    Not updating at midnight...
    24 Posts 3 Posters 4.8k Views 3 Watching
    • BKeyportB
      I think I got it figured out - Based on research elsewhere - if I’m correct: start: function() is only called upon load, correct?
      ASSUMING that’s the case, this seems to work better:
      start: function () {
          function scheduleMidnightUpdate() {
              const now = new Date();
              const nextMidnight = new Date(now);
              // Set the time to midnight
              nextMidnight.setHours(24, 0, 0, 0);
              // Calculate the time remaining until the next midnight
              const timeUntilMidnight = nextMidnight - now;
              // Schedule the updateDom method to be called at midnight
              setTimeout(() => {
                  this.updateDom();
                  // Reschedule the update for the next midnight
                  scheduleMidnightUpdate.call(this);
              }, timeUntilMidnight);
          // Call the function to start the first schedule
      Now, This seems to work on testing - but it will fail in testing if I change the clock after starting MM.
      Is there anyway y’all can see to improve this, or am I good?
      M 1 Reply Last reply
        MMRIZE @BKeyport
        @BKeyport
        Your DOM might not be rendered yet on “start” imo. I think manipulating DOM after “DOM_OBJECT_CREATED” notification would be safer.
          sdetweil @MMRIZE
          @MMRIZE
          Yes the documented flow is, as I recall on my phone,
          Init
          Getstyles
          Getscripts
          GetTemplates
          Start
          Notification received
          AllModulesStarted
          DOMobjectsCreated
          getDOM
          BKeyportB 1 Reply Last reply
          • BKeyportB
            @sdetweil @MMRIZE so, should I move the initial call somewhere else?
              sdetweil @BKeyport
              @BKeyport after the notification
              From the doc
              DOM_OBJECTS_CREATED - All dom objects are created. The system is now ready to perform visual changes.
              • BKeyportB
                @sdetweil said in Not updating at midnight...:
                        setTimeout(() => {
                            this.updateDom();
                    notificationReceived: function (notification, payload, sender) {
                        if (notification === 'CALENDAR_EVENTS') {
                            this.storedEvents = JSON.parse(JSON.stringify(payload))
                            this.updateDom();
                        } else if (notification === 'DOM_OBJECTS_CREATED') {
                This is the only source I see in the docs of that - a notification. Is that correct?
                Thanks for the patience after the double misunderstanding.
                S 2 Replies Last reply
                  sdetweil @BKeyport
                  @BKeyport
                  https://docs.magicmirror.builders/development/core-module-file.html
                  you could have done all the initial event calculating in one function
                  used interval for the midnights (as it’s a fixed number)
                    @BKeyport MODULE_DOM_CREATED means YOUR getDom()/getTemplateData() has been called
                    • BKeyportB
                      @sdetweil yeah, doing it that way just throws headers with “Undefined” until it triggers. I’m not gonna go down that rabbit hole. It seems to work as is, so I’m gonna release for now.
                        sdetweil @BKeyport
                        @BKeyport said in Not updating at midnight...:
                            setTimeout(() => {
                                this.updateDom();
                        I would do it like this , much more straight forward
                                 setTimeout(() => {
                                     // trigger first update on next midnight change
                                     this.updateDom();
                                    // start Recurring midnight change
                                     setInterval(()=>{
                                         this.updateDom()
                                     }, 24*60*60*1000 ) // 24 hours * 60 minutes * 60 seconds * 1000 milliseconds (1 day elapsed in ms)  setInterval delay
                                 }, timeUntilMidnight);  // setTimeout delay
                        then the system triggers every midnight… not your code
