    Mirror for a Charity Auction
    13 Posts 6 Posters 9.3k Views 6 Watching
      rmonkey
      Outstanding. Love the CNC skills.
      • TipponT Offline
        Tippon @bhepler
        That looks amazing :)
        @bhepler said in Mirror for a Charity Auction:
        It has my reverse SSH code on it, so I can get into it remotely now that it’s been auctioned off.
        I don’t really understand reverse SSH. Does it let you connect if you don’t know the remote IP address? I’m looking at setting up a mirror for my mother in law, and if she changes ISP, the IP address will change. She’s not technical enough to be able to find the new one and let me know.
        Please forgive me if I’m slow to reply, I’m currently experiencing memory issues, and sometimes forget that I’ve asked a question >.<
          bhepler Module Developer @Tippon
          @Tippon Yeah, that’s pretty much it. The mirror attempts to connect to my command & control server at DNS entry that I control. When it connects, it establishes a reverse SSH connection. I can ride that reverse SSH connection down into the mirror. The C&C server is cloud based, so I just turn it off whenever I don’t need to connect to the mirrors.
          Because it’s the mirror making the outgoing connection, firewalls let it pass by. All the mirror needs is a connection to the internet.
          I have a pretty long tutorial on how to set it up. I’m a bit verbose.
          S TipponT 2 Replies Last reply Reply Quote 1
            sdetweil @bhepler
            @bhepler one can also use cloudflare to create a tunnel, (using a docker container on the device to do the inbound connect)
            cloudflare allow you to create an uri that gets mapped to a local address and port…
            I have ssh and vnc access to my systems thru this
            ha.xxx.yyy gives me the HomeAssistant home page
            ssh.xxx.yyy gives me ssh
            vnc.xxx.yyy gives me vnc
            fb.xxx.yyy gives me the file browser
            i’ve got different uris to different systems.
            then u can use https: from the user browser to the cloudflare uri, and then the tunnel…
            you can use other docker tools (filebrowser, …) to give access to different services…
            B TipponT 2 Replies Last reply Reply Quote 1
              bhepler Module Developer @sdetweil
              @sdetweil Now this sounds interesting. Do you have tutorial or URL where I can learn how to set this up?
              • TipponT Offline
                Tippon @bhepler
                @bhepler That’s brilliant, thank you :)
                I’ve got some homework to do :D
                • TipponT Offline
                  Tippon @sdetweil
                  @sdetweil Does that give you SSH access to the server you’re running everything on as well as other devices on your network?
                  I’m currently looking into changing my server OS and putting everything into containers, and then reorganising my network to make everything easier to access, so I’m trying to get everything right from the start :)
                    sdetweil @Tippon
                    @Tippon yes, you register a URL that targets the machine thru the tunnel
                    and then u can target specific systems and ports
                    one of those is the guacamole app, in a container
                    then guacamole will let you create sub apps and different access points to the systems
                    so my ha.xxx.yyy talks directly to home assistant
                    but my rm.xxx.yyy talks to guacamole, which has ‘apps’ defined
                    after I logon to guac, I get a list of my ‘apps’… these present in a web page on the system I am on , so ssh in a web page… now… some things, don’t work the same, nano doesn’t display. but vnc works…
                      see this for a cloudflare tunnel startup…
                      https://developers.cloudflare.com/cloudflare-one/connections/connect-networks/get-started/create-local-tunnel/
                      you need to buy a domain name that you can change the processor underneith… I bought one thru namecheap (domain xxx.xyz) for a few dollars a year for a couple years.
                        and there are lots of cool docker containers to use
                        dozzle will tell you about the status of all the containers
                        uptime-kuma can let you check and report on the status of different ‘apps’ web urls, connections… and send alerts
                        watchtower will watch all the versions of the docker containers and auto upgrade them as they change…
                        my son and I have realized that if we lose our home network, there is no way for all this to tell us… so we are going to add uptime-kuma monitors of things running in the others house and then alert them if there is a lost connection.
