    MMM-AlarmClock popup not appearing when alarm goes off
    3 Posts 2 Posters 604 Views 2 Watching
      jjd
      Hi, I’m having a problem with MMM-AlarmClock where the popup (to dismiss the alarm) isn’t appearing when the alarm goes off.
      This was working fine for me, and then I upgraded to the latest Raspbian, MagicMirror, and MMM-AlarmClock and the popup stopped appearing. I posted on the module’s github, but got no responses: https://github.com/fewieden/MMM-AlarmClock/issues/48
      My (test) configuration is:
      	    module: 'MMM-AlarmClock',
      	    position: 'middle_center',
      		alarms: [
      			time: "11:19",
      			days: [0,1,2,3,4,5,6],
      			sound: 'alarm.mp3',
      			title: "title",
      			message: "message",
      		touch: true,
      		popup: true,
      I’m using a Raspberry Pi Model B Rev 1.2 with Pi 7-inch Touchscreen running Raspbian 12 (bookworm). My node version is 20.15.0, my MagicMirror version is v2.28.0 and the MMM-AlarmClock version is 2.0.2.
      Any help/advice would be appreciated.
      J 1 Reply Last reply
        jjd @jjd
        I eventually figured this out: I hadn’t had alert listed in the modules list.
        More details here: https://github.com/fewieden/MMM-AlarmClock/issues/48
        B 1 Reply Last reply
        • J jjd has marked this topic as solved on
          BiaGen @jjd
          Hey, I ran into a similar issue before — the popup didn’t appear even though the alarm triggered. In my case, it turned out to be a config issue with the notification settings in the module. Try checking if the showPopup option is enabled and that you don’t have another module overlapping it on the screen.
          Also, while testing your setup, you can use something like onlinealarm.co
          to verify your alarm times are correct before syncing it with MagicMirror — makes debugging way easier.
