    MM starts but doesn't show up
    26 Posts 2 Posters 5.7k Views 2 Watching
      Benalze
      I recently updatet my MM and the MMM-GooglePhotos module. Since then, it won’t show up after starting it. Even manually.
      Also tried some scripts from “sdetweil”, but it’s not working. (but if I now starting it using pm2 start mm, I have two sessions)
      • I also already tried to git pull && npm install for every module
      • Debugged the config (no issues)
      • Restarted everything
        sdetweil @Benalze
        @Benalze please show the messages from npm start
        if you use pm2, then
        pm2 stop all
        then
        npm start
          Benalze @sdetweil
          > magicmirror@2.26.0 start
          App threw an error during load
          Error: Cannot find module 'logger'
          Require stack:
              at Module._resolveFilename (node:internal/modules/cjs/loader:1082:15)
              at n._resolveFilename (node:electron/js2c/browser_init:2:117457)
              at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
              at Module._load (node:internal/modules/cjs/loader:927:27)
              at f._load (node:electron/js2c/asar_bundle:2:13330)
              at Module.require (node:internal/modules/cjs/loader:1148:19)
              at require (node:internal/modules/cjs/helpers:110:18)
              at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:14:13)
              at Module._compile (node:internal/modules/cjs/loader:1269:14)
              at Module._extensions..js (node:internal/modules/cjs/loader:1324:10)
              at Module.load (node:internal/modules/cjs/loader:1124:32)
              at Module._load (node:internal/modules/cjs/loader:965:12)
              at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
          A JavaScript error occurred in the main process
          Uncaught Exception:
          Require stack:
          [3001:0107/202334.853859:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
            sdetweil @Benalze
            @Benalze you should use my upgrade script…
            note its a two part process
            test run NO CHANGES… don’t break anything
            if you THINK its ok, then the apply run
            actually DO the upgrade
            IF you tried manually, then apply will abort, cause u are already on the current release
            (don’t break anything!!!)
            so you can change the word ‘apply’ to ‘force’ (no quotes)
            to upgade over the currect release again…
              sdetweil @Benalze
              @Benalze the npm install did not work
              npm run install-mm
              please advise results
                Benalze @sdetweil
                > magicmirror@2.26.0 install-mm
                > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
                npm ERR! code ENOTEMPTY
                npm ERR! syscall rename
                npm ERR! path /home/pi/MagicMirror/node_modules/playwright-core
                npm ERR! dest /home/pi/MagicMirror/node_modules/.playwright-core-vy8UGbYV
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/playwright-core' -> '/home/pi/MagicMirror/node_modules/.playwright-core-vy8UGbYV'
                npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-07T19_26_34_072Z-debug-0.log
                  sdetweil @Benalze
                  @Benalze
                  sudo rm -rf node_modules
                  npm run install-mm
                    Benalze @sdetweil
                    npm ERR! errno -39
                    pi@raspberrypi:~/MagicMirror $ sudo rm -rf node_modules
                    pi@raspberrypi:~/MagicMirror $ npm run install-mm
                    (node:3286) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
                    (Use `node --trace-warnings ...` to show where the warning was created)
                    > magicmirror@2.26.0 postinstall
                    > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                    > magicmirror@2.26.0 install-vendor
                    > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                    added 1 package, and changed 2 packages in 12s
                    > magicmirror@2.26.0 install-fonts
                    > echo "Installing fonts ...
                    > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                    changed 2 packages in 6s
                    > magicmirror@2.26.0 prepare
                    > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                    no husky installed.
                    added 343 packages in 2m
                      sdetweil @Benalze
                      @Benalze cool… npm start
                        Benalze @sdetweil
                        Looks like something is still missing…
                        Require stack:
                            at node:internal/modules/cjs/loader:1084:15
                            at Function.<anonymous> (node:electron/js2c/browser_init:2:116646)
                            at node:internal/modules/cjs/loader:929:27
                            at Function._load (node:electron/js2c/asar_bundle:2:13327)
                            at Module.require (node:internal/modules/cjs/loader:1150:19)
                            at require (node:internal/modules/cjs/helpers:121:18)
                            at Module._compile (node:internal/modules/cjs/loader:1271:14)
                            at Object..js (node:internal/modules/cjs/loader:1326:10)
                            at Module.load (node:internal/modules/cjs/loader:1126:32)
                            at node:internal/modules/cjs/loader:967:12
                        Uncaught Exception:
                        Require stack:
                        [4099:0107/205905.993672:ERROR:viz_main_impl.cc(196)] Exiting GPU process due to errors during initialization
                        Warning: vkCreateInstance: Found no drivers!
                        Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                            at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                            at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                            at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                            at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                            at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
