    MMM-AccuWeatherForecastDeluxe Fahrenheit instead of Celsius
    4 Posts 3 Posters 1.4k Views 3 Watching
      svenpisa
      And because it’s so nice, here’s the next request.
      I downloaded the https://github.com/maxbethge/MMM-AccuWeatherForecastDeluxe module to my MM because I really like the design.
      There are only two things I can’t change and I’m wondering where I’m making a mistake.
      Display of the days: I have set the line maxDailiesToShow: 8 from 5 to 8 in Config.js. Nevertheless, I still get 5 days displayed and not 8 days as desired. Also in the module js file 8 are entered. Why are only the 5 days displayed anyway?
      Display Fahrenheit instead of Celsius: All modules on my MM run on Celsius and “metric” is also entered in the units in Config.js
      	language: "de",
      	locale: "de-DE",
      	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      	timeFormat: 24,
      	units: "metric",
      Here is also the excerpt from the MMM-AccuWeatherForecastDeluxe
            units: config.units,
              language: "de-DE",
      How can I also set Celsius in this module? What do I have to enter in my Custom.css? or am I missing something?
      Sorry for all my questions and thanks for help
      S H 2 Replies Last reply Reply Quote 0
        sdetweil @svenpisa
        @svenpisa can you show the module config? xxx out your apikey
          svenpisa @sdetweil
          Hi @sdetweil
          Here is the modul config
          			module: "MMM-AccuWeatherForecastDeluxe",
          			header: "Wettervorhersage",
          			position: "top_center",
          			classes: "default everyone",
          			disabled: false,
          				apikey: "H5ShqAVZaIGdQDoSrG4uwS31xxxxx",
          				locationKey: "1685xx",
          				relativeColors: true,
          				showCurrentConditions: false,
          				showExtraCurrentConditions: false,
          				showSummary: false,
          				showForecastTableColumnHeaderIcons: false,
          				showHourlyForecast: false,
          				dailyForecastLayout: 'bars',
          				maxDailiesToShow: 8,
          				showPrecipitationProbability: false,
          				showPrecipitationSeparator: false,
          				showPrecipitationAmount: false,
          				showWindSpeed: false,
          				showWindDirection: false,
          				showWindGust: false,
          				iconset: "4c",
          				useAnimatedIcons: false,
          				label_ordinals: ['↓', '↙', '←', '↖', '↑', '↗', '→', '↘'],
          				label_high: "",
          				label_low: "",
          I tried it with locationkey and also with latitude and longitude. Nothing works. But i think that is not the problem.
          However… I have distanced myself from this module for the time being and am currently trying to change the icons in the standard weather module based on your instructions and forum entry. That seems to make more sense to me at the moment.
          If you find a solution for this Accu module, it might be interesting for other users. I myself will not use it for the time being or test it on https://github.com/luxiouronimo/MMM-OpenWeatherForecastDeluxe. :-)
          • H Offline
            hrmax23 @svenpisa
            @svenpisa I created this module based on the OpenWeatherForecastDeluxe project but the backend AccuWeather API is obviously different than the OpenWeather API. It only supports forecasts for a couple different time periods. It could be updated to filter those however, the big issue at the moment is the upcoming deprecation of the free limited license for the API. There will soon be only a 14-day trial and paid licenses which $25 a month appears to be the cheapest which is a no-go.
