    MM starts but doesn't show up
    26 Posts 2 Posters 6.9k Views 2 Watching
      Benalze @sdetweil
      Looks like something is still missing…
      > magicmirror@2.26.0 start
      App threw an error during load
      Error: Cannot find module 'logger'
      Require stack:
          at node:internal/modules/cjs/loader:1084:15
          at Function.<anonymous> (node:electron/js2c/browser_init:2:116646)
          at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at node:internal/modules/cjs/loader:929:27
          at Function._load (node:electron/js2c/asar_bundle:2:13327)
          at Module.require (node:internal/modules/cjs/loader:1150:19)
          at require (node:internal/modules/cjs/helpers:121:18)
          at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:14:13)
          at Module._compile (node:internal/modules/cjs/loader:1271:14)
          at Object..js (node:internal/modules/cjs/loader:1326:10)
          at Module.load (node:internal/modules/cjs/loader:1126:32)
          at node:internal/modules/cjs/loader:967:12
          at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
      A JavaScript error occurred in the main process
      Uncaught Exception:
      Require stack:
      [4099:0107/205905.993672:ERROR:viz_main_impl.cc(196)] Exiting GPU process due to errors during initialization
      Warning: vkCreateInstance: Found no drivers!
      Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
          at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
          at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
          at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
          at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
          at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
        sdetweil @Benalze
        @Benalze weird
        do
        node -v
        npm -v
        B S 2 Replies Last reply Reply Quote 0
          Benalze @sdetweil
          i@raspberrypi:~/MagicMirror $ node -v
          v20.8.0
          pi@raspberrypi:~/MagicMirror $ npm -v
          10.1.0
            @Benalze also look at end of package.json
              @Benalze and is logger.js in the ~/MagicMirror/js folder?
                Benalze @sdetweil
                Yes, the logger.js is there.
                Here is what package.json sais:
                  "optionalDependencies": {
                    "electron": "^27.2.0"
                  "dependencies": {
                    "colors": "^1.4.0",
                    "command-exists": "^1.2.9",
                    "console-stamp": "^3.1.2",
                    "envsub": "^4.1.0",
                    "eslint": "^8.56.0",
                    "express": "^4.18.2",
                    "express-ipfilter": "^1.3.1",
                    "feedme": "^2.0.2",
                    "helmet": "^7.1.0",
                    "html-to-text": "^9.0.5",
                    "iconv-lite": "^0.6.3",
                    "module-alias": "^2.2.3",
                    "moment": "^2.30.1",
                    "node-ical": "^0.17.1",
                    "socket.io": "^4.7.2"
                  "lint-staged": {
                    "*": "prettier --write",
                    "*.js": "eslint",
                    "*.css": "stylelint"
                  "engines": {
                    "node": ">=18"
                  "directories": {
                    "test": "tests"
                  sdetweil @Benalze
                  @Benalze cool do
                  git status
                  then git checkout package.json
                  check it again
                  then ls node_modules/.bin/electron
                  note the dot in front of bin
                    Benalze @sdetweil
                    OK.
                    git status: (translated from GER to ENG)
                    pi@raspberrypi:~/MagicMirror $ git status
                    On branch master
                    Your branch is in the same state as 'origin/master'.
                    Changes that are not marked for commit:
                      (use "git add <file>..." to mark the changes for commit)
                      (use "git restore <file>..." to discard the changes in the working directory)
                    	changed: package-lock.json
                    Unversioned files:
                      (use "git add <file>..." to pre-commit the changes)
                    	config.js
                    	core
                    	installers/pm2_MagicMirror.json
                    no changes marked for commit (use "git add" and/or "git commit -a")
                    git checkout package.json (translated from GER to ENG)
                    pi@raspberrypi:~/MagicMirror $ git checkout package.json
                    1 Path updated from index
                    check it again
                    On branch master
                    Unversioned files:
                    	config.js
                    	core
                    and last but not least: ls node_modules/.bin/electron
                    pi@raspberrypi:~/MagicMirror $ ls node_modules/.bin/electron
                    ls: Unable to access 'node_modules/.bin/electron': File or directory not found
                      sdetweil @Benalze
                      @Benalze fun fun fun
                      npm install electron@27.2.1
                        sdetweil @Benalze
                        @Benalze I meant check the package.json sorry
                          Benalze @sdetweil
                          0 Paths updated from index
                            sdetweil @Benalze
                            @Benalze but you did that already… I was wondering about the aliases at the bottom
                              Benalze @sdetweil
                              	"dependencies": {
                              		"colors": "^1.4.0",
                              		"envsub": "^4.1.0",
                              		"feedme": "^2.0.2",
                              		"helmet": "^7.1.0",
                              	"lint-staged": {
                              		"*.js": "eslint",
                              	"_moduleAliases": {
                              		"node_helper": "js/node_helper.js",
                              		"logger": "js/logger.js"
                              	"engines": {
                              		"node": ">=18"
                                sdetweil @Benalze
                                @Benalze good. if the electron install went ok, then npm start
                                  Benalze @sdetweil
                                  BOOM it worked.
                                  Thank you soo sooo much. I really appreciate it!!!
                                  Can you explain to me what was the problem?
                                    sdetweil @Benalze
                                    @Benalze somehow you had the correct top of package.json( that’s where the number comes in the npm start messages), but an incorrect bottom of package json ( no aliases)
                                    but git didn’t report the file being different
                                    I can’t explain that
                                    did u upgrade manually?
                                    if so, in the future please use my script
                                      Benalze @sdetweil
                                      Yes I upgraded manually and in the future I will use your script for sure!
