    Calendar not updating
    95 Posts 4 Posters 95.3k Views 6 Watching
      matt216 @sdetweil
      @sdetweil None that I can see.
      pi@magicmirror:~/.pm2/logs $ tail --lines=1000 MagicMirror-error.log | grep calendar
      [02.01.2024 10:29.43.758] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
      [02.01.2024 10:31.53.769] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
      Will open an issue. Thanks for assisting. I might have a play with a couple of the other calendar modules there are out there…
        sdetweil @matt216
        @matt216 generally there is a more specific error earlier in the log.
        if you clear it
        pm2 flush
        the restart
        pm2 restart all
        you will have the smallest output to look at
        M 1 Reply Last reply
          matt216 @sdetweil
          @sdetweil Can’t see any calendar errors in error.log now! :grinning_squinting_face:
          But still my new events are not showing up when they should…
            matt216
            https://github.com/MagicMirrorOrg/MagicMirror/issues/3329
              sdetweil @matt216
              @matt216 thank you… i posted a an additional grep thru the log to the issue
                sdetweil @matt216
                @matt216 cant see any errors… well not with the grep search you do
                can u do this
                pm2 stop all
                npm start >somefile.txt 2>&1
                wait, til UI up with no issues, or no updates
                ctrl-q on MM screen to end
                edit the somefile.txt
                loo at messages after “Starting server on port”
                  matt216 @sdetweil
                  pi@magicmirror:~/MagicMirror $ cat somefile.txt | grep calendar
                  [02.01.2024 14:56.40.510] [LOG]   Module helper loaded: calendar
                  [02.01.2024 14:56.42.557] [LOG]   Connecting socket for: calendar
                  [02.01.2024 14:56.42.558] [LOG]   Starting node helper for: calendar
                  [02.01.2024 14:56.46.986] [LOG]   Create new calendarfetcher for url: https://my.cal.url - Interval: 120000
                  [02.01.2024 14:57.13.099] [INFO]  Calendar-Fetcher: Broadcasting 379 events from https://my.cal.url.
                  [02.01.2024 14:59.23.139] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                    matt216 @matt216
                        at Object.fetch (node:internal/deps/undici/undici:11576:11)
                        at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
                      cause: ConnectTimeoutError: Connect Timeout Error
                          at onConnectTimeout (node:internal/deps/undici/undici:8522:28)
                          at node:internal/deps/undici/undici:8480:50
                          at Immediate._onImmediate (node:internal/deps/undici/undici:8511:13)
                          at process.processImmediate (node:internal/timers:476:21) {
                        code: 'UND_ERR_CONNECT_TIMEOUT'
                    Timeout…
                    Let me know if the full somefile.txt by email is still wanted.
                      sdetweil @matt216
                      @matt216 no… not needed…
                        matt216 @sdetweil
                        @sdetweil If I enter my calendar URL in to a web browser I can download the ics file fine, FYI
                        S 2 Replies Last reply
                          sdetweil @matt216
                          @matt216 yes, it was a momentary delay, which caused the timeout… trying to see why the catch() block didn’t
                            sdetweil @matt216
                            @matt216 can u try updating modules/default/calendar/calendarfetcher.js like this
                            replace lines 58-84 with this . also added this to the issue
                            		try {  /// new code here     // this will be the new line 58
                            		fetch(url, { headers: headers, agent: httpsAgent })
                            			.then(NodeHelper.checkFetchStatus)
                            			.then((response) => response.text())
                            			.then((responseData) => {
                            				let data = [];
                            				try {
                            					data = ical.parseICS(responseData);
                            					Log.debug(`parsed data=${JSON.stringify(data)}`);
                            					events = CalendarFetcherUtils.filterEvents(data, {
                            						excludedEvents,
                            						includePastEvents,
                            						maximumEntries,
                            						maximumNumberOfDays
                            				} catch (error) {
                            					fetchFailedCallback(this, error);
                            					scheduleTimer();
                            					return;
                            				this.broadcastEvents();
                            				scheduleTimer();
                            			.catch((error) => {
                            				scheduleTimer();
                            		}    // new code here =========
                            		catch(error){
                                                 console.error( "fetch for calendar url" +url + "failed error="+error.code);
                                                scheduleTimer();
                            		}   // end new code =====
                              matt216 @sdetweil
                              @sdetweil Doesn’t like that - mirror won’t load. Got to pick up my little boy now, so reverted back (mirror loads ok again). Will try again and look at logs.
                              S M 2 Replies Last reply
                                sdetweil @matt216
                                @matt216 u are replacing the whole block, right…
                                replace lines 58-84 in original with that
                                lmk
                                  matt216 @matt216
                                  @sdetweil can you tell I’m not a developer…?!
                                  Ok, I’ve replaced the whole block, then pm2 stop all, cd ~/MagicMirror, npm start…
                                  Mirror starts but still no new calendar events are showing where I would expect to be. Interestingly I can see that edits to existing events that I’ve made are showing up on the mirror, so there is some communication. Just no new events are being picked up.
                                  Thanks again,
                                  Matt
                                  M S 2 Replies Last reply
                                    matt216 @matt216
                                    By existing and new events I mean with reference to the point I added the calendar server to the calendar module. That first initial sync (if that’s the right word) of the .ics file.
                                      sdetweil @matt216
                                      @matt216 and what do you see in the place where you npm start?
                                      should NOT see the timeout error
                                        matt216 @sdetweil
                                        @sdetweil I do not see a timeout, no. The most unusual log entry related to the calendar is
                                        [04.01.2024 16:39.21.257] [LOG] Use existing calendarfetcher for url: https://my.cal.url
                                        That “existing” might imply something…?
                                          sdetweil @matt216
                                          @matt216 not an error… says ’ we created a fecther() at the start’… and we found it and are reusing it… just informational
                                          now… lets turn on more debug
                                          in the config.js
                                          change
                                              logLevel: [
                                                "INFO",
                                                "LOG",
                                                "WARN",
                                                "ERROR",
                                             //   "DEBUG"
                                          loglevel like that (just hit enter after the commas and before the ]
                                          then add the // debug line
                                          then remove the leading //
                                          just makes it easier later to turn off debug by adding the // (comment it out)
                                          then in MagicMirror folder again do
                                          wait til you think it should have updated...
                                          then ctrl-q
                                          and then look at the somefile.txt or send it to me
                                          same user id at gmail
                                          (I added most of the debug output to work on calendar problems)
                                          then u can comment out "DEBUG" again
                                          we did change the calendar parser version this release, to fix a couple bugs I added code for, and a big change on the repeating rule handler...
                                            matt216 @sdetweil
                                            @sdetweil yikes, 14000 lines of calendar entries included in this one!
                                            Any steer on what I’m looking for? Loads of personal info, so I won’t send over if that’s ok (no offence)
                                            Matt
                                            • 2 / 5
