    MM starts but doesn't show up
    26 Posts 2 Posters 6.6k Views 2 Watching
      Benalze @sdetweil
      > magicmirror@2.26.0 install-mm
      > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
      npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /home/pi/MagicMirror/node_modules/playwright-core
      npm ERR! dest /home/pi/MagicMirror/node_modules/.playwright-core-vy8UGbYV
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/playwright-core' -> '/home/pi/MagicMirror/node_modules/.playwright-core-vy8UGbYV'
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-07T19_26_34_072Z-debug-0.log
      pi@raspberrypi:~/MagicMirror $ sudo rm -rf node_modules
      pi@raspberrypi:~/MagicMirror $ npm run install-mm
      (node:3286) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
      (Use `node --trace-warnings ...` to show where the warning was created)
      > magicmirror@2.26.0 postinstall
      > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
      > magicmirror@2.26.0 install-vendor
      > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
      added 1 package, and changed 2 packages in 12s
      > magicmirror@2.26.0 install-fonts
      > echo "Installing fonts ...
      > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
      changed 2 packages in 6s
      > magicmirror@2.26.0 prepare
      > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
      no husky installed.
      added 343 packages in 2m
        sdetweil @Benalze
        @Benalze cool… npm start
          Benalze @sdetweil
          Looks like something is still missing…
          > magicmirror@2.26.0 start
          App threw an error during load
          Error: Cannot find module 'logger'
          Require stack:
              at node:internal/modules/cjs/loader:1084:15
              at Function.<anonymous> (node:electron/js2c/browser_init:2:116646)
              at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
              at node:internal/modules/cjs/loader:929:27
              at Function._load (node:electron/js2c/asar_bundle:2:13327)
              at Module.require (node:internal/modules/cjs/loader:1150:19)
              at require (node:internal/modules/cjs/helpers:121:18)
              at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:14:13)
              at Module._compile (node:internal/modules/cjs/loader:1271:14)
              at Object..js (node:internal/modules/cjs/loader:1326:10)
              at Module.load (node:internal/modules/cjs/loader:1126:32)
              at node:internal/modules/cjs/loader:967:12
              at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
          A JavaScript error occurred in the main process
          Uncaught Exception:
          Require stack:
          [4099:0107/205905.993672:ERROR:viz_main_impl.cc(196)] Exiting GPU process due to errors during initialization
          Warning: vkCreateInstance: Found no drivers!
          Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
              at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
              at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
              at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
              at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
              at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
            sdetweil @Benalze
            @Benalze weird
            do
            node -v
            npm -v
            B S 2 Replies Last reply Reply Quote 0
              Benalze @sdetweil
              i@raspberrypi:~/MagicMirror $ node -v
              v20.8.0
              pi@raspberrypi:~/MagicMirror $ npm -v
              10.1.0
                @Benalze also look at end of package.json
                  @Benalze and is logger.js in the ~/MagicMirror/js folder?
                    Benalze @sdetweil
                    Yes, the logger.js is there.
                    Here is what package.json sais:
                      "optionalDependencies": {
                        "electron": "^27.2.0"
                      "dependencies": {
                        "colors": "^1.4.0",
                        "command-exists": "^1.2.9",
                        "console-stamp": "^3.1.2",
                        "envsub": "^4.1.0",
                        "eslint": "^8.56.0",
                        "express": "^4.18.2",
                        "express-ipfilter": "^1.3.1",
                        "feedme": "^2.0.2",
                        "helmet": "^7.1.0",
                        "html-to-text": "^9.0.5",
                        "iconv-lite": "^0.6.3",
                        "module-alias": "^2.2.3",
                        "moment": "^2.30.1",
                        "node-ical": "^0.17.1",
                        "socket.io": "^4.7.2"
                      "lint-staged": {
                        "*": "prettier --write",
                        "*.js": "eslint",
                        "*.css": "stylelint"
                      "engines": {
                        "node": ">=18"
                      "directories": {
                        "test": "tests"
                      sdetweil @Benalze
                      @Benalze cool do
                      git status
                      then git checkout package.json
                      check it again
                      then ls node_modules/.bin/electron
                      note the dot in front of bin
                        Benalze @sdetweil
                        OK.
                        git status: (translated from GER to ENG)
                        pi@raspberrypi:~/MagicMirror $ git status
                        On branch master
                        Your branch is in the same state as 'origin/master'.
                        Changes that are not marked for commit:
                          (use "git add <file>..." to mark the changes for commit)
                          (use "git restore <file>..." to discard the changes in the working directory)
                        	changed: package-lock.json
                        Unversioned files:
                          (use "git add <file>..." to pre-commit the changes)
                        	config.js
                        	core
                        	installers/pm2_MagicMirror.json
                        no changes marked for commit (use "git add" and/or "git commit -a")
                        git checkout package.json (translated from GER to ENG)
                        pi@raspberrypi:~/MagicMirror $ git checkout package.json
                        1 Path updated from index
                        check it again
                        On branch master
                        Unversioned files:
                        	config.js
                        	core
                        and last but not least: ls node_modules/.bin/electron
                        pi@raspberrypi:~/MagicMirror $ ls node_modules/.bin/electron
                        ls: Unable to access 'node_modules/.bin/electron': File or directory not found
                          sdetweil @Benalze
                          @Benalze fun fun fun
                          npm install electron@27.2.1
                            sdetweil @Benalze
                            @Benalze I meant check the package.json sorry
                              Benalze @sdetweil
                              0 Paths updated from index
                                sdetweil @Benalze
                                @Benalze but you did that already… I was wondering about the aliases at the bottom
                                  Benalze @sdetweil
                                  	"dependencies": {
                                  		"colors": "^1.4.0",
                                  		"envsub": "^4.1.0",
                                  		"feedme": "^2.0.2",
                                  		"helmet": "^7.1.0",
                                  	"lint-staged": {
                                  		"*.js": "eslint",
                                  	"_moduleAliases": {
                                  		"node_helper": "js/node_helper.js",
                                  		"logger": "js/logger.js"
                                  	"engines": {
                                  		"node": ">=18"
                                    sdetweil @Benalze
                                    @Benalze good. if the electron install went ok, then npm start
                                      Benalze @sdetweil
                                      BOOM it worked.
                                      Thank you soo sooo much. I really appreciate it!!!
                                      Can you explain to me what was the problem?
                                        sdetweil @Benalze
                                        @Benalze somehow you had the correct top of package.json( that’s where the number comes in the npm start messages), but an incorrect bottom of package json ( no aliases)
                                        but git didn’t report the file being different
                                        I can’t explain that
                                        did u upgrade manually?
                                        if so, in the future please use my script
                                          Benalze @sdetweil
                                          Yes I upgraded manually and in the future I will use your script for sure!
