    MMM-CalendarExt3 fine tuning
    7 Posts 3 Posters 1.9k Views 3 Watching
      csongor.varga 0 @sdetweil
      @sdetweil said in MMM-CalendarExt3 fine tuning:
      @csongor-varga-0 Ext3 gets its events from the default calendar module.
      by default it does not send out past events
      Thanks a lot. That was the solution. I can see the past events now, the +1 icons are still appearing on some days where clearly I have less items than the maximum.
      I assume the best practice is to keep maximumEntires: 12, on the calendar module, and maxEventLines: 12, on the Ext3 aligned.
        sdetweil @csongor.varga 0
        @csongor-varga-0 said in MMM-CalendarExt3 fine tuning:
        maximumEntires: 12
        you might need
        maximumEntries:1000,
        depending on how much old stuff there is in your calendar
        I would set it to minimum of 100
          that is an Ext3 display thing… I don’t know… the module author is around frequently
            csongor.varga 0
            I wonder if there are options to make the calendar taller.
            I am planning to use my MMM portrait. and with the week view the individual days get quite slim. Maybe each calendar entry take 2 lines, icon and the date on the top line, and the description below. I can increase the vertical size of the module to take up the extra space.
              MMRIZE @csongor.varga 0
              @csongor-varga-0
              • For the multilines events; not naturally. It is designed so intentionally. I know it is probably possible with heavy CSS tweak but I will not do or try it by myself.
              • For the (+1) : There might be hidden(skipped) events. (You’ve set skipDuplicated: true)
