    MM starts but doesn't show up
    26 Posts 2 Posters 6.9k Views 2 Watching
      Benalze @sdetweil
      OK.
      git status: (translated from GER to ENG)
      pi@raspberrypi:~/MagicMirror $ git status
      On branch master
      Your branch is in the same state as 'origin/master'.
      Changes that are not marked for commit:
        (use "git add <file>..." to mark the changes for commit)
        (use "git restore <file>..." to discard the changes in the working directory)
      	changed: package-lock.json
      Unversioned files:
        (use "git add <file>..." to pre-commit the changes)
      	config.js
      	core
      	installers/pm2_MagicMirror.json
      no changes marked for commit (use "git add" and/or "git commit -a")
      git checkout package.json (translated from GER to ENG)
      pi@raspberrypi:~/MagicMirror $ git checkout package.json
      1 Path updated from index
      check it again
      On branch master
      Unversioned files:
      	config.js
      	core
      and last but not least: ls node_modules/.bin/electron
      pi@raspberrypi:~/MagicMirror $ ls node_modules/.bin/electron
      ls: Unable to access 'node_modules/.bin/electron': File or directory not found
        sdetweil @Benalze
        @Benalze fun fun fun
        npm install electron@27.2.1
          sdetweil @Benalze
          @Benalze I meant check the package.json sorry
            Benalze @sdetweil
            0 Paths updated from index
              sdetweil @Benalze
              @Benalze but you did that already… I was wondering about the aliases at the bottom
                Benalze @sdetweil
                	"optionalDependencies": {
                		"electron": "^27.2.0"
                	"dependencies": {
                		"colors": "^1.4.0",
                		"command-exists": "^1.2.9",
                		"console-stamp": "^3.1.2",
                		"envsub": "^4.1.0",
                		"eslint": "^8.56.0",
                		"express": "^4.18.2",
                		"express-ipfilter": "^1.3.1",
                		"feedme": "^2.0.2",
                		"helmet": "^7.1.0",
                		"html-to-text": "^9.0.5",
                		"iconv-lite": "^0.6.3",
                		"module-alias": "^2.2.3",
                		"moment": "^2.30.1",
                		"node-ical": "^0.17.1",
                		"socket.io": "^4.7.2"
                	"lint-staged": {
                		"*": "prettier --write",
                		"*.js": "eslint",
                		"*.css": "stylelint"
                	"_moduleAliases": {
                		"node_helper": "js/node_helper.js",
                		"logger": "js/logger.js"
                	"engines": {
                		"node": ">=18"
                  sdetweil @Benalze
                  @Benalze good. if the electron install went ok, then npm start
                    Benalze @sdetweil
                    BOOM it worked.
                    Thank you soo sooo much. I really appreciate it!!!
                    Can you explain to me what was the problem?
                      sdetweil @Benalze
                      @Benalze somehow you had the correct top of package.json( that’s where the number comes in the npm start messages), but an incorrect bottom of package json ( no aliases)
                      but git didn’t report the file being different
                      I can’t explain that
                      did u upgrade manually?
                      if so, in the future please use my script
                        Benalze @sdetweil
                        Yes I upgraded manually and in the future I will use your script for sure!
