    MM starts but doesn't show up
    26 Posts 2 Posters 5.8k Views 2 Watching
      sdetweil @Benalze
      @Benalze please show the messages from npm start
      if you use pm2, then
      pm2 stop all
      then
      npm start
        Benalze @sdetweil
        > magicmirror@2.26.0 start
        App threw an error during load
        Error: Cannot find module 'logger'
        Require stack:
            at Module._resolveFilename (node:internal/modules/cjs/loader:1082:15)
            at n._resolveFilename (node:electron/js2c/browser_init:2:117457)
            at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
            at Module._load (node:internal/modules/cjs/loader:927:27)
            at f._load (node:electron/js2c/asar_bundle:2:13330)
            at Module.require (node:internal/modules/cjs/loader:1148:19)
            at require (node:internal/modules/cjs/helpers:110:18)
            at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:14:13)
            at Module._compile (node:internal/modules/cjs/loader:1269:14)
            at Module._extensions..js (node:internal/modules/cjs/loader:1324:10)
            at Module.load (node:internal/modules/cjs/loader:1124:32)
            at Module._load (node:internal/modules/cjs/loader:965:12)
            at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
        A JavaScript error occurred in the main process
        Uncaught Exception:
        Require stack:
        [3001:0107/202334.853859:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
          sdetweil @Benalze
          @Benalze you should use my upgrade script…
          note its a two part process
          test run NO CHANGES… don’t break anything
          if you THINK its ok, then the apply run
          actually DO the upgrade
          IF you tried manually, then apply will abort, cause u are already on the current release
          (don’t break anything!!!)
          so you can change the word ‘apply’ to ‘force’ (no quotes)
          to upgade over the currect release again…
            sdetweil @Benalze
            @Benalze the npm install did not work
            npm run install-mm
            please advise results
              Benalze @sdetweil
              > magicmirror@2.26.0 install-mm
              > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
              npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
              npm ERR! code ENOTEMPTY
              npm ERR! syscall rename
              npm ERR! path /home/pi/MagicMirror/node_modules/playwright-core
              npm ERR! dest /home/pi/MagicMirror/node_modules/.playwright-core-vy8UGbYV
              npm ERR! errno -39
              npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/playwright-core' -> '/home/pi/MagicMirror/node_modules/.playwright-core-vy8UGbYV'
              npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-07T19_26_34_072Z-debug-0.log
                sdetweil @Benalze
                @Benalze
                sudo rm -rf node_modules
                npm run install-mm
                  Benalze @sdetweil
                  npm ERR! errno -39
                  pi@raspberrypi:~/MagicMirror $ sudo rm -rf node_modules
                  pi@raspberrypi:~/MagicMirror $ npm run install-mm
                  (node:3286) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
                  (Use `node --trace-warnings ...` to show where the warning was created)
                  > magicmirror@2.26.0 postinstall
                  > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                  > magicmirror@2.26.0 install-vendor
                  > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                  added 1 package, and changed 2 packages in 12s
                  > magicmirror@2.26.0 install-fonts
                  > echo "Installing fonts ...
                  > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                  changed 2 packages in 6s
                  > magicmirror@2.26.0 prepare
                  > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                  no husky installed.
                  added 343 packages in 2m
                    sdetweil @Benalze
                    @Benalze cool… npm start
                      Benalze @sdetweil
                      Looks like something is still missing…
                      Require stack:
                          at node:internal/modules/cjs/loader:1084:15
                          at Function.<anonymous> (node:electron/js2c/browser_init:2:116646)
                          at node:internal/modules/cjs/loader:929:27
                          at Function._load (node:electron/js2c/asar_bundle:2:13327)
                          at Module.require (node:internal/modules/cjs/loader:1150:19)
                          at require (node:internal/modules/cjs/helpers:121:18)
                          at Module._compile (node:internal/modules/cjs/loader:1271:14)
                          at Object..js (node:internal/modules/cjs/loader:1326:10)
                          at Module.load (node:internal/modules/cjs/loader:1126:32)
                          at node:internal/modules/cjs/loader:967:12
                      Uncaught Exception:
                      Require stack:
                      [4099:0107/205905.993672:ERROR:viz_main_impl.cc(196)] Exiting GPU process due to errors during initialization
                      Warning: vkCreateInstance: Found no drivers!
                      Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                          at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                          at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                          at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                          at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                          at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                        sdetweil @Benalze
                        @Benalze weird
                        do
                        node -v
                        npm -v
                        B S 2 Replies Last reply Reply Quote 0
