    Newbie Trying to Get Started
    13 Posts 3 Posters 3.2k Views 3 Watching
      sdetweil @LoneSoldier
      @LoneSoldier see
      https://forum.magicmirror.builders/topic/15663/how_to-magicmirror-as-desktop-wallpaper-all-platform-updated?_=1715801448276
      by default MagicMirror IS the app running on a fixed display on the wall so it would BE
      the image displayed
        @sdetweil address in use means it is running already
        probably via pm2, so do
        pm2 stop all
        see the output of
        pm2 --help
        for all the command options
        • L Offline
          LoneSoldier @sdetweil
          @sdetweil Yes, that’s where I got my code, but I don’t think it’s using that.
          Yes, I also just figured out it’s already running.
          When I launch it in my Mate desktop, it covers all the windows and also the panel on one of my monitors. It’s not in the background at all.
          Here is the valid CLI output:
          [config]$ magicmirror
          > magicmirror@2.22.0 start
          [15.05.2024 22:43.51.198] [LOG]   Starting MagicMirror: v2.22.0
          [15.05.2024 22:43.51.200] [LOG]   Loading config ...
          [15.05.2024 22:43.51.201] [LOG]   Loading module helpers ...
          [15.05.2024 22:43.51.202] [LOG]   No helper found for module: alert.
          [15.05.2024 22:43.51.208] [LOG]   Initializing new module helper ...
          [15.05.2024 22:43.51.208] [LOG]   Module helper loaded: updatenotification
          [15.05.2024 22:43.51.208] [LOG]   No helper found for module: clock.
          [15.05.2024 22:43.51.267] [LOG]   Initializing new module helper ...
          [15.05.2024 22:43.51.267] [LOG]   Module helper loaded: calendar
          [15.05.2024 22:43.51.267] [LOG]   No helper found for module: compliments.
          [15.05.2024 22:43.51.268] [LOG]   No helper found for module: weather.
          [15.05.2024 22:43.51.275] [LOG]   Initializing new module helper ...
          [15.05.2024 22:43.51.275] [LOG]   Module helper loaded: newsfeed
          [15.05.2024 22:43.51.275] [LOG]   All module helpers loaded.
          [15.05.2024 22:43.51.310] [LOG]   Starting server on port 8080 ...
          [15.05.2024 22:43.51.394] [LOG]   Server started ...
          [15.05.2024 22:43.51.394] [LOG]   Connecting socket for: updatenotification
          [15.05.2024 22:43.51.395] [LOG]   Starting module helper: updatenotification
          [15.05.2024 22:43.51.395] [LOG]   Connecting socket for: calendar
          [15.05.2024 22:43.51.395] [LOG]   Starting node helper for: calendar
          [15.05.2024 22:43.51.395] [LOG]   Connecting socket for: newsfeed
          [15.05.2024 22:43.51.395] [LOG]   Starting node helper for: newsfeed
          [15.05.2024 22:43.51.395] [LOG]   Sockets connected & modules started ...
          [15.05.2024 22:43.51.406] [LOG]   Launching application.
          [15.05.2024 22:43.52.005] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
          [15.05.2024 22:43.52.016] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
          [15.05.2024 22:43.52.029] [INFO]  Checking git for module: default
          [15.05.2024 22:43.52.406] [INFO]  Newsfeed-Fetcher: Broadcasting 25 items.
          [15.05.2024 22:43.53.215] [INFO]  Calendar-Fetcher: Broadcasting 8 events.
          ^C/usr/share/magicmirror/node_modules/electron/dist/electron exited with signal SIGINT
          [config]$ pm2
          bash: pm2: command not found
          [config]$
          Thank you.
            @LoneSoldier how did you make it autostart? create a service?
            that code is 3 years old
            I never tried it
            @MMRIZE does this still work?
              MMRIZE @sdetweil
              For Linux, there are many distros, so I’m not sure it works on all environments.
              For Mac/Windows, I think it will still work.
                MMRIZE @LoneSoldier
                @LoneSoldier
                On which lines did you put the additional configurations? Last line? Show me full config.js.
                • L Offline
                  LoneSoldier @MMRIZE
                  @MMRIZE
                  Here’s the whole file. I don’t know yet what else to put in. Just trying to get started:
                  // in your config.js add these lines.
                  electronOptions: {
                    width: 1920,
                    height: 1200,
                    fullscreen:  false,
                    backgroundColor: '#00000000',
                    titleBarStyle: 'none',
                    frame: false,
                    type: 'desktop',
                    hasShadow: false,
                    transparent: true,
                    resizable:   false,
                  electronSwitches: ["enable-transparent-visuals"],
                    MMRIZE
                    I tested on my Mac, it works still.(MM 2.27) For linux, I believe it has to work also. (Because it is one of the default features of the Electron.)
                    CONFIG.JS
                    /* config.js */
                    timeFormat: 24,
                    units: "metric",
                    /* Insert here */
                    electronOptions: {
                    	fullscreen:  false,
                    	frame: false,
                    	type: 'desktop',
                    	hasShadow: false,
                    	transparent: true,
                    	resizable:   false,
                    		module: "clock",
                    		position: "top_left"
                    CUSTOM.CSS
                    /* custom.css */
                    :root {
                      --color-text: #ddd;
                      --color-text-dimmed: #bbb;
                      --color-text-bright: #fff;
                      --color-background: rgba(0, 0, 0, 0);
                      /* make fonts color brighter */
                      --font-size: 2vh;
                      --font-size-small: 0.75rem;
                      --gap-body-top: 20px;
                      --gap-body-right: 120px;
                      --gap-body-bottom: 20px;
                      --gap-body-left: 40px;
                      /* adjust margin for your screen */
                      text-shadow: 2px 2px 5px #000000; /* make text more readable on the background image */
                      @LoneSoldier that cannot be the whole file.
                      see the config.js.sample in the vonfig folder as a starter. you can add those fields to it
                      my install script copies the sample to start with
                      • L Offline
                        @sdetweil The issue here is indeed something with the install. The app appears to run, but it did not create a config file for me.
                        So I copied the one from https://github.com/MagicMirrorOrg/MagicMirror/blob/master/config/config.js.sample and also added the lines as above and launched it again, but it’s the same.
                        It’s supposed to be in
                        ~/MagicMirror/config/config.js
                        apparently, and that’s where mine is.
                        But if I rename that file, I get the same results. So I think it’s not picking up that config file at all.
                        Perhaps I should install from the repo instead of using Arch’s build?
