    Calendar not updating
    95 Posts 4 Posters 95.3k Views 6 Watching
      matt216 @matt216
      By existing and new events I mean with reference to the point I added the calendar server to the calendar module. That first initial sync (if that’s the right word) of the .ics file.
        sdetweil @matt216
        @matt216 and what do you see in the place where you npm start?
        should NOT see the timeout error
        M 1 Reply Last reply
          matt216 @sdetweil
          @sdetweil I do not see a timeout, no. The most unusual log entry related to the calendar is
          [04.01.2024 16:39.21.257] [LOG] Use existing calendarfetcher for url: https://my.cal.url
          That “existing” might imply something…?
          S 2 Replies Last reply
            sdetweil @matt216
            @matt216 not an error… says ’ we created a fecther() at the start’… and we found it and are reusing it… just informational
            now… lets turn on more debug
            in the config.js
            change
                logLevel: [
                  "INFO",
                  "LOG",
                  "WARN",
                  "ERROR",
               //   "DEBUG"
            loglevel like that (just hit enter after the commas and before the ]
            then add the // debug line
            then remove the leading //
            just makes it easier later to turn off debug by adding the // (comment it out)
            then in MagicMirror folder again do
            npm start >somefile.txt 2>&1
            wait til you think it should have updated...
            then ctrl-q
            and then look at the somefile.txt or send it to me
            same user id at gmail
            (I added most of the debug output to work on calendar problems)
            then u can comment out "DEBUG" again
            we did change the calendar parser version this release, to fix a couple bugs I added code for, and a big change on the repeating rule handler...
              matt216 @sdetweil
              @sdetweil yikes, 14000 lines of calendar entries included in this one!
              Any steer on what I’m looking for? Loads of personal info, so I won’t send over if that’s ok (no offence)
              Matt
                sdetweil @matt216
                @matt216 well … just let you know… I don’t LOOK at any of that info… only the cal entry dates and processing… I only match by title… and I NEVER share…
                (we just added the cal url to output as some were confused about which calendar was sending what entries… more debug info )
                start of the content
                [04.01.2024 11:14.45.590] [DEBUG] There are 5 calendar entries.
                [04.01.2024 11:14.45.591] [DEBUG] Processing entry...
                [04.01.2024 11:14.45.594] [DEBUG] Event:
                then thru the next Event: is all one event, with its recurring events if any
                I’m interested in the events that you says don’t show up…
                one thing you can do is use the configured url to get the ics file
                to make sure the calendar provider is providing the entry
                if its in the ics , but not in the output, then this is a new parser problem… and I want to see the ics entry to test. all can be sent thru mail or private chat (altho chat posts are limited in size)
                curl -sL thaturl >someicsfile.txt
                ics file is just text
                can u find that entry
                can u find it in the debug output
                  sdetweil @matt216
                  @matt216 also, could you check
                  ip addr
                  and disable the IP v6 if present.
                  in desktop, menu , preferences, pi config , network settings. may have to reboot
                    sdetweil @matt216
                    @matt216 also another user having trouble… his url is a shared cal , the other person owns it, but has given the secret url to the spouse for MM cal usage
                    are any of the cals shared like this?
                      matt216 @sdetweil
                      @sdetweil Hi Sam.
                      A newly created event is showing up in the debug logs, but not on the mirror display:
                      [05.01.2024 13:22.18.330] [DEBUG] Event:
                      {"type":"VEVENT","params":[],"created":"2024-01-05T13:20:05.000Z","end":"2024-01-06T10:00:00.000Z","dtstamp":"2024-01-05T13:20:06.000Z","start":"2024-01-06T09:00:00.000Z","datetype":"date-time","lastmodified":"2024-01-05T13:20:05.000Z","sequence":"0","summary":"test1234567","transparency":"OPAQUE","uid":"60E1B9F2-66C4-46ED-B98E-AD1A36FAB1EF","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000"}
                      [05.01.2024 13:22.18.330] [DEBUG] start: Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                      [05.01.2024 13:22.18.331] [DEBUG] end:: Sat Jan 06 2024 10:00:00 GMT+0000 (Greenwich Mean Time)
                      [05.01.2024 13:22.18.331] [DEBUG] duration: 3600000
                      [05.01.2024 13:22.18.331] [DEBUG] title: test1234567
                      [05.01.2024 13:22.18.331] [DEBUG] initial tz=Europe/London
                      [05.01.2024 13:22.18.332] [DEBUG] corrected tz=Europe/London
                      [05.01.2024 13:22.18.332] [DEBUG] start date/time=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                      [05.01.2024 13:22.18.332] [DEBUG] start offset=0
                      [05.01.2024 13:22.18.333] [DEBUG] start date/time w tz =Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                      [05.01.2024 13:22.18.333] [DEBUG] event date=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                      [05.01.2024 13:22.18.333] [DEBUG] event offset=0 hour=9 event date=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                      [05.01.2024 13:22.18.333] [DEBUG] adjustHours=0
                      [05.01.2024 13:22.18.334] [DEBUG] Processing entry...
                        matt216 @sdetweil
                        @sdetweil done
                          matt216 @sdetweil
                          @sdetweil Not entirely sure what you mean here. This is a calendar that I own. It’s a locally hosted container service. Several devices read/write to it. It is a baikal server. I have seen several forum posts that suggest using the caldav URL adding ?export to the end to generate the ics file.
                            sdetweil @matt216
                            @matt216 ok… looking at the code
                              @matt216 can u show me that event from the ICS file?
                              does the rest of the debug output say
                              Calendar-Fetcher: Broadcasting xxx events
                              where xxx is not 0
                                matt216 @sdetweil
                                @sdetweil from ics file:
                                BEGIN:VEVENT
                                CREATED:20240105T132005Z
                                DTEND;TZID=Europe/London:20240106T100000
                                DTSTAMP:20240105T132006Z
                                DTSTART;TZID=Europe/London:20240106T090000
                                LAST-MODIFIED:20240105T132005Z
                                SEQUENCE:0
                                SUMMARY:test1234567
                                TRANSP:OPAQUE
                                UID:60E1B9F2-66C4-46ED-B98E-AD1A36FAB1EF
                                URL;VALUE=URI:
                                X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
                                X-APPLE-CREATOR-TEAM-IDENTITY:0000000000
                                END:VEVENT
                                Broadcasting 1000+ events, yes.
                                  sdetweil @matt216
                                  @matt216 and it works perfectly here…
                                  could you try in config before the calendars list
                                  broadcastPastEvents: false
                                    matt216 @sdetweil
                                    @sdetweil config now:
                                                            header: "calendar",
        fetchInterval: 120000,
        timeFormat: 'absolute',
        maximumEntries: 5,
        broadcastPastEvents: false,
        url: 'https://my.cal.url',
        auth:   {
        user: 'user',
        pass: 'pass',
        method: 'basic'
                                    No change. Still not displaying newly created events. :(
                                      sdetweil @matt216
                                      @matt216 ok, i don’t know… lets get you back to running on the prior release
                                      stop mm, shouldn’t be running as its not helpful
                                      git tag -l
                                      to see the list of tagged commits,
                                      then
                                      git checkout temp_branch -b tags/v???????
                                      where ??? is the number 2.25.0 or whatever u want to go back to
                                      then
                                      rm -rf node_modules
                                      npm install
                                      please advise(we can get back to the current v2.26.0 branch too, very easily
                                        sdetweil @matt216
                                        @matt216 just one last thing, if you comment out
                                         maximumEntries: 5,
                                        what happens?
                                          matt216 @sdetweil
                                          @sdetweil commenting maximumEntries just shows the default 10 entries, but still does not include recently created events that should show within those 10.
                                          Getting a git error (novice here, sorry):
                                          fatal: 'temp_branch' is not a commit and a branch 'tags/v2.24.0' cannot be created from it
                                          Although this issue existed before I upgraded to 2.26.0…
                                            matt216
                                            I might have a go at spinning up another calendar server and see if the issue still exists there. This calendar is a newly self-hosted one so it could be an issue there (although the magicmirror is the only device having trouble with it).
                                            Thanks for the help still.
                                            Matt
                                            • 2 / 5
