    Merge conflict detected in your package.json
    19 Posts 3 Posters 4.8k Views 3 Watching
      sdetweil @docransom
      @docransom show the file
        docransom @sdetweil
        log file from error:
        0 verbose cli /usr/bin/node /usr/bin/npm
        1 info using npm@9.6.7
        2 info using node@v18.17.1
        3 timing npm:load:whichnode Completed in 4ms
        4 timing config:load:defaults Completed in 6ms
        5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 6ms
        6 timing config:load:builtin Completed in 7ms
        7 timing config:load:cli Completed in 6ms
        8 timing config:load:env Completed in 1ms
        9 timing config:load:file:/home/hamonation/MagicMirror/.npmrc Completed in 6ms
        10 timing config:load:project Completed in 8ms
        11 timing config:load:file:/home/hamonation/.npmrc Completed in 0ms
        12 timing config:load:user Completed in 2ms
        13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
        14 timing config:load:global Completed in 1ms
        15 timing config:load:setEnvs Completed in 3ms
        16 timing config:load Completed in 36ms
        17 timing npm:load:configload Completed in 36ms
        18 timing npm:load:mkdirpcache Completed in 1ms
        19 timing npm:load:mkdirplogs Completed in 2ms
        20 verbose title npm start
        21 verbose argv "start"
        22 timing npm:load:setTitle Completed in 3ms
        23 timing config:load:flatten Completed in 10ms
        24 timing npm:load:display Completed in 13ms
        25 verbose logfile logs-max:10 dir:/home/hamonation/.npm/_logs/2023-10-02T21_06_09_813Z-
        26 verbose logfile /home/hamonation/.npm/_logs/2023-10-02T21_06_09_813Z-debug-0.log
        27 timing npm:load:logFile Completed in 37ms
        28 timing npm:load:timers Completed in 0ms
        29 timing npm:load:configScope Completed in 0ms
        30 timing npm:load Completed in 99ms
        31 timing command:run-script Completed in 21ms
        32 timing command:start Completed in 77ms
        33 verbose stack JSONParseError: Unexpected token "<" (0x3C) in JSON at position 26 while parsing near "...me\": >
        33 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json-fast/lib/index.js:7:61
        33 verbose stack     at async RunScript.run (/usr/lib/node_modules/npm/lib/commands/run-script.js:73:19)
        33 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:89:5)
        34 verbose cwd /home/hamonation/MagicMirror
        35 verbose Linux 6.1.21-v8+
        36 verbose node v18.17.1
        37 verbose npm  v9.6.7
        38 error code EJSONPARSE
        39 error path /home/hamonation/MagicMirror/package.json
        40 error Merge conflict detected in your package.json.
        40 error
        40 error Please resolve the package.json conflict and retry.
        41 verbose exit 1
        42 timing npm Completed in 239ms
        43 verbose code 1
        44 error A complete log of this run can be found in: /home/hamonation/.npm/_logs/2023-10-02T21_06_09_813Z-debug-0>
        package.json:
                "name": "magicmirror",
        <<<<<<< HEAD
                "version": "2.25.0",
                "version": "2.23.0",
        >>>>>>> parent of e87f50e6 (Release 2.24.0 (#3141))
                "description": "The open source modular smart mirror platform.",
                "main": "js/electron.js",
                "scripts": {
                        "start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev",
                        "server": "node ./serveronly",
                        "install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
                        "install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
                        "install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=>
                        "install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --n>
                        "postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installati>
                        "test": "NODE_ENV=test jest -i --forceExit",
                        "test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit",
                        "test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
                        "test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
                        "test:unit": "NODE_ENV=test jest --selectProjects unit",
                        "test:prettier": "prettier . --check",
                        "test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'tr>
                        "test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --c>
                        "test:calendar": "node ./modules/default/calendar/debug.js",
                        "config:check": "node js/check_config.js",
                        "lint:prettier": "prettier . --write",
                        "lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'tr>
                        "lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --c>
                        "lint:staged": "lint-staged",
                        "prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed."
                "repository": {
                        "type": "git",
                        "url": "git+https://github.com/MichMich/MagicMirror.git"
                "keywords": [
                        "magic mirror",
                        "magicmirror",
                        "smart mirror",
                        "mirror UI",
                        "modular"
                "author": "Michael Teeuw",
                "contributors": [
                        "https://github.com/MichMich/MagicMirror/graphs/contributors"
                "license": "MIT",
                "bugs": {
                        "url": "https://github.com/MichMich/MagicMirror/issues"
                "homepage": "https://magicmirror.builders",
                "devDependencies": {
        <<<<<<< HEAD
                        "eslint-config-prettier": "^9.0.0",
                        "eslint-plugin-import": "^2.28.1",
                        "eslint-plugin-jest": "^27.4.2",
                        "eslint-plugin-jsdoc": "^46.8.2",
                        "eslint-plugin-prettier": "^5.0.0",
                        "express-basic-auth": "^1.2.1",
                        "husky": "^8.0.3",
                        "jest": "^29.7.0",
                        "jsdom": "^22.1.0",
                        "lint-staged": "^14.0.1",
                        "lodash": "^4.17.21",
                        "playwright": "^1.38.1",
                        "prettier": "^3.0.3",
                        "sinon": "^16.0.0",
                        "stylelint": "^15.10.3",
                        "stylelint-config-standard": "^34.0.0",
                        "stylelint-prettier": "^4.0.2",
                        "suncalc": "^1.9.0"
                "optionalDependencies": {
                        "electron": "^26.2.4"
                "dependencies": {
                        "colors": "^1.4.0",
                        "console-stamp": "^3.1.2",
                        "envsub": "^4.1.0",
                        "eslint": "^8.50.0",
                        "express": "^4.18.2",
                        "express-ipfilter": "^1.3.1",
                        "feedme": "^2.0.2",
                        "helmet": "^7.0.0",
                        "html-to-text": "^9.0.5",
                        "eslint-config-prettier": "^8.8.0",
                        "eslint-plugin-import": "^2.27.5",
                        "eslint-plugin-jest": "^27.2.1",
                        "eslint-plugin-jsdoc": "^40.1.0",
                        "eslint-plugin-prettier": "^4.2.1",
                        "husky": "^8.0.3",
                        "jest": "^29.5.0",
                        "jsdom": "^21.1.1",
                        "playwright": "^1.32.1",
                        "prettier": "^2.8.7",
                        "pretty-quick": "^3.1.3",
                        "sinon": "^15.0.2",
                        "stylelint": "^15.3.0",
                        "stylelint-config-standard": "^31.0.0",
                        "stylelint-prettier": "^3.0.0",
                        "suncalc": "^1.9.0"
                        "electron": "^22.3.4"
                "dependencies": {
                        "colors": "^1.4.0",
                        "console-stamp": "^3.1.1",
                        "digest-fetch": "^2.0.1",
                        "envsub": "^4.1.0",
                        "eslint": "^8.36.0",
                        "feedme": "^2.0.2",
                        "helmet": "^6.0.1",
                        "iconv-lite": "^0.6.3",
                        "luxon": "^1.28.1",
                        "module-alias": "^2.2.2",
                        "moment": "^2.29.4",
        <<<<<<< HEAD
                        "node-ical": "^0.16.1",
                        "socket.io": "^4.7.2"
                "lint-staged": {
                        "*": "prettier --write",
                        "*.js": "eslint",
                        "*.css": "stylelint"
                        "node-fetch": "^2.6.9",
                        "node-ical": "^0.16.0",
                        "socket.io": "^4.6.1"
                "_moduleAliases": {
                        "node_helper": "js/node_helper.js",
                        "logger": "js/logger.js"
                "engines": {
        <<<<<<< HEAD
                        "node": ">=18"
                        "node": ">=14"
          sdetweil @docransom
          @docransom thanks. weird
          see this
          https://docs.github.com/en/pull-requests/collaborating-with-pull-requests/addressing-merge-conflicts/resolving-a-merge-conflict-using-the-command-line
          but for you the simple explanation
          edit the package.json file
          find the line with ======
          delete that line thru the line with >>>>>>>>
          repeat til all are gone
          go back to top
          delete all lines with
          save the file
          git add package.json
          git commit -m " save new"
          the git commit may require you to identify yourself
          | updated
          git config --local user.name ??? <----your name
          git config --local user.email ??? <----your email
          • G Offline
            Guku @sdetweil
            @sdetweil Hi, so i had the same issue and after running the commands i get this
            MagicMirror $ git commit -m"save new"
            U package-lock.json
            error: Committing is not possible because you have unmerged files.
            hint: Fix them up in the work tree, and then use ‘git add/rm ’
            hint: as appropriate to mark resolution and make a commit.
              sdetweil @Guku
              @Guku i hate package-lock.json… should NEVER be shipped…
              its used in the test env to get the right level of code, but we have SO many platforms, that the lock file is garbage…
              anyhow
              git checkout package-lock.json
              • G Offline
                Guku @sdetweil
                @sdetweil just more errors…
                /MagicMirror $ git checkout package-lock.json
                error: path ‘package-lock.json’ is unmerged
                i just started fresh with version 2.25 few months ago and this is the 1st update, how are things go wrong so quickly? the old build i had for few years without and issue.
                  sdetweil @Guku
                  @Guku rm package-lock.json
                  to erase it
                  my upgrade script handles this for you
                  • G Offline
                    Guku @sdetweil
                    @sdetweil said in Merge conflict detected in your package.json:
                    ran your upgrade script and now see this
                    MagicMirror $ npm run server
                    npm ERR! code EJSONPARSE
                    npm ERR! JSON.parse Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3552 while parsing ‘{
                    npm ERR! JSON.parse “name”: “magicmirror”,
                    npm ERR! JSON.parse “version”: "2’
                    npm ERR! JSON.parse Failed to parse JSON data.
                    npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
                    npm ERR! A complete log of this run can be found in: /home/lolo/.npm/_logs/2024-01-01T18_11_41_122Z-debug-0.log
                      sdetweil @Guku
                      @Guku did you use apply?
                      can u look at package.json too?
                      • G Offline
                        Guku @sdetweil
                        @sdetweil i did use apply at the end and here the file
                        	"version": "2.26.0",
                        	"scripts": {
                        		"install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                        		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                        		"postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"",
                        		"test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*'",
                        		"test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
                        		"lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --fix",
                        		"lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
                        	"repository": {
                        		"type": "git",
                        	"keywords": [
                        		"magic mirror",
                        		"magicmirror",
                        		"smart mirror",
                        		"mirror UI",
                        		"modular"
                        	"contributors": [
                        	"license": "MIT",
                        	"bugs": {
                        		"@stylistic/eslint-plugin": "^1.5.1",
                        		"eslint-plugin-import": "^2.29.1",
                        		"eslint-plugin-jest": "^27.6.0",
                        		"eslint-plugin-jsdoc": "^46.9.1",
                        		"husky": "^8.0.3",
                        		"jest": "^29.7.0",
                        		"jsdom": "^23.0.1",
                        		"lint-staged": "^15.2.0",
                        		"playwright": "^1.40.1",
                        		"prettier": "^3.1.1",
                        		"sinon": "^17.0.1",
                        		"stylelint": "^16.1.0",
                        		"stylelint-config-standard": "^36.0.0",
                        		"stylelint-prettier": "^5.0.0",
                        		"suncalc": "^1.9.0"
                        		"electron": "^27.2.0"
                        	"dependencies": {
                        		"colors": "^1.4.0",
                        		"command-exists": "^1.2.9",
                        		"envsub": "^4.1.0",
                        		"eslint": "^8.56.0",
                        		"feedme": "^2.0.2",
                        		"helmet": "^7.1.0",
                        		"module-alias": "^2.2.3",
                        	"lint-staged": {
                        		"*.js": "eslint",
                        	"_moduleAliases": {
                        	"engines": {
                        		"node": ">=18"
                          sdetweil @Guku
                          @Guku weird… missing some of file
                          git checkout package.json
                            @Guku also, can u send me the ~/MagicMirror/installers/upgrade.log
                            same userid at gmail
                            • G Offline
                              Guku @sdetweil
                              @sdetweil ran the command and this is it
                              Updated 1 path from the index
                              sent email with upgrade log
                                sdetweil @Guku
                                @Guku now
                                npm start
                                  sdetweil @Guku
                                  @Guku I ran upgarde on my very old desktop, 2.8 to 2.26
                                  all ok
                                  • G Offline
                                    Guku @sdetweil
                                    @sdetweil now this
                                    npm run server
                                    magicmirror@2.26.0 server
                                    node ./serveronly
                                    [01.01.2024 13:52.17.327] [LOG] Starting MagicMirror: v2.26.0
                                    [01.01.2024 13:52.17.329] [LOG] Loading config …
                                    [01.01.2024 13:52.17.330] [DEBUG] config template file not exists, no envsubst
                                    [01.01.2024 13:52.17.332] [LOG] Loading module helpers …
                                    [01.01.2024 13:52.17.332] [LOG] No helper found for module: alert.
                                    [01.01.2024 13:52.17.336] [ERROR] Whoops! There was an uncaught exception…
                                    [01.01.2024 13:52.17.339] [ERROR] Error: Cannot find module ‘command-exists’
                                    Require stack:
                                    • /home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js
                                    • /home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js
                                    • /home/lolo/MagicMirror/js/app.js
                                    • /home/lolo/MagicMirror/serveronly/index.js
                                      at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
                                      at Module._resolveFilename (/home/lolo/MagicMirror/node_modules/module-alias/index.js:49:29)
                                      at Module._load (node:internal/modules/cjs/loader:901:27)
                                      at Module.require (node:internal/modules/cjs/loader:1115:19)
                                      at require (node:internal/modules/helpers:130:18)
                                      at Object. (/home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js:3:23)
                                      at Module._compile (node:internal/modules/cjs/loader:1241:14)
                                      at Module._extensions…js (node:internal/modules/cjs/loader:1295:10)
                                      at Module.load (node:internal/modules/cjs/loader:1091:32)
                                      at Module._load (node:internal/modules/cjs/loader:938:12)
                                      at Object. (/home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js:4:22)
                                      at Module.load (node:internal/modules/cjs/loader:1091:32) {
                                      code: ‘MODULE_NOT_FOUND’,
                                      requireStack: [
                                      ‘/home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js’,
                                      ‘/home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js’,
                                      ‘/home/lolo/MagicMirror/js/app.js’,
                                      ‘/home/lolo/MagicMirror/serveronly/index.js’
                                      [01.01.2024 13:52.17.339] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      [01.01.2024 13:52.17.339] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      sdetweil @Guku
                                      @Guku I’m guessing because of the merge conflict the install didn’t work
                                      do
                                      npm install
                                      then start again
                                      • G Offline
                                        Guku @sdetweil
                                        @sdetweil i think that finally did it!
                                        thank you so much for your help Sam!
