MMM-Scenes2
Hi
I’m currently building my first mirror and experimenting with third-party modules.
For example MMM-Scenes2. I don’t know if the behaviour is correct. The scenes change as desired. After a certain time, the loop stops at the first scene. I want the cycle to be endless.
Is this behaviour intended? Do I need to adjust my configuration? Does anyone have any tips?
My configuration{ module: "MMM-Scenes2", position: 'bottom_bar', // Position of indicator config: { activeIndicator: " ^|^s", inactiveIndicator: " ^|^w", defaultEnter: { animation: "bounceInUp", /* "zoomInUp" */ }, defaultExit: { animation: "hinge", }, scenario: [ // `scenario` is REQUIRED { // First scene definition exit: [ { role: "role_date", animation: "bounceOutDown", }, { role: "role_germanclock", animation: "bounceOutDown", }, ], enter: ["role_alert", "role_notification", "role_clock", "role_calendar", "role_weather_current", "role_weather_forecast" ], }, { // Second scene definition exit: ["role_alert", "role_notification", "role_clock", "role_calendar", "role_weather_current", "role_weather_forecast" ], enter: [ { role: "role_date", animation: "zoomInUp", }, { role: "role_germanclock", animation: "zoomInUp", }, ], }, ] } }
@ric
Hmmm weird. It should restart unless you set thelife
as0
. Let me check. -
@ric
Can you send me your config? (eouia0819@gmail.com) (You may need to rename it as config.txt to attach it to the mail.) -
I have sent it
@ric has not reached yet.
Anyway,- did it stop after the first cycle?
- or did it work for a while, but after many cycles, did it suddenly stop? In that case, maybe some javascript error from this or other modules prevents the working. I need the front-end log error also.
it ran for several hours. now it seems to be blocked again.
Where can I find front-end log ? -
@ric
Install MMM-LogExt; that module would help deliver your front-end log to the backend log. If you are using pm2, you can see the log in~/.pm2/logs
or somewhere. (I’m not sure about your environment.)Or, you can run MM as debug mode; Instead of
pm2
(stoppm2
first), you can run your MM with debug mode bynpm run start:dev
, It will open MM with dev-console. Wait until your error happens. When you find the issue, See the console tab, there would be some suspicious messages or errors. -
@MMRIZE said in MMM-Scenes2:
@ric
or somewhere. (I’m not sure about your environment.)pm2 only captures backend log,
nothing captures front end log unless your LogExt is installed.
@MMRIZE
Thank you for your patience.
Now magicmirror is running in debug mode. So far it runs as it should.pi@magicmirror:~/MagicMirror $ npm run start:dev > magicmirror@2.25.0 start:dev > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js dev [13.12.2023 23:20.19.284] [LOG] Starting MagicMirror: v2.25.0 [13.12.2023 23:20.19.289] [LOG] Loading config ... [13.12.2023 23:20.19.293] [DEBUG] config template file not exists, no envsubst [13.12.2023 23:20.19.298] [LOG] Loading module helpers ... [13.12.2023 23:20.19.300] [LOG] No helper found for module: alert. [13.12.2023 23:20.19.325] [LOG] Initializing new module helper ... [13.12.2023 23:20.19.326] [LOG] Module helper loaded: updatenotification [13.12.2023 23:20.19.327] [LOG] No helper found for module: clock. [13.12.2023 23:20.19.399] [LOG] Initializing new module helper ... [13.12.2023 23:20.19.400] [LOG] Module helper loaded: MMM-text-clock [13.12.2023 23:20.19.627] [LOG] Initializing new module helper ... [13.12.2023 23:20.19.628] [LOG] Module helper loaded: calendar [13.12.2023 23:20.19.628] [LOG] No helper found for module: weather. [13.12.2023 23:20.19.643] [LOG] Initializing new module helper ... [13.12.2023 23:20.19.643] [LOG] Module helper loaded: MMM-Scenes2 [13.12.2023 23:20.19.643] [LOG] All module helpers loaded. [13.12.2023 23:20.19.651] [LOG] Starting server on port 8080 ... [13.12.2023 23:20.20.122] [LOG] Server started ... [13.12.2023 23:20.20.122] [LOG] Connecting socket for: updatenotification [13.12.2023 23:20.20.123] [LOG] Starting module helper: updatenotification [13.12.2023 23:20.20.123] [LOG] Connecting socket for: MMM-text-clock [13.12.2023 23:20.20.124] [LOG] Starting module helper: MMM-text-clock [13.12.2023 23:20.20.124] [LOG] Connecting socket for: calendar [13.12.2023 23:20.20.125] [LOG] Starting node helper for: calendar [13.12.2023 23:20.20.125] [LOG] Connecting socket for: MMM-Scenes2 [13.12.2023 23:20.20.425] [LOG] Sockets connected & modules started ... [13.12.2023 23:20.20.576] [LOG] Launching application. [5658:1213/232023.441362:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [5658:1213/232023.441848:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [5658:1213/232023.442182:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [5658:1213/232023.442478:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [5658:1213/232023.442771:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [5658:1213/232023.443062:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [5658:1213/232023.443344:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [5658:1213/232023.444865:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [5658:1213/232023.445175:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [5658:1213/232023.445471:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [5658:1213/232023.445828:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [5658:1213/232023.446143:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [5658:1213/232023.446421:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [5658:1213/232023.446686:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [13.12.2023 23:20.25.506] [LOG] Create new calendarfetcher for url: https://calendar.google.com/xxxxxxxxxxxxx/basic.ics - Interval: 3600000 [13.12.2023 23:20.25.672] [LOG] Create new calendarfetcher for url: https://onlinekalender.info/feiertage/schweiz.ics - Interval: 3600000 [13.12.2023 23:20.25.678] [INFO] Checking git for module: MMM-text-clock [13.12.2023 23:20.26.283] [INFO] Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics. [13.12.2023 23:20.26.344] [INFO] Checking git for module: MMM-Scenes2 [13.12.2023 23:20.26.553] [INFO] Checking git for module: MagicMirror [13.12.2023 23:20.28.191] [INFO] Calendar-Fetcher: Broadcasting 3 events from https://calendar.google.com/xxxxxxxxxxxxx/basic.ics. [5658:1213/232033.074222:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times! [5658:1213/232037.073720:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times! [5658:1213/232039.081014:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
I’ll let it run until something suspicious is output and then report back.
Thank you very much -
After several hours, the loop is blocked again.
But there is not much to see in the log.I have deleted the log ~/.pm2/logs and started it again. I can also post this afterwards.
pi@magicmirror:~/MagicMirror $ npm run start:dev > magicmirror@2.25.0 start:dev > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js dev [13.12.2023 23:55.22.997] [LOG] Starting MagicMirror: v2.25.0 [13.12.2023 23:55.23.002] [LOG] Loading config ... [13.12.2023 23:55.23.005] [DEBUG] config template file not exists, no envsubst [13.12.2023 23:55.23.010] [LOG] Loading module helpers ... [13.12.2023 23:55.23.012] [LOG] No helper found for module: alert. [13.12.2023 23:55.23.037] [LOG] Initializing new module helper ... [13.12.2023 23:55.23.038] [LOG] Module helper loaded: updatenotification [13.12.2023 23:55.23.039] [LOG] No helper found for module: clock. [13.12.2023 23:55.23.109] [LOG] Initializing new module helper ... [13.12.2023 23:55.23.110] [LOG] Module helper loaded: MMM-text-clock [13.12.2023 23:55.23.336] [LOG] Initializing new module helper ... [13.12.2023 23:55.23.336] [LOG] Module helper loaded: calendar [13.12.2023 23:55.23.337] [LOG] No helper found for module: weather. [13.12.2023 23:55.23.351] [LOG] Initializing new module helper ... [13.12.2023 23:55.23.352] [LOG] Module helper loaded: MMM-Scenes2 [13.12.2023 23:55.23.352] [LOG] All module helpers loaded. [13.12.2023 23:55.23.360] [LOG] Starting server on port 8080 ... [13.12.2023 23:55.23.755] [LOG] Server started ... [13.12.2023 23:55.23.756] [LOG] Connecting socket for: updatenotification [13.12.2023 23:55.23.757] [LOG] Starting module helper: updatenotification [13.12.2023 23:55.23.757] [LOG] Connecting socket for: MMM-text-clock [13.12.2023 23:55.23.758] [LOG] Starting module helper: MMM-text-clock [13.12.2023 23:55.23.758] [LOG] Connecting socket for: calendar [13.12.2023 23:55.23.759] [LOG] Starting node helper for: calendar [13.12.2023 23:55.23.759] [LOG] Connecting socket for: MMM-Scenes2 [13.12.2023 23:55.24.018] [LOG] Sockets connected & modules started ... [13.12.2023 23:55.24.126] [LOG] Launching application. [6004:1213/235525.303520:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [6004:1213/235525.304075:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [6004:1213/235525.304482:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [6004:1213/235525.304869:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [6004:1213/235525.305244:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [6004:1213/235525.305713:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [6004:1213/235525.306098:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [6004:1213/235525.307820:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [6004:1213/235525.308207:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [6004:1213/235525.308576:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [6004:1213/235525.308928:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [6004:1213/235525.309269:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [6004:1213/235525.309644:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [6004:1213/235525.310007:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2) [13.12.2023 23:55.27.245] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics - Interval: 3600000 [13.12.2023 23:55.27.382] [LOG] Create new calendarfetcher for url: https://onlinekalender.info/feiertage/schweiz.ics - Interval: 3600000 [13.12.2023 23:55.27.389] [INFO] Checking git for module: MMM-text-clock [13.12.2023 23:55.28.161] [INFO] Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics. [13.12.2023 23:55.28.195] [INFO] Checking git for module: MMM-Scenes2 [13.12.2023 23:55.28.616] [INFO] Checking git for module: MagicMirror [13.12.2023 23:55.30.046] [INFO] Calendar-Fetcher: Broadcasting 3 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics. [6004:1213/235535.089417:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times! [6004:1213/235537.084669:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times! [6004:1213/235540.087744:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times! [14.12.2023 00:55.28.404] [INFO] Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics. [14.12.2023 00:55.30.993] [INFO] Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics. [14.12.2023 01:55.28.639] [INFO] Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics. [14.12.2023 01:55.31.758] [INFO] Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics. [14.12.2023 02:55.28.843] [INFO] Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics. [14.12.2023 02:55.32.503] [INFO] Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics. [14.12.2023 03:55.29.056] [INFO] Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics. [14.12.2023 03:55.33.226] [INFO] Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics. [14.12.2023 04:55.29.269] [INFO] Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics. [14.12.2023 04:55.33.880] [INFO] Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics. [14.12.2023 05:55.29.449] [INFO] Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics. [14.12.2023 05:55.34.466] [INFO] Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics. [14.12.2023 06:55.29.648] [INFO] Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics. [14.12.2023 06:55.35.144] [INFO] Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics. [14.12.2023 07:55.29.860] [INFO] Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics. [14.12.2023 07:55.35.877] [INFO] Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
