    Setting 2 default calendar modules; but weird represent
    11 Posts 2 Posters 3.5k Views 2 Watching
    • 1 Offline
      1a2a3a
      hi all
      coming from this post - https://forum.magicmirror.builders/topic/18211/help-with-date-format-mmm-calendarext3/15?page=2
      what i am trying to achieve here is that im running cx3 and cx3agenda and default calendar module.
      i was able to change date format in cx3 and cx3agenda from mm d to d mm using locale.
      now the issue is that i am not able to change the date format in the default calendar.
      i have 2 default calendar running with 1 hidden -
      default cal 1 (hidden): with personal ics and soccer ics.
      default cal 2 (shown): with holiday ics.
      reason being is that i do not want my default calendar to show all 3 ics. i want the default cal to only show holiday ics. cx3 and cx3agenda will show all 3 ics.
      problem here is that for the 2 default calendar setup, despite changing the timeFormat to absolute and dateFormat to desire, it does not work.
      this will only work once i revert to 1 default calendar. but that would mean my default calendar will show all 3 ics instead of just 1.
      are there any options available?
        sdetweil @1a2a3a
        @1a2a3a ok, got it…
        the code is using this attribute
         'fullDayEventDateFormat'
          fulldayEventDateFormat: "Do. MMM",
        you are suppling the second one
        case matters, every character
        so your config entry is ignored as it didn’t match, so it used the default
        1 1 Reply Last reply Reply Quote 0
          sdetweil @1a2a3a
          @1a2a3a I don’t understand your words
          do u have 1 calendar module w 3 url entries
          or more than one calendar module w different settings?
          only the calendar module w a position: attribute will show the content
          • 1 Offline
            1a2a3a @sdetweil
            @sdetweil we are talking about default cal ya? lets ignore cx here.
            i have 1 hidden with 2 url. <- this is fine to be hidden because i need the url to be passed on to the cx.
            have another 1 not hidden with 1 url. <- i cant change the date format for this with the code given unless i merge both cal (hidden and not hidden) url into 1 module. i only want this calendar to only show holiday and not the rest of the url.
            im going to paste my code here
              module: "MMM-CalendarExt3Agenda",
              title: "Today",
            	  locale: 'en-GB',
            	  instanceId: "basicCalendar",
            	  startDayIndex: 0,
            	  endDayIndex: 7,
            	  showMiniMonthCalendar: false,
            			broadcastPastEvents: true,
            			timeFormat: "absolute",
            			dateFormat: "Do MMM",
            					 url: "personal.ics",
            					url: "personal2.ics",
            					url: "soccer.ics",
            			 module: "MMM-CalendarExt3",
            			 position: "bottom_bar",
            			 title: "",
            			  mode: "weekly",
            			  locale: 'en-GB',
            			  weekIndex: 0,
            			  weeksInView: 4,
            			  maxEventLines: 6,
            			  fontSize: '18px',
            			  eventHeight: '13px',
            			  firstDayOfWeek: 0,
                          		  useMarquee: true,
            			  calendarSet: [],
            			header: "Singapore Holiday",
            			maximumEntries: 10,
            					url: "https://www.officeholidays.com/ics-clean/singapore",
            					name: "Singapore Holiday",
            and this is my result. as you can see, managed to flip all the dates to d MM except the one on the right showing the holiday despite the code added in…
              sdetweil @1a2a3a
              @1a2a3a I think you have the wrong format requested
              Do MMM
              from the moment format specs page
              https://momentjscom.readthedocs.io/en/latest/moment/04-displaying/01-format/
              Day of Month	D	1 2 ... 30 31
              Do	1st 2nd ... 30th 31st
              DD	01 02 ... 30 31
              Do has th, nd,st…
              D has just the number
              DD has 2 digit number 0 prefixed
                sdetweil @1a2a3a
                @1a2a3a one other minor forum thing…
                alwasy warp config stuff in code block
                paste text in editor
                spare line above/below
                select all the text you pasted
                hit the </> button to wrap in code block… I added that for you this time
                • 1 Offline
                  1a2a3a @sdetweil
                  @sdetweil nothing works actually. so you see my code.
                  the last paragraph on the default cal module where holiday ics is … no matter what format i choose for the date format, it will be stuck at Dec 25th. all i wanted is 25th Dec or 25 Dec.
                    sdetweil @1a2a3a
                    @1a2a3a ok, got it…
                    • 1 Offline
                      1a2a3a @sdetweil
                      @sdetweil yes yes yes! thank you so much! spent my entire day on this :(
                        sdetweil @1a2a3a
                        @1a2a3a one of my modules ‘may’ help… doesn’t work for every module
                        see https://github.com/sdetweil/MMM-Config
                        it provides a form for you to fill out… no more config editing…
                        some modules do tricky things… EXT3/Agenda
                        but they can be augmented with a proper config definition and work perfectly.
                        I ship the schemas for modules that won’t be updated as a way to help older modules…
                        • 1 Offline
                          1a2a3a @sdetweil
                          @sdetweil I actually installed this but couldn’t get it to work. When I tried launching, the page looks gibberish to me and it doesn’t generate a new config file. Not sure if I’m doing something wrong.
                            sdetweil @1a2a3a
                            @1a2a3a can u send me some screen shots? either direct or to my mail , same userid at gmail…
                            and the schema3.json file from the module folder
