1a2a3a one of my modules ‘may’ help… doesn’t work for every module
                    see https://github.com/sdetweil/MMM-Config
                    it provides a form for you to fill out… no more config editing…
                    some modules do tricky things… EXT3/Agenda
                    but they can be augmented with a proper config definition and work perfectly.
                    I ship the schemas for modules that won’t be updated as a way to help older modules…
                    • 1 Offline
                      1a2a3a @sdetweil
                      @sdetweil I actually installed this but couldn’t get it to work. When I tried launching, the page looks gibberish to me and it doesn’t generate a new config file. Not sure if I’m doing something wrong.
                        sdetweil @1a2a3a
                        @1a2a3a can u send me some screen shots? either direct or to my mail , same userid at gmail…
                        and the schema3.json file from the module folder
