    MM starts but doesn't show up
    26 Posts 2 Posters 7.2k Views 2 Watching
      sdetweil @Benalze
      @Benalze weird
      do
      node -v
      npm -v
      B S 2 Replies Last reply Reply Quote 0
        Benalze @sdetweil
        i@raspberrypi:~/MagicMirror $ node -v
        v20.8.0
        pi@raspberrypi:~/MagicMirror $ npm -v
        10.1.0
          @Benalze also look at end of package.json
            @Benalze and is logger.js in the ~/MagicMirror/js folder?
              Benalze @sdetweil
              Yes, the logger.js is there.
              Here is what package.json sais:
                "optionalDependencies": {
                  "electron": "^27.2.0"
                "dependencies": {
                  "colors": "^1.4.0",
                  "command-exists": "^1.2.9",
                  "console-stamp": "^3.1.2",
                  "envsub": "^4.1.0",
                  "eslint": "^8.56.0",
                  "express": "^4.18.2",
                  "express-ipfilter": "^1.3.1",
                  "feedme": "^2.0.2",
                  "helmet": "^7.1.0",
                  "html-to-text": "^9.0.5",
                  "iconv-lite": "^0.6.3",
                  "module-alias": "^2.2.3",
                  "moment": "^2.30.1",
                  "node-ical": "^0.17.1",
                  "socket.io": "^4.7.2"
                "lint-staged": {
                  "*": "prettier --write",
                  "*.js": "eslint",
                  "*.css": "stylelint"
                "engines": {
                  "node": ">=18"
                "directories": {
                  "test": "tests"
                sdetweil @Benalze
                @Benalze cool do
                git status
                then git checkout package.json
                check it again
                then ls node_modules/.bin/electron
                note the dot in front of bin
                  Benalze @sdetweil
                  OK.
                  git status: (translated from GER to ENG)
                  pi@raspberrypi:~/MagicMirror $ git status
                  On branch master
                  Your branch is in the same state as 'origin/master'.
                  Changes that are not marked for commit:
                    (use "git add <file>..." to mark the changes for commit)
                    (use "git restore <file>..." to discard the changes in the working directory)
                  	changed: package-lock.json
                  Unversioned files:
                    (use "git add <file>..." to pre-commit the changes)
                  	config.js
                  	core
                  	installers/pm2_MagicMirror.json
                  no changes marked for commit (use "git add" and/or "git commit -a")
                  git checkout package.json (translated from GER to ENG)
                  pi@raspberrypi:~/MagicMirror $ git checkout package.json
                  1 Path updated from index
                  check it again
                  On branch master
                  Unversioned files:
                  	config.js
                  	core
                  and last but not least: ls node_modules/.bin/electron
                  pi@raspberrypi:~/MagicMirror $ ls node_modules/.bin/electron
                  ls: Unable to access 'node_modules/.bin/electron': File or directory not found
                    sdetweil @Benalze
                    @Benalze fun fun fun
                    npm install electron@27.2.1
                      sdetweil @Benalze
                      @Benalze I meant check the package.json sorry
                        Benalze @sdetweil
                        0 Paths updated from index
                          sdetweil @Benalze
                          @Benalze but you did that already… I was wondering about the aliases at the bottom
                            Benalze @sdetweil
                            	"dependencies": {
                            		"colors": "^1.4.0",
                            		"envsub": "^4.1.0",
                            		"feedme": "^2.0.2",
                            		"helmet": "^7.1.0",
                            	"lint-staged": {
                            		"*.js": "eslint",
                            	"_moduleAliases": {
                            		"node_helper": "js/node_helper.js",
                            		"logger": "js/logger.js"
                            	"engines": {
                            		"node": ">=18"
                              sdetweil @Benalze
                              @Benalze good. if the electron install went ok, then npm start
                                Benalze @sdetweil
                                BOOM it worked.
                                Thank you soo sooo much. I really appreciate it!!!
                                Can you explain to me what was the problem?
                                  sdetweil @Benalze
                                  @Benalze somehow you had the correct top of package.json( that’s where the number comes in the npm start messages), but an incorrect bottom of package json ( no aliases)
                                  but git didn’t report the file being different
                                  I can’t explain that
                                  did u upgrade manually?
                                  if so, in the future please use my script
                                    Benalze @sdetweil
                                    Yes I upgraded manually and in the future I will use your script for sure!
