Solved MMM-CalendarExt3Journal not displaying
@jlward73 view notifications
all the config is optional, so it should display every notification and there are a lot of them
@jlward73
Let’s make things simpler.
What is your current major problem. CX3J is not showing? Or Button is not working?
Solve it one-by-one.If your issue is about Button, create a new post about it. You don’t have to mention CX3J not to make things complex. Only focus on the Button’s work (and its notification maybe.)
If your issue is CX3J’s working, Forget Button things.
Backup your current config then remove all other modules from config exceptclock
,calendar
,MMM-CalendarExt3Journal
. Then execute MM.
Show me the whole front-end log. -
@MMRIZE I got Buttons working, so just need to focus on CX3J. Let me take it down to just the basics like you say and I will see what shakes out. Thanks.
@MMRIZE
I took it down to what you said and the journal displayed, but not as I expected and that may be the root of the problem. It looks like the individual calendars load up properly, but the height of each hour is too much. As a starting point, I had the calendar starting at 0700 and going for 12 hours, but (provided I uploaded the image properly), it cuts off just before 1100. I could probably experiment with the config or css file, but you would probably know right off the top of your head. -
/* config/config.js */ { module: "MMM-CalendarExt3Journal", position: "bottom_bar", config: { height: '50vh', // Half of the screen hourLength: 12, // Display 12 hours beginHour: 7, // From 7 o'clock staticWeek: true, // Since Monday days: 7, // For 7 days } },
@MMRIZE That’s pretty much the same configuration I have. It’s the same config as I had at the beginning of the post except I changed the hours to start at 0700 and go for 12 hours. I don’t understand why my individual hours are so tall compared to yours. I thought, if you increase the hourLength, it would adjust the individual hours to fit within the 50vh limit. Am I missing something, or do I need to take a look at the front-end log?
@jlward73
DefaulthourLength
is 4, so it seems your config is missing or mistyping that value. -
@MMRIZE
Syntax strikes again. I had the variable as hourlength vice hourLength. Also, I had CX3J and the newsfeed module both along the bottom bar. I moved CX3J up to the lower third and all is displaying right. Now I just want to do some tweaks to the css file for formatting. Thanks again for all your help and the great modules. -
