MMM-MyCalendar install problem
I’ve been using the default calendar module for awhile now, and living with the incorrect date for one of my recurring events. Specifically, my event occurs on the first Thursday of each month, and the calendar seems to show the correct date for the first occurrence, but all subsequent occurrences seem to happen on the first Wednesday of each month — one day early.
I understand that one solution may be to use the MMM-MyCalendar module instead. I attempted this and discovered that my MM wouldn’t launch, and attempted a workaround shown here:
https://github.com/jclarke0000/MMM-MyCalendar/issues/40
As others have reported, MM will now launch, but the calendar never appears (always indicates ‘loading’). I can put back the original calendar module, and just live with the problem, but does anyone have any other suggestions? Thanks.
I am running MM version 2.27.0, node v20.4, npm v9.8.1
I read that post already, which allowed me to get the MM running again. I just commented out the lines indicated.
@Freddy_boy what MagicMirror version are you running? there were some significant changes in the latest version
also see this issue for the module
https://github.com/jclarke0000/MMM-MyCalendar/issues/40 -
Not sure what happened here… You indicate that this issue is solved…? I still don’t have a calendar yet. MM launches now, but I only have an indication that the calendar is “Loading…” but it never appears.
@Freddy_boy ok, I guessed it was solved…
so, look at the messages where you start MM
if pm2, then
pm2 logs --lines=xxx
where xxx is some number, default 15
you might need 100always best when adding/changing NOT to use pm2
pm2 stop all cd ~/MagicMirror npm start
then u can see the messages immediately
when u get it all working then
pm2 status
and then pm2 start x
where x is the name or number on the row of the managed app you want to startpm2 --help will show you all the command options
this is a typical scenario for all linux command line commands --help shows the help
and most times
man command_name
will show you the user manual
q, quits the manual display -
I don’t believe that I am using pm2. Here are the logs when MM starts:
magicmirror@2.27.0 start
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js[2024-05-03 16:04:55.886] [LOG] Starting MagicMirror: v2.27.0
[2024-05-03 16:04:55.935] [LOG] Loading config …
[2024-05-03 16:04:55.938] [LOG] config template file not exists, no envsubst
[2024-05-03 16:04:55.957] [LOG] Loading module helpers …
[2024-05-03 16:04:55.958] [LOG] No helper found for module: alert.
[2024-05-03 16:04:56.237] [LOG] Initializing new module helper …
[2024-05-03 16:04:56.239] [LOG] Module helper loaded: updatenotification
[2024-05-03 16:04:56.240] [LOG] No helper found for module: clock.
[2024-05-03 16:04:56.402] [LOG] Initializing new module helper …
[2024-05-03 16:04:56.403] [LOG] Module helper loaded: MMM-MyCalendar
[2024-05-03 16:04:56.403] [LOG] No helper found for module: calendar_monthly.
[2024-05-03 16:04:56.414] [LOG] Initializing new module helper …
[2024-05-03 16:04:56.414] [LOG] Module helper loaded: MMM-Pir
[2024-05-03 16:04:56.462] [LOG] Initializing new module helper …
[2024-05-03 16:04:56.462] [LOG] Module helper loaded: MMM-Weather
[2024-05-03 16:04:56.543] [LOG] Initializing new module helper …
[2024-05-03 16:04:56.544] [LOG] Module helper loaded: MMM-Tools
[2024-05-03 16:04:56.673] [LOG] Initializing new module helper …
[2024-05-03 16:04:56.674] [LOG] Module helper loaded: newsfeed
[2024-05-03 16:04:56.674] [LOG] All module helpers loaded.
[2024-05-03 16:04:56.685] [LOG] Starting server on port 8080 …
[2024-05-03 16:04:58.244] [LOG] Server started …
[2024-05-03 16:04:58.247] [LOG] Connecting socket for: updatenotification
[2024-05-03 16:04:58.248] [LOG] Starting module helper: updatenotification
[2024-05-03 16:04:58.250] [LOG] Connecting socket for: MMM-MyCalendar
[2024-05-03 16:04:58.261] [LOG] Starting node helper for: MMM-MyCalendar
[2024-05-03 16:04:58.262] [LOG] Connecting socket for: MMM-Pir
[2024-05-03 16:04:58.264] [LOG] Connecting socket for: MMM-Weather
[2024-05-03 16:04:58.272] [LOG] Connecting socket for: MMM-Tools
[2024-05-03 16:04:58.284] [LOG] [Tools] MMM-Tools Version: 2.1.7
[2024-05-03 16:04:58.286] [LOG] Connecting socket for: newsfeed
[2024-05-03 16:04:58.287] [LOG] Starting node helper for: newsfeed
[2024-05-03 16:04:58.288] [LOG] Sockets connected & modules started …
WARNING: v3dv is neither a complete nor a conformant Vulkan implementation. Testing use only.
[2024-05-03 16:04:58.891] [LOG] Launching application.
[2024-05-03 16:05:02.661] [LOG] Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/39/Canada_Holidays.ics - Interval: 300000
[2024-05-03 16:05:02.668] [ERROR] Whoops! There was an uncaught exception…
[2024-05-03 16:05:02.677] [ERROR] ReferenceError: fetcher is not defined
at fetchCalendar (/home/pi/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js:65:3)
at CalendarFetcher.startFetch (/home/pi/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js:110:3)
at Class.createFetcher (/home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js:73:11)
at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js:21:9)
at Socket. (/home/pi/MagicMirror/js/node_helper.js:98:11)
at Socket.emit (node:events:514:28)
at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:704:39
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
[2024-05-03 16:05:02.680] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[2024-05-03 16:05:02.684] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
[2024-05-03 16:05:02.686] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/5u47rliikveghncls65jrsotkc%40group.calendar.google.com/private-7c6a117f2ae0d357b447c735373245a2/basic.ics - Interval: 300000
[2024-05-03 16:05:02.688] [ERROR] Whoops! There was an uncaught exception…
[2024-05-03 16:05:02.689] [ERROR] ReferenceError: fetcher is not defined
[2024-05-03 16:05:02.690] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[2024-05-03 16:05:02.690] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
[2024-05-03 16:05:02.790] [LOG] Create new newsfetcher for url: https://rss.cbc.ca/lineup/canada.xml - Interval: 300000
[2024-05-03 16:05:03.039] [LOG] Create new newsfetcher for url: https://rss.cbc.ca/lineup/canada-toronto.xml - Interval: 300000
[2024-05-03 16:05:03.052] [LOG] Create new newsfetcher for url: https://rss.cbc.ca/lineup/sports-nhl.xml - Interval: 300000
[2024-05-03 16:05:03.071] [LOG] [WEATHER] MMM-WEATHER Version: 1.0.6
[2024-05-03 16:05:03.112] [LOG] [MMM-Pir] Version: 1.5.1 rev: 240402
[2024-05-03 16:05:03.114] [LOG] [MMM-Pir] [LIB] [PIR] Mode 0 Selected (onoff library)
[2024-05-03 16:05:03.168] [LOG] [MMM-Pir] [LIB] [PIR] Started!
[2024-05-03 16:05:03.172] [LOG] [MMM-Pir] [LIB] [SCREEN] Mode 4: HDMI CEC
[2024-05-03 16:05:03.228] [LOG] [MMM-Pir] Started!
[2024-05-03 16:05:03.231] [INFO] updatenotification: Updater Class Loaded!
[2024-05-03 16:05:03.233] [INFO] updatenotification: Checking PM2 using…
[2024-05-03 16:05:03.239] [INFO] Checking git for module: MMM-MyCalendar
[2024-05-03 16:05:03.375] [INFO] Checking git for module: calendar_monthly
[2024-05-03 16:05:03.478] [INFO] System information:SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.4; raspberry: [object Object]; virtual: false
OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 5.10.103-v7l+
VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 20.4.0; npm: 9.8.1; pm2: 5.3.1
OTHER: timeZone: America/Toronto; ELECTRON_ENABLE_GPU: undefined
[2024-05-03 16:05:03.529] [INFO] Checking git for module: MMM-Pir
[2024-05-03 16:05:03.687] [INFO] updatenotification: [PM2] You are not using pm2
[2024-05-03 16:05:04.116] [INFO] Checking git for module: MMM-Weather
[2024-05-03 16:05:04.566] [INFO] Checking git for module: MMM-Tools
[2024-05-03 16:05:04.708] [INFO] Newsfeed-Fetcher: Broadcasting 18 items.
[2024-05-03 16:05:04.809] [INFO] Checking git for module: MagicMirror
[2024-05-03 16:05:04.861] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
[2024-05-03 16:05:04.874] [INFO] Newsfeed-Fetcher: Broadcasting 19 items.
[2024-05-03 16:05:14.810] [LOG] Shutting down server…
[2024-05-03 16:05:14.812] [LOG] Stopping module helper: updatenotification
[2024-05-03 16:05:14.813] [LOG] Stopping module helper: MMM-MyCalendar
[2024-05-03 16:05:14.813] [LOG] Stopping module helper: MMM-Pir
[2024-05-03 16:05:14.814] [LOG] Stopping module helper: MMM-Weather
[2024-05-03 16:05:14.814] [LOG] Stopping module helper: MMM-Tools
[2024-05-03 16:05:14.815] [LOG] Stopping module helper: newsfeed
[2024-05-03 16:05:14.816] [LOG] Node_helpers stopped …
[2024-05-03 16:05:14.891] [LOG] [MMM-Pir] [LIB] [SCREEN] See you soon !
[2024-05-03 16:05:14.893] [LOG] [MMM-Pir] [LIB] [SCREEN] @bugsounet -
@Freddy_boy said in MMM-MyCalendar install problem:
at fetchCalendar (/home/pi/MagicMirror/modules/MMM-MyCalendaryep
you didn’t get all the change from the linked issue
Ah, yes. That was it. Instead of manually making the changes, I just copied the entire code and pasted. Seems to work now. Thanks!
[2024-05-03 16:05:14.893] [LOG] [MMM-Pir] [LIB] [SCREEN] @bugsounetReally… I have to delete this…
In all case, I’m happy that’s resolved.
