    MMM-todoist dosent hide with this Option
    9 Posts 2 Posters 2.9k Views 2 Watching
    • F
      fischi87
      HI,
      i set the hideWhenEmpty to true but it still display the header and the borderline. I had a look at the code and there I saw nothing about defaults with hideWhenEmpty. I saw in the code there is a getDom function but this dosent work.
      someone know about that?
      thanks
        sdetweil @fischi87
        @fischi87 I looked at code and it uses that property, incorrectly in my opinion
        F 1 Reply Last reply
        • F
          fischi87 @sdetweil
          For example i try this?
          return this.hide()
          U think it will be better?
            sdetweil @fischi87
            @fischi87 no… getDom() should ALWAYS return something
            	getDom: function () {
            		//Add a new div to be able to display the update time alone after all the task
            		//display "loading..." if not loaded
            		if (!this.loaded) {
            			wrapper.innerHTML = "Loading...";
            			wrapper.className = "dimmed light small";
            			return wrapper;
                            // moved to here and changed return
            		if (this.config.hideWhenEmpty && this.tasks.items.length === 0) {
            			return wrapper;
            • F
              fischi87 @sdetweil
              I think this don’t work because I see still the header. it es possible to display a empty wrapper?
                sdetweil @fischi87
                @fischi87 header is different its not hidden.
                do, could do self.hide()
                I was returning an empty div
                • F
                  fischi87 @sdetweil
                  u can explain me how it works with self.hide()? where I have to write it down and so on?
                    sdetweil @fischi87
                    @fischi87 add the one line, this.hide() shown below
                                            this.hide()  // added hide to hide header too
                        			return wrapper;
                    • F
                      fischi87 @sdetweil
                      It works thanks Sam
