    Merge conflict detected in your package.json
    19 Posts 3 Posters 4.8k Views 3 Watching
      sdetweil @Guku
      @Guku rm package-lock.json
      to erase it
      my upgrade script handles this for you
      • G Offline
        Guku @sdetweil
        @sdetweil said in Merge conflict detected in your package.json:
        ran your upgrade script and now see this
        MagicMirror $ npm run server
        npm ERR! code EJSONPARSE
        npm ERR! JSON.parse Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3552 while parsing ‘{
        npm ERR! JSON.parse “name”: “magicmirror”,
        npm ERR! JSON.parse “version”: "2’
        npm ERR! JSON.parse Failed to parse JSON data.
        npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
        npm ERR! A complete log of this run can be found in: /home/lolo/.npm/_logs/2024-01-01T18_11_41_122Z-debug-0.log
          sdetweil @Guku
          @Guku did you use apply?
          can u look at package.json too?
          • G Offline
            Guku @sdetweil
            @sdetweil i did use apply at the end and here the file
            	"name": "magicmirror",
            	"version": "2.26.0",
            	"description": "The open source modular smart mirror platform.",
            	"main": "js/electron.js",
            	"scripts": {
            		"start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev",
            		"server": "node ./serveronly",
            		"install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
            		"install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
            		"install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
            		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
            		"postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"",
            		"test": "NODE_ENV=test jest -i --forceExit",
            		"test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit",
            		"test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
            		"test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
            		"test:unit": "NODE_ENV=test jest --selectProjects unit",
            		"test:prettier": "prettier . --check",
            		"test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*'",
            		"test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
            		"test:calendar": "node ./modules/default/calendar/debug.js",
            		"config:check": "node js/check_config.js",
            		"lint:prettier": "prettier . --write",
            		"lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --fix",
            		"lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
            		"lint:staged": "lint-staged",
            		"prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed."
            	"repository": {
            		"type": "git",
            		"url": "git+https://github.com/MichMich/MagicMirror.git"
            	"keywords": [
            		"magic mirror",
            		"magicmirror",
            		"smart mirror",
            		"mirror UI",
            		"modular"
            	"author": "Michael Teeuw",
            	"contributors": [
            		"https://github.com/MichMich/MagicMirror/graphs/contributors"
            	"license": "MIT",
            	"bugs": {
            		"url": "https://github.com/MichMich/MagicMirror/issues"
            	"homepage": "https://magicmirror.builders",
            	"devDependencies": {
            		"@stylistic/eslint-plugin": "^1.5.1",
            		"eslint-plugin-import": "^2.29.1",
            		"eslint-plugin-jest": "^27.6.0",
            		"eslint-plugin-jsdoc": "^46.9.1",
            		"express-basic-auth": "^1.2.1",
            		"husky": "^8.0.3",
            		"jest": "^29.7.0",
            		"jsdom": "^23.0.1",
            		"lint-staged": "^15.2.0",
            		"lodash": "^4.17.21",
            		"playwright": "^1.40.1",
            		"prettier": "^3.1.1",
            		"sinon": "^17.0.1",
            		"stylelint": "^16.1.0",
            		"stylelint-config-standard": "^36.0.0",
            		"stylelint-prettier": "^5.0.0",
            		"suncalc": "^1.9.0"
            	"optionalDependencies": {
            		"electron": "^27.2.0"
            	"dependencies": {
            		"colors": "^1.4.0",
            		"command-exists": "^1.2.9",
            		"console-stamp": "^3.1.2",
            		"envsub": "^4.1.0",
            		"eslint": "^8.56.0",
            		"express": "^4.18.2",
            		"express-ipfilter": "^1.3.1",
            		"feedme": "^2.0.2",
            		"helmet": "^7.1.0",
            		"html-to-text": "^9.0.5",
            		"iconv-lite": "^0.6.3",
            		"module-alias": "^2.2.3",
            	"lint-staged": {
            		"*": "prettier --write",
            		"*.js": "eslint",
            		"*.css": "stylelint"
            	"_moduleAliases": {
            		"node_helper": "js/node_helper.js",
            		"logger": "js/logger.js"
            	"engines": {
            		"node": ">=18"
              sdetweil @Guku
              @Guku weird… missing some of file
              git checkout package.json
                @Guku also, can u send me the ~/MagicMirror/installers/upgrade.log
                same userid at gmail
                • G Offline
                  Guku @sdetweil
                  @sdetweil ran the command and this is it
                  Updated 1 path from the index
                  sent email with upgrade log
                    sdetweil @Guku
                    @Guku now
                    npm start
                      sdetweil @Guku
                      @Guku I ran upgarde on my very old desktop, 2.8 to 2.26
                      all ok
                      • G Offline
                        Guku @sdetweil
                        @sdetweil now this
                        npm run server
                        magicmirror@2.26.0 server
                        node ./serveronly
                        [01.01.2024 13:52.17.327] [LOG] Starting MagicMirror: v2.26.0
                        [01.01.2024 13:52.17.329] [LOG] Loading config …
                        [01.01.2024 13:52.17.330] [DEBUG] config template file not exists, no envsubst
                        [01.01.2024 13:52.17.332] [LOG] Loading module helpers …
                        [01.01.2024 13:52.17.332] [LOG] No helper found for module: alert.
                        [01.01.2024 13:52.17.336] [ERROR] Whoops! There was an uncaught exception…
                        [01.01.2024 13:52.17.339] [ERROR] Error: Cannot find module ‘command-exists’
                        Require stack:
                        • /home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js
                        • /home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js
                        • /home/lolo/MagicMirror/js/app.js
                        • /home/lolo/MagicMirror/serveronly/index.js
                          at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
                          at Module._resolveFilename (/home/lolo/MagicMirror/node_modules/module-alias/index.js:49:29)
                          at Module._load (node:internal/modules/cjs/loader:901:27)
                          at Module.require (node:internal/modules/cjs/loader:1115:19)
                          at require (node:internal/modules/helpers:130:18)
                          at Object. (/home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js:3:23)
                          at Module._compile (node:internal/modules/cjs/loader:1241:14)
                          at Module._extensions…js (node:internal/modules/cjs/loader:1295:10)
                          at Module.load (node:internal/modules/cjs/loader:1091:32)
                          at Module._load (node:internal/modules/cjs/loader:938:12)
                          at Object. (/home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js:4:22)
                          at Module.load (node:internal/modules/cjs/loader:1091:32) {
                          code: ‘MODULE_NOT_FOUND’,
                          requireStack: [
                          ‘/home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js’,
                          ‘/home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js’,
                          ‘/home/lolo/MagicMirror/js/app.js’,
                          ‘/home/lolo/MagicMirror/serveronly/index.js’
                          [01.01.2024 13:52.17.339] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          [01.01.2024 13:52.17.339] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          sdetweil @Guku
                          @Guku I’m guessing because of the merge conflict the install didn’t work
                          do
                          npm install
                          then start again
                          • G Offline
                            Guku @sdetweil
                            @sdetweil i think that finally did it!
                            thank you so much for your help Sam!
