    MM starts but doesn't show up
    26 Posts 2 Posters 7.7k Views 2 Watching
      sdetweil @Benalze
      @Benalze cool do
      git status
      then git checkout package.json
      check it again
      then ls node_modules/.bin/electron
      note the dot in front of bin
      B 1 Reply Last reply
        Benalze @sdetweil
        OK.
        git status: (translated from GER to ENG)
        pi@raspberrypi:~/MagicMirror $ git status
        On branch master
        Your branch is in the same state as 'origin/master'.
        Changes that are not marked for commit:
          (use "git add <file>..." to mark the changes for commit)
          (use "git restore <file>..." to discard the changes in the working directory)
        	changed: package-lock.json
        Unversioned files:
          (use "git add <file>..." to pre-commit the changes)
        	config.js
        	core
        	installers/pm2_MagicMirror.json
        no changes marked for commit (use "git add" and/or "git commit -a")
        git checkout package.json (translated from GER to ENG)
        pi@raspberrypi:~/MagicMirror $ git checkout package.json
        1 Path updated from index
        check it again
        On branch master
        Unversioned files:
        	config.js
        	core
        and last but not least: ls node_modules/.bin/electron
        pi@raspberrypi:~/MagicMirror $ ls node_modules/.bin/electron
        ls: Unable to access 'node_modules/.bin/electron': File or directory not found
        S 2 Replies Last reply
          sdetweil @Benalze
          @Benalze fun fun fun
          npm install electron@27.2.1
            sdetweil @Benalze
            @Benalze I meant check the package.json sorry
              Benalze @sdetweil
              0 Paths updated from index
                sdetweil @Benalze
                @Benalze but you did that already… I was wondering about the aliases at the bottom
                  Benalze @sdetweil
                  	"optionalDependencies": {
                  		"electron": "^27.2.0"
                  	"dependencies": {
                  		"colors": "^1.4.0",
                  		"command-exists": "^1.2.9",
                  		"console-stamp": "^3.1.2",
                  		"envsub": "^4.1.0",
                  		"eslint": "^8.56.0",
                  		"express": "^4.18.2",
                  		"express-ipfilter": "^1.3.1",
                  		"feedme": "^2.0.2",
                  		"helmet": "^7.1.0",
                  		"html-to-text": "^9.0.5",
                  		"iconv-lite": "^0.6.3",
                  		"module-alias": "^2.2.3",
                  		"moment": "^2.30.1",
                  		"node-ical": "^0.17.1",
                  		"socket.io": "^4.7.2"
                  	"lint-staged": {
                  		"*": "prettier --write",
                  		"*.js": "eslint",
                  		"*.css": "stylelint"
                  	"_moduleAliases": {
                  		"node_helper": "js/node_helper.js",
                  		"logger": "js/logger.js"
                  	"engines": {
                  		"node": ">=18"
                    sdetweil @Benalze
                    @Benalze good. if the electron install went ok, then npm start
                      Benalze @sdetweil
                      BOOM it worked.
                      Thank you soo sooo much. I really appreciate it!!!
                      Can you explain to me what was the problem?
                        sdetweil @Benalze
                        @Benalze somehow you had the correct top of package.json( that’s where the number comes in the npm start messages), but an incorrect bottom of package json ( no aliases)
                        but git didn’t report the file being different
                        I can’t explain that
                        did u upgrade manually?
                        if so, in the future please use my script
                          Benalze @sdetweil
                          Yes I upgraded manually and in the future I will use your script for sure!
