    Merge conflict detected in your package.json
    19 Posts 3 Posters 5.0k Views 3 Watching
    • G
      Guku @sdetweil
      @sdetweil Hi, so i had the same issue and after running the commands i get this
      MagicMirror $ git commit -m"save new"
      U package-lock.json
      error: Committing is not possible because you have unmerged files.
      hint: Fix them up in the work tree, and then use ‘git add/rm ’
      hint: as appropriate to mark resolution and make a commit.
        sdetweil @Guku
        @Guku i hate package-lock.json… should NEVER be shipped…
        its used in the test env to get the right level of code, but we have SO many platforms, that the lock file is garbage…
        anyhow
        git checkout package-lock.json
        G 1 Reply Last reply
        • G
          Guku @sdetweil
          @sdetweil just more errors…
          /MagicMirror $ git checkout package-lock.json
          error: path ‘package-lock.json’ is unmerged
          i just started fresh with version 2.25 few months ago and this is the 1st update, how are things go wrong so quickly? the old build i had for few years without and issue.
            sdetweil @Guku
            @Guku rm package-lock.json
            to erase it
            my upgrade script handles this for you
            • G
              Guku @sdetweil
              @sdetweil said in Merge conflict detected in your package.json:
              ran your upgrade script and now see this
              MagicMirror $ npm run server
              npm ERR! code EJSONPARSE
              npm ERR! JSON.parse Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3552 while parsing ‘{
              npm ERR! JSON.parse “name”: “magicmirror”,
              npm ERR! JSON.parse “version”: "2’
              npm ERR! JSON.parse Failed to parse JSON data.
              npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
              npm ERR! A complete log of this run can be found in: /home/lolo/.npm/_logs/2024-01-01T18_11_41_122Z-debug-0.log
                sdetweil @Guku
                @Guku did you use apply?
                can u look at package.json too?
                • G
                  Guku @sdetweil
                  @sdetweil i did use apply at the end and here the file
                  	"name": "magicmirror",
                  	"version": "2.26.0",
                  	"description": "The open source modular smart mirror platform.",
                  	"main": "js/electron.js",
                  	"scripts": {
                  		"start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev",
                  		"server": "node ./serveronly",
                  		"install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
                  		"install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
                  		"install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                  		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                  		"postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"",
                  		"test": "NODE_ENV=test jest -i --forceExit",
                  		"test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit",
                  		"test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
                  		"test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
                  		"test:unit": "NODE_ENV=test jest --selectProjects unit",
                  		"test:prettier": "prettier . --check",
                  		"test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*'",
                  		"test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
                  		"test:calendar": "node ./modules/default/calendar/debug.js",
                  		"config:check": "node js/check_config.js",
                  		"lint:prettier": "prettier . --write",
                  		"lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --fix",
                  		"lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
                  		"lint:staged": "lint-staged",
                  		"prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed."
                  	"repository": {
                  		"type": "git",
                  		"url": "git+https://github.com/MichMich/MagicMirror.git"
                  	"keywords": [
                  		"magic mirror",
                  		"magicmirror",
                  		"smart mirror",
                  		"mirror UI",
                  		"modular"
                  	"author": "Michael Teeuw",
                  	"contributors": [
                  		"https://github.com/MichMich/MagicMirror/graphs/contributors"
                  	"license": "MIT",
                  	"bugs": {
                  		"url": "https://github.com/MichMich/MagicMirror/issues"
                  	"homepage": "https://magicmirror.builders",
                  	"devDependencies": {
                  		"@stylistic/eslint-plugin": "^1.5.1",
                  		"eslint-plugin-import": "^2.29.1",
                  		"eslint-plugin-jest": "^27.6.0",
                  		"eslint-plugin-jsdoc": "^46.9.1",
                  		"express-basic-auth": "^1.2.1",
                  		"husky": "^8.0.3",
                  		"jest": "^29.7.0",
                  		"jsdom": "^23.0.1",
                  		"lint-staged": "^15.2.0",
                  		"lodash": "^4.17.21",
                  		"playwright": "^1.40.1",
                  		"prettier": "^3.1.1",
                  		"sinon": "^17.0.1",
                  		"stylelint": "^16.1.0",
                  		"stylelint-config-standard": "^36.0.0",
                  		"stylelint-prettier": "^5.0.0",
                  		"suncalc": "^1.9.0"
                  	"optionalDependencies": {
                  		"electron": "^27.2.0"
                  	"dependencies": {
                  		"colors": "^1.4.0",
                  		"command-exists": "^1.2.9",
                  		"console-stamp": "^3.1.2",
                  		"envsub": "^4.1.0",
                  		"eslint": "^8.56.0",
                  		"express": "^4.18.2",
                  		"express-ipfilter": "^1.3.1",
                  		"feedme": "^2.0.2",
                  		"helmet": "^7.1.0",
                  		"html-to-text": "^9.0.5",
                  		"iconv-lite": "^0.6.3",
                  		"module-alias": "^2.2.3",
                  	"lint-staged": {
                  		"*": "prettier --write",
                  		"*.js": "eslint",
                  		"*.css": "stylelint"
                  	"_moduleAliases": {
                  		"node_helper": "js/node_helper.js",
                  		"logger": "js/logger.js"
                  	"engines": {
                  		"node": ">=18"
                    sdetweil @Guku
                    @Guku weird… missing some of file
                    git checkout package.json
                      @Guku also, can u send me the ~/MagicMirror/installers/upgrade.log
                      same userid at gmail
                      • G
                        Guku @sdetweil
                        @sdetweil ran the command and this is it
                        Updated 1 path from the index
                        sent email with upgrade log
                        S 2 Replies Last reply
                          sdetweil @Guku
                          @Guku now
                          npm start
                            sdetweil @Guku
                            @Guku I ran upgarde on my very old desktop, 2.8 to 2.26
                            all ok
                            • G
                              Guku @sdetweil
                              @sdetweil now this
                              npm run server
                              magicmirror@2.26.0 server
                              node ./serveronly
                              [01.01.2024 13:52.17.327] [LOG] Starting MagicMirror: v2.26.0
                              [01.01.2024 13:52.17.329] [LOG] Loading config …
                              [01.01.2024 13:52.17.330] [DEBUG] config template file not exists, no envsubst
                              [01.01.2024 13:52.17.332] [LOG] Loading module helpers …
                              [01.01.2024 13:52.17.332] [LOG] No helper found for module: alert.
                              [01.01.2024 13:52.17.336] [ERROR] Whoops! There was an uncaught exception…
                              [01.01.2024 13:52.17.339] [ERROR] Error: Cannot find module ‘command-exists’
                              Require stack:
                              • /home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js
                              • /home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js
                              • /home/lolo/MagicMirror/js/app.js
                              • /home/lolo/MagicMirror/serveronly/index.js
                                at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
                                at Module._resolveFilename (/home/lolo/MagicMirror/node_modules/module-alias/index.js:49:29)
                                at Module._load (node:internal/modules/cjs/loader:901:27)
                                at Module.require (node:internal/modules/cjs/loader:1115:19)
                                at require (node:internal/modules/helpers:130:18)
                                at Object. (/home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js:3:23)
                                at Module._compile (node:internal/modules/cjs/loader:1241:14)
                                at Module._extensions…js (node:internal/modules/cjs/loader:1295:10)
                                at Module.load (node:internal/modules/cjs/loader:1091:32)
                                at Module._load (node:internal/modules/cjs/loader:938:12)
                                at Object. (/home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js:4:22)
                                at Module.load (node:internal/modules/cjs/loader:1091:32) {
                                code: ‘MODULE_NOT_FOUND’,
                                requireStack: [
                                ‘/home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js’,
                                ‘/home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js’,
                                ‘/home/lolo/MagicMirror/js/app.js’,
                                ‘/home/lolo/MagicMirror/serveronly/index.js’
                                [01.01.2024 13:52.17.339] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                [01.01.2024 13:52.17.339] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                sdetweil @Guku
                                @Guku I’m guessing because of the merge conflict the install didn’t work
                                do
                                npm install
                                then start again
                                • G
                                  Guku @sdetweil
                                  @sdetweil i think that finally did it!
                                  thank you so much for your help Sam!
