    MMM-CalendarExt3 fine tuning
    7 Posts 3 Posters 2.0k Views 3 Watching
      csongor.varga 0
      Hi All,
      I am making very good progress with the MMM-CalendarExt3, there are only a few things that are odd:
      • The calendar is not showing any past events, which just makes all this wasted space on the screen. Is that a setting?
      • I have configured maxEventLines: 8. On Monday there are 5 entries, but still I can see a +1 icon in the cell why is that? If there are more events, why not showing them?
      The configuration looks like this:
      			module: "MMM-CalendarExt3",
      			position: "bottom_bar",
      			title: "This Week",
      			    mode: "week",
      			    instanceId: "basicCalendar",
      			    locale: 'hu-HU',
      			    maxEventLines: 8,
      			    firstDayOfWeek: 1,
      			    weekIndex: 0,
      			    weeksInView: 2,
      			    useWeather: false,
      			    skipDuplicated: true,
      			    useSymbol: false,
      			    calendarSet: ['Csongor', 'Iza']
      Thanks in advance.
        sdetweil @csongor.varga 0
        @csongor-varga-0 Ext3 gets its events from the default calendar module.
        by default it does not send out past events
        so you have to add
        broadcastPastEvents:true,
        to the config for the default calendar.
        now this adds to the events list, which is limited by the
        maximumEntires: nnnn
        setting. so you may have to increase that too
          csongor.varga 0 @sdetweil
          @sdetweil said in MMM-CalendarExt3 fine tuning:
          Thanks a lot. That was the solution. I can see the past events now, the +1 icons are still appearing on some days where clearly I have less items than the maximum.
          I assume the best practice is to keep maximumEntires: 12, on the calendar module, and maxEventLines: 12, on the Ext3 aligned.
            @csongor-varga-0 said in MMM-CalendarExt3 fine tuning:
            maximumEntires: 12
            you might need
            maximumEntries:1000,
            depending on how much old stuff there is in your calendar
            I would set it to minimum of 100
              that is an Ext3 display thing… I don’t know… the module author is around frequently
                csongor.varga 0
                I wonder if there are options to make the calendar taller.
                I am planning to use my MMM portrait. and with the week view the individual days get quite slim. Maybe each calendar entry take 2 lines, icon and the date on the top line, and the description below. I can increase the vertical size of the module to take up the extra space.
                  MMRIZE @csongor.varga 0
                  @csongor-varga-0
                  • For the multilines events; not naturally. It is designed so intentionally. I know it is probably possible with heavy CSS tweak but I will not do or try it by myself.
                  • For the (+1) : There might be hidden(skipped) events. (You’ve set skipDuplicated: true)
