    Newbie Trying to Get Started
    13 Posts 3 Posters 3.1k Views 3 Watching
    • L Offline
      LoneSoldier @sdetweil
      @sdetweil Yes, that’s where I got my code, but I don’t think it’s using that.
      Yes, I also just figured out it’s already running.
      When I launch it in my Mate desktop, it covers all the windows and also the panel on one of my monitors. It’s not in the background at all.
      Here is the valid CLI output:
      [config]$ magicmirror
      > magicmirror@2.22.0 start
      [15.05.2024 22:43.51.198] [LOG]   Starting MagicMirror: v2.22.0
      [15.05.2024 22:43.51.200] [LOG]   Loading config ...
      [15.05.2024 22:43.51.201] [LOG]   Loading module helpers ...
      [15.05.2024 22:43.51.202] [LOG]   No helper found for module: alert.
      [15.05.2024 22:43.51.208] [LOG]   Initializing new module helper ...
      [15.05.2024 22:43.51.208] [LOG]   Module helper loaded: updatenotification
      [15.05.2024 22:43.51.208] [LOG]   No helper found for module: clock.
      [15.05.2024 22:43.51.267] [LOG]   Initializing new module helper ...
      [15.05.2024 22:43.51.267] [LOG]   Module helper loaded: calendar
      [15.05.2024 22:43.51.267] [LOG]   No helper found for module: compliments.
      [15.05.2024 22:43.51.268] [LOG]   No helper found for module: weather.
      [15.05.2024 22:43.51.275] [LOG]   Initializing new module helper ...
      [15.05.2024 22:43.51.275] [LOG]   Module helper loaded: newsfeed
      [15.05.2024 22:43.51.275] [LOG]   All module helpers loaded.
      [15.05.2024 22:43.51.310] [LOG]   Starting server on port 8080 ...
      [15.05.2024 22:43.51.394] [LOG]   Server started ...
      [15.05.2024 22:43.51.394] [LOG]   Connecting socket for: updatenotification
      [15.05.2024 22:43.51.395] [LOG]   Starting module helper: updatenotification
      [15.05.2024 22:43.51.395] [LOG]   Connecting socket for: calendar
      [15.05.2024 22:43.51.395] [LOG]   Starting node helper for: calendar
      [15.05.2024 22:43.51.395] [LOG]   Connecting socket for: newsfeed
      [15.05.2024 22:43.51.395] [LOG]   Starting node helper for: newsfeed
      [15.05.2024 22:43.51.395] [LOG]   Sockets connected & modules started ...
      [15.05.2024 22:43.51.406] [LOG]   Launching application.
      [15.05.2024 22:43.52.005] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
      [15.05.2024 22:43.52.016] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      [15.05.2024 22:43.52.029] [INFO]  Checking git for module: default
      [15.05.2024 22:43.52.406] [INFO]  Newsfeed-Fetcher: Broadcasting 25 items.
      [15.05.2024 22:43.53.215] [INFO]  Calendar-Fetcher: Broadcasting 8 events.
      ^C/usr/share/magicmirror/node_modules/electron/dist/electron exited with signal SIGINT
      [config]$ pm2
      bash: pm2: command not found
      [config]$
      Thank you.
        sdetweil @LoneSoldier
        @LoneSoldier how did you make it autostart? create a service?
        that code is 3 years old
        I never tried it
        @MMRIZE does this still work?
          MMRIZE @sdetweil
          For Linux, there are many distros, so I’m not sure it works on all environments.
          For Mac/Windows, I think it will still work.
            MMRIZE @LoneSoldier
            @LoneSoldier
            On which lines did you put the additional configurations? Last line? Show me full config.js.
            • L Offline
              LoneSoldier @MMRIZE
              @MMRIZE
              Here’s the whole file. I don’t know yet what else to put in. Just trying to get started:
              // in your config.js add these lines.
              electronOptions: {
                width: 1920,
                height: 1200,
                fullscreen:  false,
                backgroundColor: '#00000000',
                titleBarStyle: 'none',
                frame: false,
                type: 'desktop',
                hasShadow: false,
                transparent: true,
                resizable:   false,
              electronSwitches: ["enable-transparent-visuals"],
                MMRIZE
                I tested on my Mac, it works still.(MM 2.27) For linux, I believe it has to work also. (Because it is one of the default features of the Electron.)
                CONFIG.JS
                /* config.js */
                timeFormat: 24,
                units: "metric",
                /* Insert here */
                electronOptions: {
                	fullscreen:  false,
                	frame: false,
                	type: 'desktop',
                	hasShadow: false,
                	transparent: true,
                	resizable:   false,
                		module: "clock",
                		position: "top_left"
                CUSTOM.CSS
                /* custom.css */
                :root {
                  --color-text: #ddd;
                  --color-text-dimmed: #bbb;
                  --color-text-bright: #fff;
                  --color-background: rgba(0, 0, 0, 0);
                  /* make fonts color brighter */
                  --font-size: 2vh;
                  --font-size-small: 0.75rem;
                  --gap-body-top: 20px;
                  --gap-body-right: 120px;
                  --gap-body-bottom: 20px;
                  --gap-body-left: 40px;
                  /* adjust margin for your screen */
                  text-shadow: 2px 2px 5px #000000; /* make text more readable on the background image */
                  @LoneSoldier that cannot be the whole file.
                  see the config.js.sample in the vonfig folder as a starter. you can add those fields to it
                  my install script copies the sample to start with
                  • L Offline
                    @sdetweil The issue here is indeed something with the install. The app appears to run, but it did not create a config file for me.
                    So I copied the one from https://github.com/MagicMirrorOrg/MagicMirror/blob/master/config/config.js.sample and also added the lines as above and launched it again, but it’s the same.
                    It’s supposed to be in
                    ~/MagicMirror/config/config.js
                    apparently, and that’s where mine is.
                    But if I rename that file, I get the same results. So I think it’s not picking up that config file at all.
                    Perhaps I should install from the repo instead of using Arch’s build?
                      @LoneSoldier the git clone/npm install does NOT copy the sample config.js
                      see step 4 of the installation instructions
                      3. Install the application: npm run install-mm
                      4. Make a copy of the config sample file: cp config/config.js.sample config/config.js
                      you do NOT need to copy from the github repo… the file is in the config folder
                      also why verion 2.22?? we are on v 2.27 now
                      if there is an ERROR, then there is a built in minimal config.js used
                      easy way to determine
                      is to add
                      disabled: true,
                      after some module:
                      entry
                      and restart magic mirror
                      note if you created a service to start MM on boot, THAT instance is running and you MUST stop it to change config settings…
                      you don’t need to reinstall… just do the correct things
                      to see if something is running from a terminal window do
                      ps -ef | grep -i magicmirror
                      if there is more than one line then you have to stop it…
                      • L Offline
                        @sdetweil OK, the issue was that I used this
                        https://aur.archlinux.org/packages/magicmirror
                        It’s 2.22 and I’m not sure how it works.
                        I installed normally from git now and it works, and also the “wallpaper” code works for me.
                        Thank you for your help.
                        Now I will try to configure this.
